NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. May 7, 2020 at 4:11 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    do you have the 3* cam gears?
  2. May 7, 2020 at 4:15 PM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Not yet I need to drill my old ones
  3. May 7, 2020 at 4:50 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i have a set of non oem. they are chromoly but they are cut at stock keyway. they can be cut for the 3* by a guy on here for 85$ i think. you can have them if you like. my cams will make the same change so theyre paper weights for me. maybe save you some downtime.
  4. May 7, 2020 at 6:06 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    Finally getting my tool/recovery gear storage area finalized.
    still waiting on the foam to get in.
  5. May 7, 2020 at 6:25 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    thats some serious prep. i need to charge my jump box and see if it works. at 1% after starting a dead cummins.
    Usethe2nd[QUOTED] likes this.
  6. May 7, 2020 at 7:12 PM
    Filip38507
    Filip38507 Well-Known Member
    Filip
    Lynnwood Washington
    2019 Tacoma TRD Offroad
    Went to get my Toyota care service done at magic Toyota and long story short they forgot to put the nut in the bolt of the negative terminal of the battery leaving my light bar and winch connectors just dangling there and they were no help on the phone does anyone know where you could get an OEM nut?
  7. May 7, 2020 at 7:48 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Theres nothing special about those nuts so you could just run to a hardware store and pick one up. Going off memory its a like M6x1.0 for the nut that clamps the terminal to the post. The positive has the extra stud and i want to say that one was M8x1.25 but might be m6 too.
  8. May 7, 2020 at 8:02 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    They're the pair I pulled from my old motor, so already out. I bet @Usethe2nd might be interested in the ones you have.
  9. May 7, 2020 at 8:02 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    hey man im close if you need help.
  10. May 7, 2020 at 8:03 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i paid xx free to good home.well, they were $100 but ill part for free. moving soon.
    bobsuruncle[QUOTED] likes this.
  11. May 7, 2020 at 9:05 PM
    Filip38507
    Filip
    Lynnwood Washington
    Appreciate the offer! Ran down to lowes and found a bolt that fits
  12. May 7, 2020 at 9:56 PM
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    For me... no more rev hang. I’m noticing a little more torque coming on down low and I ran it to red line for the first time and noticed it’s at about 5900 now. My truck is for off road use only and had the air pump light turned off so when I do my intake spacer and cam gears it can be removed and put next to my sway bar in the junk pile.As far as O my god my truck has insane power no but definitely noticeable say rolling on the gas say in 3rd cruising at 35 You can feel it picking up earlier. He set the throttle response about where they should have set it from the factory. I left in my petal commander so driving on the highway and freeway I get instant response. I like to turn down the response driving snow on steep roads so I don’t break loose or have the trac control kick on if I’m trying to use momentum to make up up.... some times I forgot to disable the trac control and it will absolutely fuck you in a bad spot when it cuts the power and my shit comes to a stop.
  13. May 8, 2020 at 8:28 AM
    TimberTiger
    TimberTiger Get Western! ... ig @tcave87
    Tanner
    Arlington, Wa
    2014 DCSB Trd off road , 2002 Ext Cab Trd
    2014 DCSB: nitro 4.30 gears, Eaton/Harrop front locker, Bilstein 6112's w/ 650#, Camburg ball joint UCA's, Marlin cam tab gussets, Wheelers superbumps, Deaver U402 stage 2 leaves, bilstein b110's, u bolt flip, Archive hammer hangers, ADV weld co hybrid sliders, ADV weld co bed rack or Leer 180 w/ windoors, full RCI skids, SCS stealth 6, 35x10.5 kenda RT, ATH fab HC rear bumper, US offroad stealth front winch bumper, Smittybuilt x20 10k winch, ARB simpson III rtt, plenty of dents and scratches Now Sold 2002 TRD ext cab: 06 TRD Tundra coils, tundra 5100s, wheelers HD 3 leaf AAL, rear 5100s, ARB front bumper, SkidRow front skid, Leer commercial cap with windoors, 285/75r16 Kelly Safari TSR
    @Shadowhunter I hate that you have to stop to turn the trac off, cause i forget all the time too
    Eazy.E and Dirk Diggler like this.
  14. May 8, 2020 at 11:17 AM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Almost got my ass good a few weeks ago in snow. Went 8 Miles with that shit hovering over my head
  15. May 8, 2020 at 11:28 AM
    JDAM
    JDAM Well-Known Member
    J
    Worshington
    12 DCSB TRD OR
    any chainsaw experts here help me find a used saw? probably at least 25 or 28" and up to 32" max.
    I know this in an older Stihl but what do you think?
  16. May 8, 2020 at 11:49 AM
    TimberTiger
    Tanner
    Arlington, Wa
    i’m glad it turns off automatically in 4low though
    Dirk Diggler[QUOTED] likes this.
  17. May 8, 2020 at 11:50 AM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    Yeah but I was 4 hi and if I stopped I was gonna be screwed
    TimberTiger[QUOTED] likes this.
  18. May 8, 2020 at 12:05 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    FJ case swap takes care of that. I swapped 4wd lo and 4x4 sensors. Now when i shift into 4wd high it thinks it’s in 4wd lo and it turns off the traction control.
    And you can still be in 2wd if you do the two sticks :cool:
  19. May 8, 2020 at 12:13 PM
    vorkuta775
    vorkuta775 Well-Known Member
    Texas
    tesla truck
    id ask him for a few more photos, see what it looks like after taking the bar and cover off, look at the plug, start it see how it runs. I ran a STIHL44 as my project saw when cutting line in my fire days. Good saws, but for 500 You could pony up and try to find a used 460. What are you mainly using it for? firewood? or doing projects and shit?
  20. May 8, 2020 at 12:15 PM
    vorkuta775
    Texas
    tesla truck
    anyone gonna go and play this weekend? My lift is going on this weekend/alignment, I dont know this area. Id be willing to tag along with any local who is gonna go out
    ready6delta likes this.
