NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Jun 2, 2020 at 10:08 AM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    Walker valley ORV
    ready6delta and rlx02[QUOTED] like this.
  2. Jun 2, 2020 at 10:50 AM
    BZ4X4
    BZ4X4 Well-Known Member
    Brian
    2018 Blue Tacoma TRD Off-Road
    I took a trip up to Walker Valley in late December just to look around and was confused by the closed gates. Do they open them up in the summer, or do navigate around them?
  3. Jun 2, 2020 at 10:52 AM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    navigate around them. they are "gate keepers" to make sure your vehicle can actually do the trail. Though sometimes the gate keepers are harder then most of the trails
    ready6delta and BZ4X4[QUOTED] like this.
  4. Jun 2, 2020 at 10:56 AM
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    people used to steal cars and take them up there and beat them till they broke and abandon them. Keeps the riff raff out.
  5. Jun 2, 2020 at 11:09 AM
    BZ4X4
    Brian
    this is why we can't have nice things!
    ready6delta and cosmicfires like this.
  6. Jun 2, 2020 at 11:27 AM
    SaphiraTaco
    SaphiraTaco Well-Known Member
    Sean
    Seattle WA
    2013 DCLB TRD Sport
    About halfway done...
    More details, please...
    bobsuruncle likes this.
  7. Jun 2, 2020 at 11:32 AM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    I know at other orv places like Evans Creek, they make the trail entrances narrow to keep the guys with buggies on full size/width axles and 44" boggers/pitbulls out. They tend to have a big power plant to turn that bigger running gear and in the process can make a easy to moderate difficulty trail impassable to anyone that doesn't have a built rig.
    ready6delta likes this.
  8. Jun 2, 2020 at 1:09 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    procharger and the Tacoma kit. Supposed to be able to get around 45% more HP out of it. Supposed to work with most after market winches and bumpers too
    bobsuruncle and TimberTiger like this.
  9. Jun 2, 2020 at 1:27 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    390hp:eek:
    im kinda regretting the 5.29's
  10. Jun 2, 2020 at 1:44 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    The 390hp is the 4runner as they have the dual VVT-i 1GR-FE (stock is 270 for them) vs our regular VVT-i 1GR.
    Plus Im doubting the 390 is an exact thing as its probably based of the crank HP and they are just comparing wheel HP %. People like numbers so taking the 270hp it is listed as and comparing it to the wheel HP wouldnt be as impressive as doing the numbers to "convert" to crank HP.
    They have one tacoma review with Dyno...im sure it was the test truck. Pre RWHP was 225. After was 311 RWHP.
    Im sure once the tuners get hands on a unit they can get more out of it.
    The one thing Im not a fan of it they use a fuel pump booster. Makes install a bit simplier as you dont have to swap fuel pumps but...I'd rather just drop the tank and put in a bigger pump
  11. Jun 2, 2020 at 2:03 PM
    Louisd75
    Louisd75 Well-Known Member
    Northwest Washington
    '02 Xtra Cab, '15 DCSB
    I wonder if moisture is an issue with the Procharger intercooler. I read through the manual and it doesn't address what happens to the water that condenses out during the intercooling process, nor do they mention it in any of their website info.
  12. Jun 2, 2020 at 2:06 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    I'm actually kinda surprised at that stock NA nunber. Only ~10hp below advertised. :wink:
  13. Jun 2, 2020 at 2:23 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    You mean in the sense water will form inside the charge pipes and bring moisture through the intake?
    Yeah i was a bit surprised by that. They dont list any other mods for drive train outside of 31.5" tires. But always hard to know. Be nice once either some tacoma guys or 4runner guys get them and can get some dyno numbers. Be interesting to see it along with some headers and y pipe.
    bobsuruncle[QUOTED] likes this.
  14. Jun 2, 2020 at 2:58 PM
    Louisd75
    Yeah. I have no experience with intercooling on small systems like this. The engine of the ship that I work on is 25,000hp. We've got two turbos running about 3 bar of boost. Compressed air coming out of the turbo and into the intercooler is running about 160*C. The intercooler brings it down to about 30*C. In the process the air temp typically drops below the dew point for the pressure that we're running at and we end up with moisture. The intercoolers have a set of plates that force the air to make 90* changes in direction. Water hits the plates and runs downwards where it is collected in drains and dumps into a storage tank. We've had issues with the drains, which led to water carrying over in the intake. In our case, it caused scuffing in the liners which lead to broken piston rings and excessive wear as it washed the lubricant off. FWIW, in the right circumstance I've seen the engine make 20 tons of water a day out of the drains.
    Based off that experience, I'd be leery of putting an intercooler system on a vehicle without a better understanding of how they manage the moisture that will inevitably be created.
  15. Jun 2, 2020 at 3:10 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Can confirm it is a tight fit on where we entered
  16. Jun 2, 2020 at 3:36 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    :eek:
    :goingcrazy:
    My buddies old sti impreza was nicknamed the 2baru. I wonder why he blew 2 motors and decided to tone it down on the 3rd motor. :anonymous:
  17. Jun 2, 2020 at 3:54 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    You’ll get more water in the system via a snorkel then the pro charger System.
    You’re talking about insanely large volume of heated air that’s being drastically cooled down by what I assume is a water to air intercooler
    Louisd75[QUOTED] likes this.
  18. Jun 2, 2020 at 4:12 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Not an issue in the automotive side of things. Much smaller volumes of air being used. Any moisture that is generated is just fine to go into the intake.
    These systems of turbo charger/procharger/supercharger to intercooler to intake are incredibly common in the boosted automotive world. Pretty much every diesel truck uses it plus most cars.
    ready6delta and Louisd75[QUOTED] like this.
  19. Jun 2, 2020 at 4:21 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    Shit, @White lightning boosted ADDS moisture in the form of methanol to his supercharger setup. Gotta keep that fuel cool.
    Louisd75 likes this.
  20. Jun 2, 2020 at 4:42 PM
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    true. dual stage. im asking more than double duty of this gen 5 blower. methanol/ water injection can have benefits on n/a motors. trd s/c makes 6lbs of boost peak at sea-lvl. im closing in on 12psi. compressing air makes heat. lots. alcohol and water clean and cool. https://youtu.be/XJzLTxVal6A
    e- load 285's rolling start to 80mph on the ramp.
