NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Jun 5, 2020 at 6:18 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    brake cleaner probably part of the reason it’s in rough shape
    ready6delta likes this.
  2. Jun 5, 2020 at 7:10 PM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
  3. Jun 5, 2020 at 7:55 PM
    twalchlii1
    twalchlii1 Tacotraitor
    Tom
    Wa
    2018 GC Trailhawk
    Are floor mats a mod?
    why did that sound so much like the last time I had sex?:anonymous:
  4. Jun 5, 2020 at 7:58 PM
    twalchlii1
    Tom
    Wa
    2018 GC Trailhawk
    It will likely need to be cleaned and rebuilt.
  5. Jun 5, 2020 at 8:05 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    You wouldn't be selling that 1" body lift if you knew how much easier life is with it on the truck and finishing a job with unscathed hands. :anonymous:
    Are the manual transmissions bulkier that the automatic? I don't feel like I had a hard time getting the top bolts before, but they're 10x easier now. I go in through the wheel well and remove the intermediate steering shaft on the driver's side to make it easier there.
  6. Jun 5, 2020 at 9:12 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    I got small hands. I’m not a really big dood at all so yeah. Biggest problem I ha e is my damn t-Rex arms
    I can actually get those bolts out from the top. Not sure if it’s because of the supercharger but I can do it. If I have 2 people it’s easy. On to guide the socket into the bolts and the other underneath with impact to remove and it’s really easy.
    bobsuruncle[QUOTED] likes this.
  7. Jun 5, 2020 at 9:54 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    Oh supercharger. Yeah 2 people is less stressful when one holds the socket in place and the other breaks it loose. I can't remember how many times I've had all the blood run out of my arms, a good sign it's time for a beer break, and get so frustrated just trying to get a good purchase on the bolt head. Going in from the top of the engine isnt bad at all if you have a flex head ratchet with about a 18" handle.
  8. Jun 5, 2020 at 10:05 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    amateurs
  9. Jun 5, 2020 at 10:11 PM
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    Well in my defense I tried to get them
    without dropping the cross membero_O
    bobsuruncle likes this.
  10. Jun 5, 2020 at 10:14 PM
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    Hopefully tomorrow I get to put them back in. 44DFF7D0-BE9B-43E4-94FE-CBF7650DB0A8.jpg 5CBCB6E2-9F86-42EF-A44D-E5F31AA5AD01.jpg BEA95349-D3A7-4334-AE3F-9378AAEE8A63.jpg
    cosmicfires and bobsuruncle like this.
  11. Jun 5, 2020 at 10:20 PM
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    I need to hit the research cave and make sure I get my bleed line in the right spot on the hydro before I tighten everything down and oriented.
  12. Jun 6, 2020 at 6:53 AM
    wrmathis
    Bonaire, GA
    parts and stuff
    once the socket is on the bolt head there is amazingly a good amount of room for a ratchet when going from the top.
  13. Jun 6, 2020 at 6:59 AM
    Apollo14
    Apollo14 EEF Brand Ambassador
    Jonathan
    Vail, CO
    2018 Cement Taco TRDOR DCSB
    :rofl:
  14. Jun 6, 2020 at 7:07 AM
    Apollo14
    Jonathan
    Vail, CO
    Went out to Friday Harbor, WA last week. Still plenty of good spots on the ferry! Had the entire port side to myself.
    :anonymous:
    SilverYeti, ready6delta, yeos and 8 others like this.
  15. Jun 6, 2020 at 7:44 AM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    Why is it such a pain in the dick to get the tcase shifter offset right? :annoyed::bananadead:
    I tack it, check it, adjust, tack check bingo. Weld it up put it back in and then it like I'm back to square one again. I tried to anticipate the exaggerated pattern since it's not moving in a J pattern directly above where the shifter normally would be. I'm either over thinking it or :notsure:.
    That nut just above the green tcase is currently in the 4hi position and to the right as if you were getting ready to proceed forward to neutral and then 4lo.
  16. Jun 6, 2020 at 7:57 AM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    Nice thing about running a RTT on a shell, always get to go down the middle of the boat
  17. Jun 6, 2020 at 10:42 AM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    I posted This on ARFCOM, might as well here.
    has anyone had ACL surgery and had the retaining screw back out?
  18. Jun 6, 2020 at 10:43 AM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Holy shit that sounds horrible
  19. Jun 6, 2020 at 11:13 AM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    There’s no pain, unless i hit it on something, the skins sensitive because the metal has no give to it. Same thing with my collar bone plate.
    Mine is kinda like this one
  20. Jun 6, 2020 at 11:15 AM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    Seeing as you're a mechanic, and knee pads are probably used often, probably only a matter of time before you kneel down to check out what heat soaked shit show you're working with and BAM! on the ground you go
    Usethe2nd[QUOTED] likes this.
