NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Feb 12, 2014 at 5:11 PM
    #5661
    uncleART
    uncleART Well-Known Member
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    3" Toytec ULK 285/75-16 BFG KO2 Verge FN Wheels DeBadged, Toyota Bedmat, Window tint 30%, DeFlapped the front, Bilstein 5100s, Toytec coil overs, Dakar leafs, LR UCAs, SwayBar relocate, TRD Offroad tow hook, RotoPax, DeFlapped the rear, Tailgate mod, CBI receiver shackle w/ Bolt Hitch Pin, BFG KO2 285/75-16, FNWheels Verge, Weathertech Floor Liners, Spare tire mod, UWS toolbox with Bolt Latch Retrofit, Rear Diff vent relocated, Blacked-out grill emblem, Toolbox Bedrail mod, Trailer Plug relocated, ECGS bushing, Redline Hood Struts, Leer 100XR, C4 Fabrication Lo-Pro Bumper, Relentless Fab Frame Reinforcements, Warn 9.5XP-S Winch, Baja Designs S8 20" Lighbar, Off-Grid Engineering Dual Battery Tray, Odessey 35-PC1400 Batteries, BlueSea ML-ACR
    :wave: dclb FTW :thumbsup:
  2. Feb 12, 2014 at 5:12 PM
    #5662
    tacoma2014
    tacoma2014 Well-Known Member
    Brandon
    Bellingham,wa
    2014 Sr5 doublecab longbox
    Thanks, not wheelin in it yet till the newness wears off though! haha:D But still down to hang out and BS:cool:
  3. Feb 12, 2014 at 5:12 PM
    #5663
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Twisted? This is tame compared to the Oregon Washington BS Thread. :D
    Welcome, Brandon!
  4. Feb 12, 2014 at 5:14 PM
    #5664
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    You at least need to pin stripe it before you get 2,000 miles on it.
  5. Feb 12, 2014 at 5:20 PM
    #5665
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
  6. Feb 12, 2014 at 5:24 PM
    #5666
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    True. And we are very tame compared to the retarded NJ area
  7. Feb 12, 2014 at 5:29 PM
    #5667
    tacoma2014
    Brandon
    Bellingham,wa
    HAHA yeah first its get rid of the gay tires that come on it and go for some 265/70/16 duratracks then canopy. also eyeballin some skid plates.
  8. Feb 12, 2014 at 7:21 PM
    #5668
    Benson X
    Benson X [OP] My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    Here are the (rough) dimensions on mine. I tried to get as accurate as possible, but it's not an easy area to work in :p
    I'm out for a while :pout:
    I can ride-along though :thumbsup:
    Welcome Brandon!
    I see you've joined the ranks of the MGM DC/LB crew :)
    ..and don't worry, after you get your first pinstripes or ding/dent while wheeling, it's much easier to "let-go" and have more fun after that...but you should not take advice from me :eek:
  9. Feb 12, 2014 at 7:45 PM
    #5669
    InTheRough
    InTheRough Well-Known Member
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    Oh man, I really don't know if it will work. Mine measure out to be just over .75" (not quite 1") and just over 2.5" (even thought those aren't as important). Thanks for taking the time to measure. I might just wait for the next meet to take a look at it.
  10. Feb 12, 2014 at 7:47 PM
    #5670
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Sounds good man.
    The (2) holes are definitely around 2.25" apart, the key cam might be slightly smaller than 1", but like you said, you can scope it out at the next meet if I'm there :thumbsup:
  11. Feb 13, 2014 at 8:06 AM
    #5671
    stikle
    stikle Well-Known Member
    Seth
    The Sovereign State of Eastern Oregon
    1997 LX Xtracab 4x4 V6 3.4L
    Eh, see my Build Thread sig link. Too many mods to list.
    Would you fix your Yoda already? There can't be much wrong with it, maybe just couple hours of work MAX. You slacker.
    :D
  12. Feb 13, 2014 at 10:56 AM
    #5672
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    Wiring issue on the winch? On the main power lines going from the battery to the winch, I call bullshit. I personally cut off the factory crimps and put it into the gold plated replacement pieces you put on your battery terminals. Pretty sure I tightened down the set screws as well. The power wires go to that harness which is pretty hard to fuck up plugging that in right.
    Have you checked the hand held controller?
  13. Feb 13, 2014 at 11:18 AM
    #5673
    penguins_cc
    Will
    Bellevue, WA
    I did check the controller. Thought that was the issue and got a replacement from Warn but the replacement failed right away also.
    It could actually be at the battery terminal, although I'm not sure. Reason is that R/R the winch cable at the battery terminals got things working again - temporarily. Otherwise, whenever I push the controller, the solenoid makes a click and nothing else happens. It seems to work about 1/3 of the time.
  14. Feb 13, 2014 at 12:10 PM
    #5674
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    I know that location! Liberty 319?
    We though "what kinda cliff is there that requires a warning?"
    We found out. Had a touch of vertigo at that moment...
    When we looked with the binoculars, there is a memorial at the bottom.
    I will look for a photo...
  15. Feb 13, 2014 at 12:43 PM
    #5675
    penguins_cc
    Will
    Bellevue, WA
    Whereabouts in Newcastle do you live, Ben? I'm right on the border of Newcastle/Renton/Bellevue. I have a Bellevue address, but I'm in the Renton school district and Newcastle is a couple blocks away.
  16. Feb 13, 2014 at 1:54 PM
    #5676
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    I am behind QFC.
    Newcastle address, Renton Zip, Issaquah School District.
    I almost purchased a house on SE60th that would have been the Bellevue school district but SE 60th is a well traveled road, so we passed on that one.
    There is a murdered out 4Runner and a murdered out Tacoma that I see near every day on Sunset/Coal Creek - not sure who it is - and then the guy with a pavement princessed FJ at Yea's Wok...
  17. Feb 13, 2014 at 2:36 PM
    #5677
    penguins_cc
    Will
    Bellevue, WA
    Nice, my folks live in China Creek behind the QFC. I live off SE 64th, a couple blocks north of Hazlewood. Look forward to meeting up sometime!
  18. Feb 13, 2014 at 3:06 PM
    #5678
    InTheRough
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    Does anyone have a need for a tailgate liner? Its in decent shape (no cracks) but has scratches on it. If not I will be cutting into it to use the material for projects.
  19. Feb 13, 2014 at 9:52 PM
    #5679
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Lol, I've been bustin my ass today.
    - Got the carpet back, and 90% of the interior back in.
    - Cleaned and Febreezed all the seats, carpet, and headliner again (trying to get rid of the smoke smell :()
    - Got my brake light tinted and ready to go.
    - Took off all the door panels and cleaned the shit out of them
    - Fixed one of my mirrors (the plastic that hold the mirror glass came unscrewed)
    - Derped Chickenmungas old chrome bumper and currently transferring everything to it and getting ready to put it back on.
  20. Feb 13, 2014 at 9:58 PM
    #5680
    penguins_cc
    Will
    Bellevue, WA
    Smoke smell is bad, but IIRC Tahuya mud is pretty rank smelling when it dries.
