NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Jul 1, 2020 at 5:29 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    Back when I was a wildland firefighter we had a 7' wide cedar that got struck by lightning that had to come down. 088 with a 72" bar still took a long ass time, but that was neat. We had to spike and chain the whole thing afterwards to keep the tree poachers away
    ready6delta and razhick4x4 like this.
  2. Jul 1, 2020 at 5:30 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    My good friends dad carrying a 357 in his fanny pack.hilarious by the way
    ready6delta likes this.
  3. Jul 1, 2020 at 5:35 PM
    Wyckedan
    Dan
    Woodinville WA
    Joe Rogan not only is big proponent of them, he sells a really nice one. Hard to argue with the convenience/functionality of it, but got damn you can't make it look good
  4. Jul 1, 2020 at 5:37 PM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    Fanny packs are under rated and incredibly handy. I have one for when I'm playing in the woods dressed as a bush.
    ready6delta and TimberTiger like this.
  5. Jul 1, 2020 at 5:48 PM
    Wyckedan
    Dan
    Woodinville WA
    I have a little pouch I use for the same, bow release, calls, etc. It's borderline a fanny pack but removable
  6. Jul 1, 2020 at 6:01 PM
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    I want one of those old dinosaurs to hang up in the shop.
  7. Jul 1, 2020 at 6:04 PM
    twalchlii1
    twalchlii1 Tacotraitor
    Tom
    Wa
    2018 GC Trailhawk
    Are floor mats a mod?
    I have 2 :anonymous:
  8. Jul 1, 2020 at 6:49 PM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    If it is borderline it's still a fanny pack
    ready6delta and PNW/TRD Steve like this.
  9. Jul 1, 2020 at 8:17 PM
    Tacobello
    Tacobello Well-Known Member
    2018 Magnetic Gray Metallic TRD OR DCSB
    Pocket snake shee shi shaaa
    ready6delta and Dirk Diggler like this.
  10. Jul 1, 2020 at 8:58 PM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    Pocket full of sand
  11. Jul 1, 2020 at 9:13 PM
    twalchlii1
    Tom
    Wa
    2018 GC Trailhawk
    add black belt in phillipino and Korean weapons .
  12. Jul 1, 2020 at 10:58 PM
    SaphiraTaco
    SaphiraTaco Well-Known Member
    Sean
    Seattle WA
    2013 DCLB TRD Sport
    About halfway done...
    So while working on last-minute projects before a trip I broke an ABS wire.
    The wire pulled out of the connector plug.
    Does anyone have any ideas on how to de-pin this plug?
    I have tried jamming paper clips and needles next to the broken contact...
  13. Jul 1, 2020 at 11:43 PM
    Eazy.E
    Eazy.E Big gulps huh?!
    Erik
    Snohomish, Wa
    06 DCLB TRD Sport Trail Whale
    I was a little bummed when they changed the cans from the old cyclones to the rectangle, doesn’t fit in my pack as well lol
  14. Jul 2, 2020 at 12:32 AM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Pull that white plastic piece out with some small needle nose pliers and the retention barb is exposed. Using a small rigid poker press the barb down and gently pull the wire out from the rear of the plug. I've got a few extra misc plugs with pig tails if you need to splice in a fix. I had to replace the rear abs harness on the axle housing and kept it for if something like this came up.
  15. Jul 2, 2020 at 12:33 AM
    PNW/TRD Steve
    PNW/TRD Steve Well-Known Member
    WA
    2012 DCSB TRD
    ImMrYo Rear view mirror lift bracket. Changed out mud flaps. Salex glove box organizer. OEM Ashtray (cup). AVS Step Shields. 16x8 SCS F5 Matte Jet Black. 265/75 16 Cooper St Maxx. OME Bp-51s. U.S. Offroad Winch Mount (in process) Smittybuilt x20 12k synthetic winch (in process) More....
    I've used the WeatherPak plugs and there are a couple of 'ears/tabs' on the terminal. The removal tool slips over the contact end of the terminal and then the wire is pulled from the back.
    Your plug looks like the release is above the contact and would require a screwdriver shaped and strength tool as well as a pull on the wire end via needle nose pliers.
    bobsuruncle likes this.
  16. Jul 2, 2020 at 12:34 AM
    PNW/TRD Steve
    WA
    2012 DCSB TRD
    Missed that. The white piece in the middle is a retention tab.
  17. Jul 2, 2020 at 8:45 AM
    SaphiraTaco
    Sean
    Seattle WA
    2013 DCLB TRD Sport
    Thanks so much. I was about to just cut off the plug and install a different water rated plug. Now to see if I can solder to this crimped pin...
  18. Jul 2, 2020 at 10:24 AM
    SaphiraTaco
    Sean
    Seattle WA
    2013 DCLB TRD Sport
    Success!! Tested wires with Multi meter got good connections. Best part is ABS light if off. I thought for sure I’d have to reset something to make the light go away.
  19. Jul 2, 2020 at 10:41 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Would not splice ABS wires. In that exposed location solder and heat shrink for sure or you’ll be back soon
  20. Jul 2, 2020 at 11:25 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    meh, depends on the splice. I use splices from work that are used on a $35 million dollar helicopter. ill take my chances. especially since these are subjected to pressure washers, hydraulic fluid, and god knows what else the crewchiefs do to the helicopter when no one is looking
    ready6delta and bobsuruncle like this.
