NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Jul 7, 2020 at 6:05 AM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    there’s still snow? Gallagher had light patches two weeks ago
  2. Jul 7, 2020 at 6:27 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    @12TRDTacoma did this swap. dont think his has operable paddle shifting though.
  3. Jul 7, 2020 at 7:04 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Paddle shifters are a no as they require a full controller that our transmissions do not have and is a little too expensive and complex to do.
    I did do this mod some time ago. Good luck studying wiring diagrams. It's a shitshow. Especially if you own a 12. I can get every button working for you except the back, left, right, and DISP buttons unless you have an OE radio.
    This is NOT a straight across swap @bobsuruncle, so be prepared for some heartache. I will get back to you on this later today as I have work all day until 5.
  4. Jul 7, 2020 at 8:03 AM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    Bob’s got that 4Runner tranny and beers
    12TRDTacoma[QUOTED] likes this.
  5. Jul 7, 2020 at 8:20 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Lol. Makes sense. He can keep the beers though. More for him. :p
  6. Jul 7, 2020 at 8:40 AM
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
    18 LX570 on 35s, 06 Tundra DC beater
    Negative, I got on 5 north SAC and took that 800 miles to Renton
  7. Jul 7, 2020 at 8:44 AM
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
    I didn't take many, and most are of the cat. I started a new job yesterday and haven't had as much time to fuck around as I have in the past 4 months, so I haven't had a chance to go through the images I took.
    ready6delta and twalchlii1 like this.
  8. Jul 7, 2020 at 9:11 AM
    Eazy.E
    Eazy.E Big gulps huh?!
    Erik
    Snohomish, Wa
    06 DCLB TRD Sport Trail Whale
    I ssure am, grew up there. I’ve hiked in and out of there on back country trips in the winter and have a few buddies that snowmobile in to backside from the Nordic center once it’s open but I never really gave much thought to driving back there, makes perfect sense!
    The snowpack was pretty good this year and the temps are low so I’m sure it’s sticking around.
    how far did you say you got? You must be taking the cat track rout up? Is there a fs road that gets to the top in the summer?
  9. Jul 7, 2020 at 9:25 AM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    lol they are for him, With beers Bob can accomplish great and terrible things
  10. Jul 7, 2020 at 9:45 AM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Yeah, the few spare minutes I had to look at things last night left me planning to de-pin and get custom with things. I'm planning to do some wire continuity testing on each switch to get an idea of what's what before it heads back into the dash making my own wiring diagram essentially. Definitely have a wiring spaghetti hangover after looking over I don't know how many wiring diagrams last night, either from t4r/tundra with S mode, and then Corolla and Tacoma steering wheel controls, and common color use. :goingcrazy:
    I initially thought the paddles wouldn't be too difficult, but knew it wasn't exactly going to be plug and play. Even though I have a 2012 t4r trans in my truck, I don't have a way to easily take control over the solenoids, and my ECU has NFC what to do. Leaving me with a few options that are not very high on the success side of things IMO.
    1: Use a t4r/tundra ECU as a piggyback TCU for the S mode portion of things, but that gets murky quick when that ECU is going to be wanting feedback from sensors that are being used elsewhere. :Trainwreck:
    2: Microsquirt gpio board and set it up so that when I move from D/5 - 4 with the shifter it would essentially simulate the t4r/tundras operation of S mode and take over the sequential shift duties triggering the solenoids for the requested shift.
    I don't see a problem being able to trigger/actuate the shift solenoids, but there needs to be some sort of intelligent device to know what gear the transmission is currently in and which solenoids are on/off, so when a up or down shift is signaled it knows what to do to make it happen. I'd be willing to spend the few hundred more bucks for the MS TCU controller and make this work vs spending $2k for something like the computech and it doesn't even look factory.
    I'm not expecting this to happen over a weekend, but I'll be brainstorming when my ADD allows it and trying not to overthink it. I mean it's not rocket science, but it seems like it is after looking at the Corolla wiring diagrams and it looks like it uses CAN to control the shifting in the manumatics/CVTi-S transmissions. :bananadead:
  11. Jul 7, 2020 at 9:53 AM
    Filip38507
    Filip38507 Well-Known Member
    Filip
    Lynnwood Washington
    2019 Tacoma TRD Offroad
    Yeah there’s a cat track leading all the way up! Theres a snow patch pretty low down on the track you have to cross but after that it’s clear until about half way up where there is another good size patch we didn’t attempt going over
    Eazy.E[QUOTED] likes this.
  12. Jul 7, 2020 at 9:56 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You're on your own with the paddle shifters brother. Hahaha. That's requires too much brain energy on my part to be of any help with that.
    bobsuruncle[QUOTED] likes this.
  13. Jul 7, 2020 at 10:07 AM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    @Usethe2nd you think Clint would sell me the ECU from Ashley's 4runner? :anonymous::rofl:
    Hell, I'd only need to "borrow" it to run a few tests.
  14. Jul 7, 2020 at 10:28 AM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    Oh I'm used to being on my own and tinkering with ideas. When friends ask me what I'm doing, and I start to explain, about right after I say wiring diagrams and de-pining blah blah not factory, but this car has it and it swaps into/fits my truck, they don't want to hear anymore lol.
    Any info you would like to share regarding the steering wheel swap would be appreciated. When you have time. :thumbsup:
  15. Jul 7, 2020 at 10:36 AM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Its always fun doing wiring on different vintage vehicles. Wiring on the FJ40...simple. Move up to the MR2...ehhh bit more complicated but not bad. Our trucks....lots more but still not toooo bad. New stuff with their million different sensors...f that
  16. Jul 7, 2020 at 10:43 AM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    Yay multiplexing :bananadance::bananadead::annoyed:
  17. Jul 7, 2020 at 10:58 AM
    Eazy.E
    Erik
    Snohomish, Wa
    sounds like a good time!
  18. Jul 7, 2020 at 11:57 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Today I'm rewiring connectors on a Dodge Dakota. I hate wiring as of lately. The connectors are so finnicky, but hey this is what I do. I'll let you know what I got when I get a chance here. :)
  19. Jul 7, 2020 at 12:41 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    I gotta ask, why bother with the paddle shifters? Yeah it's cool to have something super unique. But if somebody took a short bed Tacoma and added 2" to the bed and it looked factory, you'd appreciate how much work it took, but does it really make any sense? Maybe if you had a turbo I'd get it.... hint hint
  20. Jul 7, 2020 at 1:37 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    id love paddle shifters. yes, with f/i i could see it being entertaining.
