NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Aug 12, 2020 at 10:12 AM
    Greddy
    Greddy Would you eat the moon if it were made of ribs?
    Cam
    Bonney Lake, WA
    It's a Tacoma, white n black, DCLB
    Front & Rear HC Bumper with Swing Out, Full Skids, Icon CO's and UCA's, Dakar w/AAL, Icon Rear Shocks and U-bolt flip, w/Superbumps. 17" XD Wheels, 34" BFG KM3s, CB/Ham Radio, 10% Tint, Snugtop, WeatherTech Mats and Deflectors, Rigid Fog Lights, UltraGauge, TRD Seatcovers, On-Board CO2 and 20L fuel. Roof Top Tent. AirFlow Snork, smittybilt winch, 20" light bar.
    Yeah bro I'm in no hurry, that would be awesome!
    tacotunner06[QUOTED] likes this.
  2. Aug 12, 2020 at 11:25 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Unrelated but since you asked about a larger trans cooler earlier I forgot to mention that you should then consider bypassing the radiator. That way no internal failure (from overheating or off-road shenanigans) can contaminate your ATF and wreck your transmission
    Greddy[QUOTED] likes this.
  3. Aug 12, 2020 at 12:58 PM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    When you can hobble up here. Between the hours of 7am-3pm or anytime really since I have keys
  4. Aug 12, 2020 at 1:19 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    For me it was keeping the tires on the ground. Tires on the ground = more traction. The ass end flexes way better with the shackle flip than the factory configuration. I noticed that I would be lifting a tire in the rear in situations that with the flip, it allowed the tire to stay on the ground. Ultimately it allows for more down travel, but you need to have the bump stops set up correctly to prevent the shock from bottoming out and minimize leaf inversion. Sacrifice up travel for down travel. I don't go bombing through the desert at 80mph so I'm fine with a little less up travel for down travel.
  5. Aug 12, 2020 at 1:32 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Yeah I think that's the only negatives I read is that the leafs can invert and the shocks will bottom out if you dont put in the bump stops. Longer shackles might need limiting straps on the shocks too. I also read that it rides worse on the street? I too am not bombing down desert roads so I don't have a need for much more up travel. I don't carry any weight in the bed either except for home depot and camping trips.
  6. Aug 12, 2020 at 1:59 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    Yeah the ride is a bit different, but if you've driven any of the older Toyota pickups pre 2004 it's not any different. I haven't found the bottom of my shocks yet, so I haven't need to strap the axle, the shackle so far has been the limit strap. I definitely had to setup the bumps to keep the shocks from topping out.
    Oh I also triangulated the rear shocks inboard and moved them higher, so I'm running a longer shock too
    rlx02[QUOTED] and TimberTiger like this.
  7. Aug 12, 2020 at 2:37 PM
    TireFire
    Olympic Peninsula
    You have bottoming our and topping out backwards I believe.
    I hate shackle flips and I wouldn’t want to sacrifice any uptravel because these trucks already have too little of it. Shackle flip will also cause tour leaves to invert much more which will cause them to wear out quick
  8. Aug 12, 2020 at 2:50 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    Yeah you're right I did have that backwards. Top out is when the shock completely extends and tops out at the top of the shock body acting like a limit strap, bottom out would be when you fully compress the shock and it quickly becomes a bump stop.
    If you setup the shackle mount correctly, shackle inversion shouldn't be an issue. With shorter leaf packs like the dakars, it will want to pull that shackle forward to invert. Moving the mount an inch or so forward fixed that for me.
  9. Aug 12, 2020 at 3:53 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    Got some new goodies for the Lexus. Got rid of the wood panels next to the radio. Installed pieces from the Prado. Mainly because the tabs that hold them to the dash were broken and they stuck up bout a 1/4” above the dash. Also brand new ones from Lexus are $1k each. I got both sides from eBay shipped from uae in 5 days for $174. And they are genuine Toyota parts
    A90648BE-3792-4B63-BC62-6DEDFDE37DEC.jpg DEA94D20-E782-4B47-97B5-F49FC03EFAD2.jpg
  10. Aug 12, 2020 at 4:16 PM
    utroda
    utroda Well-Known Member
    Jared
    PNW
    06 DCSB SR5 4x4
    I think the big thing is so many people here still DD/weekend their trucks and a straight flip sucks. The stock position on the frame with a flip has terrible geometry. If you do a flip it’s better to move the hanger forward and check your angles. Yes you loose a bit of bump travel and gain droop, which means you can kinda get tippy as one side will droop further than you can stuff the other. I personally run a flip kit, but it’s not just a bolt on thing. It takes a good day or two to cycle and set it up, but the kicker is most leaf packs are made for inverted hangers in stock locations. So it’s better to build your own bastard pack or run 63s than it is to buy a pack off the shelves that fit a taco. This is why so many people complain about vibes after flips because their pinion angles become shitty. Honestly both are a good option it just depends how much time you want to put in it.
  11. Aug 12, 2020 at 7:21 PM
    SilverYeti
    SilverYeti Well-Known Member
    2010 Silver Tacoma TRD Offroad
    Pelfreybilt sliders ARB bumper WARN winch
    Quiet this year for meets. Hit me up if your headed up north. A5A29533-4D5B-4E62-97B3-162718FFC189.jpgD6A02240-CBA0-4957-9774-EBDC1A379816.jpgA6FA8AE5-E66A-4561-AD84-BE48AFE06302.jpg
    Also went back to the future b cause COVID and not a huge fan of these Hankooks lol.
  12. Aug 12, 2020 at 7:47 PM
    utroda
    Jared
    PNW
    06 DCSB SR5 4x4
    Anyone here have a BFF Rear with swing out remember if this the spindle cap is treaded or just pushed on.
    twalchlii1 likes this.
  13. Aug 12, 2020 at 8:03 PM
    twalchlii1
    twalchlii1 Tacotraitor
    Tom
    Wa
    2018 GC Trailhawk
    Are floor mats a mod?
    mine was threaded so I put a shop towel over it and used a pair of big channel locks to unscrew. Heated it with a heat gun first
  14. Aug 12, 2020 at 8:08 PM
    utroda
    Jared
    PNW
    06 DCSB SR5 4x4
    Thanks! I started to hit it off then was like wait I think this was threaded lol.
    rlx02 likes this.
  15. Aug 12, 2020 at 8:59 PM
    06TXED
    06TXED Well-Known Member
    Tony
    Aurora CO
    2023 DCSB MGM TRD OR 4x4
    I had the factory installed tow package cooler. I upgraded to a Hayden 677 ATF temps have been consistently lower. Could go up to the next size, but so far happy with the 677. Used existing bolts on the install.
  16. Aug 12, 2020 at 9:31 PM
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    this guy outta no where, but been a member since 2009..... :hattip:
  17. Aug 12, 2020 at 10:28 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    1st gen hotness.... with the Hayden 677
  18. Aug 12, 2020 at 11:09 PM
    06TXED
    Tony
    Aurora CO
    Haha yep I hit up TW every now an then.
    bobsuruncle[QUOTED] likes this.
  19. Aug 13, 2020 at 6:51 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    bought a used honda mower tuesday on offer up.
    upon cold startup no smoke, ran great, self propell worked fine. when i got home it fired right up, with lots of smoke..... ran it til the bag filled up and the kill switch quit....bag changed and now only second gear works.... get about half done and the rod starts to knock louder and louder. then it loses power and dies. dudes phone is off, account gone. i got fucked out of 260.00:annoyed:beware folks, i drew the short straw on this one.
  20. Aug 13, 2020 at 7:15 AM
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    Drive through a transfer station for weight. They can usually do an unofficial weight for free.
    I ran those on my taco, then my dodge 3/4 ton came with them when I bought it. I was happy with them, but I never did any hardcore wheeling either. When I first had them installed on the taco, wifey said they weren't as loud as she was expecting. They did fine for me in the snow and ice over here in my neck of the woods. I was about to get a new set of them in 285/75/16 but they weren't available. Hankook now had a new design which is the replacement for them. It is the dynapro at2 I think. When looking at reviews, and tread pattern, I didn't feel it would perform like I wanted, or like the original so I opted for Cooper at3.
