NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Oct 8, 2020 at 4:54 PM
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    The State can lose almost a billion dollars in unemployment money. Nobody gets fired, fined or arrested. The minute they think you fucked up they hold your feet to the fire, take you their court and fine you and charge you interest on top of it.
  2. Oct 8, 2020 at 5:11 PM
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    There have been different federal assistance rates during this whole mess. At first, it was $500 additional, then stopped, now $300. If you qualified to receive any payment from unemployment, you get the full federal additional amount.
    I've been in construction 13 years and used unemployment off and on since early on. I am dealing with my own issue now, and they will always have a minimum of a week to respond, especially via online correspondence. I have to agree about questioning the legitimacy of a one day notice to court proceedings.
    @White lightning boosted log into your unemployment account online tonight and look through there for letters and notices. Every letter I've received via snail mail is also saved in their system online.
  3. Oct 8, 2020 at 6:04 PM
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    youre seeing my legit worry.
  4. Oct 8, 2020 at 6:06 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i moved almost 3 months ago. but no email, no calls, no letters of notice. the state has a system as fuctional as an 83 renault transfer case.
    bobsuruncle likes this.
  5. Oct 8, 2020 at 6:08 PM
    Filip38507
    Filip38507 Well-Known Member
    Filip
    Lynnwood Washington
    2019 Tacoma TRD Offroad
    Lucky to still have some stock washers as a back up and an M12 was too small but the M14x1.5 worked perfectly!
  6. Oct 8, 2020 at 6:09 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    my problem was when i went back to work and had no need of filing i thought things were all fine. guess the state is more needy on my doings then my ex.
    thanks for the suggestion man.
  7. Oct 8, 2020 at 6:12 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i like this because youre on point. i dont like it because im on the receiving end of pointy.
  8. Oct 8, 2020 at 6:38 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Glad you figured it out. I spaced on toyota using JIS. Could tell you it's a 19mm wrench though!
    Filip38507[QUOTED] likes this.
  9. Oct 8, 2020 at 6:50 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    I would do the same for any Republican texting me1DC4799A-2252-4AD9-B41A-378CD506D60F.jpg
    vorkuta775, TireFire, FN-2187 and 6 others like this.
  10. Oct 8, 2020 at 7:20 PM
    Filip38507
    Filip
    Lynnwood Washington
    Glad I caught it in time the bolt was about halfway out. I threw some locktite on there to make sure it doesn’t happen again
  11. Oct 8, 2020 at 8:00 PM
    JDAM
    JDAM Well-Known Member
    J
    Worshington
    12 DCSB TRD OR
    I pretty much loctite everything these days. Blue at least. Had some rifle scopes come loose at bad times.
  12. Oct 10, 2020 at 12:56 AM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    bobsuruncle, uurx and Yetimetchkangmi like this.
  13. Oct 10, 2020 at 6:26 AM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Ok this is perfect! It is almost as good as the artificial phallic device that was installed on the gear shifter of James May's buggie in The Grand Tour - Morocco here .
    Since 2012, the crew I run with has this "hot potato" type of thing where we hide a Tijuana Mama (a spiced pickled meat sausage) somewhere on the vehicle.
    As it is found and surreptitiously transferred to another vehicle, the package can develop pin holes.
    Suggested hidden locations are, but not limited to:
    - gas tank cover (open the cover, plop out goes the weiner) This is particularly humorous in Oregon - "sir, your weiner dropped on the ground"
    - leaf springs via zip ties
    - seat adjuster via zip ties
    - just on the seat so when ya jump in, there is a bit of a surprise when you sit down.
    - spare tire(s)
    - base of the CB antenna
    - inside seat slider rails (this only worked on a duramax)
    - broken tail light housing
    - winch hause opening
    This is similar to @Blackdawg 's plastic kazoo trick
  14. Oct 10, 2020 at 9:53 AM
    Wyckedan
    Dan
    Woodinville WA
    If they were like $4-5 I probably would have ordered some and gotten my friends with it. I find that to be hilarious
  15. Oct 10, 2020 at 8:02 PM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
  16. Oct 10, 2020 at 9:56 PM
    Filip38507
    Filip
    Lynnwood Washington
    So I was hearing a really bad squeaking sound coming from the center of the truck when it was in reverse with the gas pressed I assume it’s the U joint so I threw a glob of grease on each one and the noise stopped should I start getting my self prepared to replace these soon or is it possible the noise was caused by some debris stuck in the joint and it got cycled out and is fine now?
  17. Oct 11, 2020 at 8:01 AM
    godofspeed
    godofspeed Washington State.
    2010 4x4 TRD OR DC
    Body Armor front bumper Body Armor rear bumper 17x8.5 Method Bead Lock 35x12.50 Camburg LT Fox coilover All Pro 11 pack leaf Fox rear shock with DSC Allpro frame slider Smittybuilt 9500 winch Cobra CB w/firestick antenna. Hi-lift Smittybuilt air compressor
    Drive it around and see if the noise comes back. You can always crawl under there and see if there is any excess movement. Most likely it really needed grease.
  18. Oct 11, 2020 at 10:07 AM
    Filip38507
    Filip
    Lynnwood Washington
    Surprised Toyota didn’t add any zerk fittings seems like a part that needs regular maintenance
  19. Oct 11, 2020 at 3:06 PM
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    Drunk shopping led to a waterport purchase. I'd been waiting for it to go on sale at Costco, but finally gave in. My wife asked if she could wash her hair with it on camping trips , so I guess she approves.
  20. Oct 11, 2020 at 3:08 PM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    Waterports are great esp if you have kids and/or dogs. Filthy animals
    dilbert[QUOTED] likes this.
