NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Nov 25, 2020 at 2:31 PM
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    This is gonna sound crazy but sometimes I think it’s the kind of dirt that we run in. Say if I’m up in the hills around Coville or Chewella in that red clay shit my truck squeaks like crazy when I get back. Same as the dusty volcanic stuff around Ellensburg. Around the house the roads are mostly pit run, limestone and granite not as bad.
    TimberTiger and cosmicfires like this.
  2. Nov 25, 2020 at 2:55 PM
    bottledWater
    bottledWater Member
    Seattle / Vancouver WA
    19 SCLB OR
    Does it matter much which traction boards to get? Looking on Amazon for example has so many options.
    Do you guys ever use the bed outlet for air compressor or is a 12v DC the better route to take?
    I'm in a similar situation as the other guy, I go out solo but haven't invested in winter cya gear and realizing now that I could've use traction boards a few times to save me from digging.
  3. Nov 25, 2020 at 3:01 PM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    All traction boards are better than no traction boards but they are not created equal. Maxtrax are arguably the best but are expensive at $300. The first time they get you out of a bad situation they have paid for themselves though.
    Don't get a air compressor to hook up in the bed or one that plugs into the cigarette outlet. Get one that hooks to your battery terminals like a viair 88p (entry level pump but works great)
    https://www.amazon.com/Viair-00088-...d=1&keywords=viaair+88p&qid=1606345232&sr=8-2
  4. Nov 25, 2020 at 3:02 PM
    msgs350
    msgs350 Well-Known Member
    PNW
    2020 Tacoma OR Cement DCSB 4x4 AT
    Some Mods
    Agreed, my $30 compressor that plugs into the cigarette outlet failed to inflate a swimming pool floatie the first time I used it.
    bobsuruncle and NWTacoTime like this.
  5. Nov 25, 2020 at 5:19 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    The 88p impressed the shit out of me, having used cig lighter pumps for years. Not even comparable.
    I believe the bed outlet is only 100w right? Or is it 400? Either way it's not enough for most things
  6. Nov 25, 2020 at 5:20 PM
    urshur
    urshur Well-Known Member
    2020 TRDOR ACLB
    400W in neutral/park, 100W in drive
    SailorWA likes this.
  7. Nov 26, 2020 at 7:15 PM
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    A tow strap can be used to wrap a tree for an anchor point. Keep a shackle on one end though. It can be useful to have a couple tow straps at times too. Chains can sometimes be useful as well. I keep 3 chains in my truck 2 of the chains have open hooks, and one has a binding hook. All 3 have a shackle at the end opposite the hook so I can make a loop out of it, or easily connect it to another chain securely.
    Never get the tow straps with metal hooks already sewn in. Those things have a proclivity for breaking or coming loose while under tension, and sending the metal part into a bystander or more likely, glass on a vehicle.
    More expensive than a tow strap, but similar is a kinetic rope. Bubba Rope is the only brand that comes to mind. These are basically high strength bungee ropes, so that in tugging somebody out of a stuck situation, it isn't a sudden jerk on the line. It is not something everybody has.
    Get a poor man's winch for now. A poor man's winch is more commonly called a come along. I first got a 2 ton model (with braided steel cable), then later got a 6 ton chain style come along. 4 months after getting my Tacoma, I got it stuck, and a come along is what got me out.
    Know your recovery points, and how to best utilize them for both getting yourself out of bad spots, as well as helping others. I am a big fan of the hook I got from uhaul that goes into the receiver. It cost $25+ tax, but is solid and you will break the pin keeping the hook in the receiver before straightening or breaking the hook itself. I now use it in my 7000 lb dodge 2500.
    You can take a bicycle pump with you for airing up tires. I did that once. In the time it took me to air up one tire, another guy with a compressor had all 4 tires done. I went to Harbor freight, and bought their 12 volt compressor that clamps onto battery terminals for about $60 on special. I learned the hard way, turn it on before connecting it to a tire. If it already has pressure on it, then it blows the fuse once turned on. I'm pretty sure that is specific to the cheap Harbor Freight thing though.
    If you want to get more into offroading, then save some pennies, then get full suspension to replace the spacers/blocks. I ended getting a good deal on OME (Old Man Emu) with full Dakar leaf pack, then installed it myself. Watch the for sale threads on here for things you are interested in. Watch the local threads for get togethers, which may include build days, meaning people meet at somebody's place and bring mods to put on their trucks. Some of us have tools and/or knowledge, and are happy to help others learn how to also do things.
    As for your truck offroad, I ran my 2011 4 banger 5 speed 4wd stock, even tires, and I think I surprised more than a few people. These Tacomas are very capable trucks right off the factory line.
    Next time you head to Chewelah or Colville, give me a shout. You probably pass by me in Deer Park on the way.
  8. Nov 26, 2020 at 7:42 PM
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    Lol, could have used your help a couple years ago when I slid off the road on the spring bear hunt.
  9. Nov 26, 2020 at 7:51 PM
    Filip38507
    Filip38507 Well-Known Member
    Filip
    Lynnwood Washington
    2019 Tacoma TRD Offroad
    Small problem, was pulling a 2wd Hyundai out of the snow and had my strap wrap around my right rear axel when backing up I don’t think there was a whole lot of tension on it but enough for the ABS light and Brake light to come on the dash, there doesn’t seem to be any physical damage and everything works normal but the light hasn’t reset its self after about an hour of high way driving, any ideas on what could be potentially damaged? I’m thinking it may have pulled a sensor out of place
  10. Nov 26, 2020 at 8:47 PM
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    Was it by the wheel? Check the abs speed sensor.
    Edit: passenger side rear sensor is on the back side of the axle.
    That reminds me... I still need to install these.
    https://sdhqoffroad.com/products/07...unner-05-current-tacoma-sdhq-built-abs-guards
  11. Nov 26, 2020 at 8:48 PM
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    Your probably right.
  12. Nov 26, 2020 at 9:36 PM
    Filip38507
    Filip
    Lynnwood Washington
    SilverYeti likes this.
  13. Nov 26, 2020 at 10:34 PM
    dilbert
    dilbert AI Member
    PNW
    That sucks. No good deed goes unpunished.
  14. Nov 26, 2020 at 10:49 PM
    Filip38507
    Filip
    Lynnwood Washington
    Is what it is, good news is that it’s a pretty easy and cheap fix
    dilbert[QUOTED] likes this.
  15. Nov 27, 2020 at 7:18 AM
    Smar969905
    Zach
    Deer Park, WA
    I'll still be around here when you get stuck again. A couple people on here have my phone number. I'll PM it to you too. If I come to rescue you, just know that it will be a dodge to save a Toyota. It could be worse though. At least it isn't a jeep...
    Never wrap an axle unless you are trying to tear the axle off. Look for frame points to grab. If you have a receiver, then use a pin in the receiver through the eye of the tow strap on your truck.
  16. Nov 27, 2020 at 9:34 AM
    Filip38507
    Filip
    Lynnwood Washington
    Wasn’t the plan to wrap the axel lol I have a D ring hook on my tow hitch and got lazy, didn’t disconnect it when trying to re angle my self to pull them out and worst came to worst I ended up running over the rope and it wrapped around my axel
  17. Nov 27, 2020 at 9:49 AM
    vorkuta775
    vorkuta775 Well-Known Member
    Texas
    tesla truck
    Have a good weekend all. Out on the strait de fuck with my wife for the weekend
  18. Nov 27, 2020 at 9:52 AM
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    Have fun dude!
  19. Nov 27, 2020 at 10:06 AM
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    Sounds good, hopefully I won’t need help. That trip is what set the truck build into overdrive.
  20. Nov 27, 2020 at 10:15 AM
    vorkuta775
    Texas
    tesla truck
    Oops I
    Meant de fuca lol fucking google
