NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Jan 23, 2021 at 7:15 PM
    SilverYeti
    SilverYeti Well-Known Member
    2010 Silver Tacoma TRD Offroad
    Pelfreybilt sliders ARB bumper WARN winch
    Thats how I felt about it too but after researching into it I found the WebMD of my truck lol. I wasn’t so sure though and I am not too familiar with spindle failures so I wanted to check with y’all. Thanks for the quick input on it. I will start watching it closely.
  2. Jan 24, 2021 at 5:29 AM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Itll tow fine. Wont be a speed machine through the mountains but itll get there. The only negative is you will be able to watch your gas gauge going down lol.
    The main thing I would do....upgrade the transmission cooler. The stock on is pretty meh once you start towing.
    @Greddy just got a trailer if i remember correctly so he might be able to add some things
    dilbert[QUOTED] likes this.
  3. Jan 24, 2021 at 10:16 AM
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    Why do you need dual? Do you want isolation, or run together? My diesel has dual batteries, but no isolation. I'm pretty sure the power lead from my first battery to the starter is larger than your largest lead from your battery.
    When I had my Tacoma, I was considering a dual batt setup, and have a switch in cab to connect it. The negative can be wired from one battery to the other. My thought was to add a fuse from second battery to go to a switch in the cab, then from switch to 100A relay. The main power from second battery I was thinking to go through the relay, and connect to the positive of first battery. This would have them connected in parallel when I flip the switch, and the relay would be powered by the second battery. Once the engine is running, the alternator can charge both batteries, and the in cab switch can be flipped to disconnect and isolate the second battery again.
    If you don't have access to a welder, unistrut is something easy to find as well, and it is easy to cut to length, then use some allthread, nuts, and washers to bolt the battery to the strut. The strut can be through bolted, or tek screwed into the truck.
    If you have a toolbox in the bed, that can be a good spot to hide the second battery as well. That will keep it dry, but it will require extra length of wiring.
    I pulled a 15 ft (3000 lbs dry, 3800 gvwr) with my 4 banger. I didn't have a trans temp gauge, and my truck did it. Get the bigger mirrors. I put the dodge style fold out mirrors on, and that helps tremendously. The stock mirrors don't go out far enough and you end up looking at the front of the trailer more than along the side.
    I had a basic preset brake controller I got from uhaul. It works, but I would reccomend getting a proportional brake controller. After I got a bigger truck to replace my Tacoma, I got a tekonsha proportional brake controller for about $110 on Amazon, and mounted it to the dash next to the A pillar. The proportional ones have to be mounted about level in the truck, as they have internal sensors to determine how much brake force to send to the trailer. When I wired it into my last truck, I was able to slip the leads down a small slot in the dash, so no drilling of new holes. When I put it into my current truck, the diesel, I was able to tuck the leads through a different hole to get under the dash, so again, no drilling of the dash.
    In pulling a travel trailer, it is like driving with a parachute hooked to your truck. When I've pulled my little 15 ft with my diesel, I am still doing about 65 in a 70. Going up hills, like i90 on either side of Vantage, just run slower. In my Tacoma, I had 31s and 3" OME/Dakar leaf pack, and every little uphill I was losing speed. If you have oversized tires on stock gears, you may want to look into regearing. The 2nd gen v6 is rated to tow up to 6500#, so it can pull the almost 4900# fully loaded trailer, but be ready to burn gas a lot faster, and feel weak.
  4. Jan 24, 2021 at 5:55 PM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    anyone in the market for a beat not babied 06 DCSB?
    :spy:
  5. Jan 25, 2021 at 7:44 PM
    Smar969905
    Zach
    Deer Park, WA
    I'll start the bid at $10
  6. Jan 25, 2021 at 9:31 PM
    vecdran
    vecdran Barely-Known Member
    Jeremy
    Kirkland, WA
    2020 TRD Pro Super White 6MT
    Financial Black Hole
    Doin' my best to make my truck not white. Avants Off Road put on a fun little muddin' day at Dirtfish.
    Nimitz, obhuan, wmranos and 5 others like this.
  7. Jan 25, 2021 at 10:15 PM
    Bigheadtinyarms
    Bigheadtinyarms Well-Known Member
    Seth
    Cedar City, UT
    91 FJ80, 07 DCSB
    37’s locker bumper winch lights seats LS Swap, 35’s winch lights roof rack suspension armor plasti dipped
    So I’ve been offered a 4th gen 4runner for a deal that I really can’t pass up. Been considering switching to an SUV for quite sometime already. . . Was wanting an 80’s series landcruiser so I’m really torn if I should jump on the runner, transfer parts from the truck over and just stick with the runner for a while until the right LC comes along.
  8. Jan 26, 2021 at 8:27 AM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    I love the 80 series but the money they are demanding these days is absurd. Still is my ideal offroader/family hauler though. Good luck with your search.
    As to the 4runner, if you plan on keeping it after the LC comes to fruition go for it, if you are going to sell it (or the tacoma) when the LC arrives then I wouldn't bother with yet another car transaction. But that's just me.
  9. Jan 26, 2021 at 5:35 PM
    SilverYeti
    So when people finally part ways with their built Tacoma’s so you generally part out or sell as is? I think it may be time for me with this Tacoma at least. This thing hasn’t stopped vibrating like a nut job since being rear-ended despite attempting to replacing and balancing literally everything that could cause it. 4wd blinking light came back today to top things off.
    Also, if I went 3rd gen due to 2nd gen tax is there anything you brought with you from your 2nd gen? I was going to build this thing into a crawler eventually but I want to build from a relatively solid foundation.
  10. Jan 26, 2021 at 5:48 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    Did someone say part out??? There's nothing you can bolt onto a Tacoma to make it worth any more money. It only increases desirability to someone looking for exactly what you have, aftermarket parts have zero value on the vehicle. Remove everything you can.
    TimberTiger likes this.
  11. Jan 26, 2021 at 5:56 PM
    SilverYeti
    Yep so I guess I need to remove all the work I have done in the last few months lol. CVJ axles, super bumps and pull sliders, JBA UCAs, canopy and the winch. Rest of everything probably has to stay since it replaced damaged bumpers from the accident. May be time for a dedicated off-roader and a tow rig but Tundras are pretty pricy too lol
  12. Jan 26, 2021 at 6:12 PM
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    If you go the 3rd gen route, pull the front bed rail utility track thingy. 3rd gen only has them on the sides, but the 2nd gen one will bolt right up on the front.
  13. Jan 26, 2021 at 7:59 PM
    Tayoflor
    Tayoflor Well-Known Member
    Taylor
    Woodinville
    2013 DCSB MGM
    Leer topper BAMF weld on sliders BAMF LCA skids Icon stage 4 SCS F5s wrapped in 285/75r16 Cooper Stt Maxx
    Is it the one my friend sold to your buddy in the 4WP parking lot?
  14. Jan 26, 2021 at 10:33 PM
    BZ4X4
    BZ4X4 Well-Known Member
    Brian
    2018 Blue Tacoma TRD Off-Road
    I’m in the market for some adjustable front shocks and I’m wondering if anyone manufacture is hold best in the PNW. King,Fox,ADS,Icon, and so on. Most of them come from desert racing not rain mud and snow so I’m curious what people’s experiences have been. Cheers
  15. Jan 26, 2021 at 10:41 PM
    Lost In The Woods
    Lost In The Woods 4 out of the 5 voices in my head say go for it!
    Eric
    Buckley, WA
    21 Gladiator Rubicon Diesel
    An unusually high amount of pinstriping.
    I can't speak for the other manufactures, but I've been running Kings for the past 65k miles and haven't had any problems. The first 55K saw heavy use on logging roads all year long.
    BZ4X4[QUOTED] likes this.
  16. Jan 26, 2021 at 11:18 PM
    Wyckedan
    Dan
    Woodinville WA
    Stay away from the OME "high end" stuff. ADS seems to be the money shot
  17. Jan 27, 2021 at 7:43 AM
    TimberTiger
    TimberTiger Get Western! ... ig @tcave87
    Tanner
    Arlington, Wa
    2014 DCSB Trd off road , 2002 Ext Cab Trd
    2014 DCSB: nitro 4.30 gears, Eaton/Harrop front locker, Bilstein 6112's w/ 650#, Camburg ball joint UCA's, Marlin cam tab gussets, Wheelers superbumps, Deaver U402 stage 2 leaves, bilstein b110's, u bolt flip, Archive hammer hangers, ADV weld co hybrid sliders, ADV weld co bed rack or Leer 180 w/ windoors, full RCI skids, SCS stealth 6, 35x10.5 kenda RT, ATH fab HC rear bumper, US offroad stealth front winch bumper, Smittybuilt x20 10k winch, ARB simpson III rtt, plenty of dents and scratches Now Sold 2002 TRD ext cab: 06 TRD Tundra coils, tundra 5100s, wheelers HD 3 leaf AAL, rear 5100s, ARB front bumper, SkidRow front skid, Leer commercial cap with windoors, 285/75r16 Kelly Safari TSR
    Dibs on the CVJ's if you decide to go that route!
  18. Jan 27, 2021 at 9:25 AM
    bttrbsch
    bttrbsch Well-Known Member
    Michael
    Bellingham, WA
    2018 Inferno Tacoma TRD Off-Road
    Kicker speaker upgrade Rockford Sub TRD Grill Raptor Lights Oedro Running Boards Seat Covers Black Emblems MBRP Exhaust Sound dampened doors Blacked out turn signals Pro comp 7069 wheels BFG KO2 285/70/17 Ram mount Joying Head Unit Fogs Soft topper canopy Fox 2.5 RR DSC Fox 2.0 RR rear HS AAL 1.5" rear plus overload (2" total) Center console divider Axe/Shovel Mount Traction boards 32" light bar Shift sense pro v2 iDrive throttle controller Xentec 35W HIDs Vair 88p air compressor Dome LEDs LED reverse lights + pods JBA Upper Control Arms Full size spare tire Driver seat riser
    Interested in the JBA's if you pull em off!
  19. Jan 27, 2021 at 10:17 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    All the suspension parts are interchangeable. I think roof racks are the same as well. So you could always buy some oem 3rd gen take off suspension/wheels for cheap and throw them on while you sell yours and then put your stuff on a 3rd gen. I thought 2nd gens were loyalists though :D
  20. Jan 27, 2021 at 10:19 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    oh shit. inferno dcsb, black wheels and softtopper. My doppleganger!
    ready6delta and bobsuruncle like this.
