NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Feb 18, 2021 at 9:43 AM
    Stick to your guns
    Stick to your guns Well-Known Member
    Bronson
    Lake Stevens
    2005 Black DCSB TRD off road
    Bilstean 6112, progessive AAL, method NV 17X8.5, Falken wildpeak AT3 285/70R17, Hooke Road rack, Spyder headlights, mesh grille, BAMF hybrid bumper.
    Do you think the tops are going to get chewed up? They’re polyurethane shackle bushings and have metal sleeves on the inside. I could swap to all heim joints they actually turned out to be a lot easier to work with but they’re more expensive
  2. Feb 18, 2021 at 10:21 AM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    Everything will get chewed up, i have this kit laying around the shop. It’s cheap and comes with a lower and upper tapered roller bearing set.
  3. Feb 18, 2021 at 10:32 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    Nm. See next post
  4. Feb 18, 2021 at 10:35 AM
    wrmathis
    Bonaire, GA
    parts and stuff
    Actually used washers and a capped tube from looking at the pics on mine.
  5. Feb 19, 2021 at 10:57 AM
    SilverYeti
    SilverYeti Well-Known Member
    2010 Silver Tacoma TRD Offroad
    Pelfreybilt sliders ARB bumper WARN winch
    Anyone got recommendations on an automatic transmission shop near Lake Stevens. Seems like my 5th gear/OD may be shot as it just revs to 3000 after I get above about 50. Thanks in advanced!
  6. Feb 19, 2021 at 11:09 AM
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    Do I need to take your truck up on the hill and put it down?
    TimberTiger likes this.
  7. Feb 19, 2021 at 11:19 AM
    TimberTiger
    TimberTiger Get Western! ... ig @tcave87
    Tanner
    Arlington, Wa
    2014 DCSB Trd off road , 2002 Ext Cab Trd
    2014 DCSB: nitro 4.30 gears, Eaton/Harrop front locker, Bilstein 6112's w/ 650#, Camburg ball joint UCA's, Marlin cam tab gussets, Wheelers superbumps, Deaver U402 stage 2 leaves, bilstein b110's, u bolt flip, Archive hammer hangers, ADV weld co hybrid sliders, ADV weld co bed rack or Leer 180 w/ windoors, full RCI skids, SCS stealth 6, 35x10.5 kenda RT, ATH fab HC rear bumper, US offroad stealth front winch bumper, Smittybuilt x20 10k winch, ARB simpson III rtt, plenty of dents and scratches Now Sold 2002 TRD ext cab: 06 TRD Tundra coils, tundra 5100s, wheelers HD 3 leaf AAL, rear 5100s, ARB front bumper, SkidRow front skid, Leer commercial cap with windoors, 285/75r16 Kelly Safari TSR
    Thought you guys might appreciate the new aftermarket Kardashian booty upgrade...
    FN-2187, BoatRacer, rlx02 and 3 others like this.
  8. Feb 19, 2021 at 11:20 AM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    Damn fine cutting there!
  9. Feb 19, 2021 at 11:24 AM
    TimberTiger
    Tanner
    Arlington, Wa
    Thank you sir!
  10. Feb 19, 2021 at 12:34 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Might just be a stuck shift solenoid as well.
  11. Feb 19, 2021 at 12:40 PM
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    Or a gunked up valve body...or low on fluid....or an issue with your torque converter
  12. Feb 19, 2021 at 12:42 PM
    TireFire
    Olympic Peninsula
    Shift solenoids are in the valve body and use ATF pressure :rolleyes:
  13. Feb 19, 2021 at 12:44 PM
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    touche...only half paying attention right now as I've been on a conference call since 8am :puke:
  14. Feb 19, 2021 at 12:58 PM
    SilverYeti
    damn near thing bud more and more of a shit box for a 2010 lol.
    that is what I am hoping but didn’t want to risk taking it over the pass. I will do some research on freeing those up. Gone for the weekend so will look Monday.
    I am wondering if low on fluid too... wish it was easier to check on these but I guess I could always just top it off.
  15. Feb 19, 2021 at 12:59 PM
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    A lot of AT issues are caused by low fluid....easy place to start
    SilverYeti[QUOTED] likes this.
  16. Feb 19, 2021 at 1:07 PM
    TireFire
    Olympic Peninsula
    You can drop the pan and replace the shift solenoid, Toyota sells those individually. I’ve had to replace one because the trans fell out of gear at stop lights. But before check for codes, there’s usually one stored in the ECU that points to the faulty solenoid IF indeed it is a shift solenoid issue but it usually is if the torque converter works in the other gears. Does it still lock up in 4th?
  17. Feb 19, 2021 at 1:15 PM
    SilverYeti
    Okay I will look on my tech stream cable at home and see what happens. Thanks for the tips y’all hoping that one of those easier fixes ends up being the trick and not the whole tranny. Kind of doubt it though or I would assume more symptoms. Though I don’t know shit about transmissions really, or their related issues. Time to learn I suppose haha.
  18. Feb 19, 2021 at 1:21 PM
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    Here is some light reading material for ya
    https://at-manuals.com/manuals/a340-a341-a343/
  19. Feb 19, 2021 at 2:42 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Looks like ATH's? Have it on mine as well!
    TimberTiger[QUOTED] likes this.
  20. Feb 19, 2021 at 7:10 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    Dream garage in terms of vehicles
    Shadowhunter and Wyckedan like this.
