NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Mar 30, 2021 at 6:18 PM
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
    18 LX570 on 35s, 06 Tundra DC beater
    Half the people you meet are below average intelligence
    Shadowhunter and longhairedhippy like this.
  2. Mar 30, 2021 at 7:56 PM
    Zemuron99
    Zemuron99 Well-Known Member
    Seattle, WA
    '98 TRD V-6 4x4
    TRD S/C URD Fuel Upgrades 9 aftermarket gauges!!
    OK, I hate to be too nit-picky, but that's not right. You're describing the 'median'-that is that point where 50% of the people are below, and 50% are above that point (unless the distribution follows a perfect bell-shaped curve). Depending on the distribution of values, there may be more people above or below the 'average'. Let's say 4 people have an IQ of 25, one has an IQ of 35, and one has an IQ of 135. The average is 45, and only 1 person is above that value. The average can be swayed by outliers (like the 135) on either side of it. The median always stays the same, in this case it's 25 (3 at/below this value, 3 at/above this value, regardless of whether the top value is 55, 65 or 1,000,000,000,000,000).
  3. Mar 30, 2021 at 8:34 PM
    BoatRacer
    BoatRacer Well-Known Member
    Olalla WA
    '02 TRD 3.4 5-Speed
    All Pro front bumper, Warn winch, leds, Dakar leaf pack, locker wire mod.
    Sorry if you already mentioned this, but have you removed the brake drum and looked at the shoes or hardware? I’ve had similar issues in the past that ended up being a build up of sand and fine rocks from wheeling in the mud all the time. It could be that easy, or a broken shoe, or spring.
    longhairedhippy likes this.
  4. Mar 30, 2021 at 11:04 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Yep, took a look at all the hardware and cleaned it up with brake cleaner. Seemed to do well for a day until it acted up again.
  5. Mar 31, 2021 at 10:05 AM
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
    I know you're right, but it does take something away from the joke
    Zemuron99[QUOTED] likes this.
  6. Mar 31, 2021 at 10:11 AM
    Taco2021LB
    Taco2021LB Well-Known Member
    Don
    WA
    2004 DblCab 4x4
    OME 882 Dakars Falken 235/85R16s
    Put the back of the truck on jack stands, wheels off the ground.
    Have someone standing aside the truck.
    Start it, put in gear, (go easy) a little gas, add brakes.
    Still noise?
    Where?
    If necessary, remove wheel.
    Start truck and repeat process.
    Sorry, I didn't READ your whole response.
  7. Mar 31, 2021 at 3:24 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    Today, i went full Ford
    longhairedhippy and rlx02 like this.
  8. Mar 31, 2021 at 4:03 PM
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
    I think the front fell off
    rlx02 likes this.
  9. Mar 31, 2021 at 4:06 PM
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
  10. Mar 31, 2021 at 4:08 PM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    Putting the taco shell on that frame....I can dig it :rofl:
  11. Mar 31, 2021 at 7:30 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    i would never subject the Toyota name to that type of torture
  12. Mar 31, 2021 at 7:31 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    things are going to continue to fall off...this all started because of an alignment
  13. Mar 31, 2021 at 8:23 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    That's a lot of threaded holes, I can see why it's so much. Buy a sheet of aluminum, some drill bits and taps and get to work? Probably take all damn day
  14. Mar 31, 2021 at 8:32 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    don’t forget the math part...there’s a lot of it
  15. Mar 31, 2021 at 10:45 PM
    Wyckedan
    Dan
    Woodinville WA
    This must be some April Fool's thing? Or am I losing it?
    Edit: and now this post is flipped making my screenshot look forwards. This is a trip
  16. Mar 31, 2021 at 10:52 PM
    PacNW_Taco
    PacNW_Taco Get lost.
    Colby
    Tacoma, WA
    2016 Black DCSB OR
    Peachy Peach air fesheners
    Uhh, the “black 3rd gen” thread is showing up as black and white? o_O
    Edit: Whooaaa
  17. Mar 31, 2021 at 10:54 PM
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    The entire 3rd Gen is Black and White
  18. Apr 1, 2021 at 8:39 AM
    Nimitz
    Nimitz #Flexus
    Sam
    Seattle
    I would assume the company that makes this doesnt have a guy with a ruler and a drill sitting in a warehouse producing these. Can you tap holes with a CNC? But then you would have to program the CNC with a CAD drawing that I don't have, so never mind I guess.
  19. Apr 1, 2021 at 9:24 AM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    you can tap with a CNC mill. They probably send the specs to the machine shop and they’ll make hundreds of them,the more you have made, the less each of them will cost.
    Nimitz[QUOTED] likes this.
  20. Apr 1, 2021 at 9:51 AM
    Duffer
    Duffer Active Member
    Marc
    Washington State
    2010 Tacoma Reg Cab 4x4
    U402 stage III leafs, Relentless front bumper, other things.
    For a one off 250 does not sound bad. You have cost of material and labor rates for the shops I've worked in range from 80-100 dollars an hour.
