NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Jun 14, 2021 at 12:33 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    If my lift wasn’t taken up right now I’d offer to do it for less than whatever Mule would charge
    Dirk Diggler likes this.
  2. Jun 14, 2021 at 1:05 PM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    Mule is like $280 OTD
  3. Jun 14, 2021 at 1:13 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Dude for 280 bucks get a harbor freight cut off wheel some pads a can of spray paint and a 125 welder too.
  4. Jun 14, 2021 at 1:21 PM
    bttrbsch
    bttrbsch Well-Known Member
    Michael
    Bellingham, WA
    2018 Inferno Tacoma TRD Off-Road
    Kicker speaker upgrade Rockford Sub TRD Grill Raptor Lights Oedro Running Boards Seat Covers Black Emblems MBRP Exhaust Sound dampened doors Blacked out turn signals Pro comp 7069 wheels BFG KO2 285/70/17 Ram mount Joying Head Unit Fogs Soft topper canopy Fox 2.5 RR DSC Fox 2.0 RR rear HS AAL 1.5" rear plus overload (2" total) Center console divider Axe/Shovel Mount Traction boards 32" light bar Shift sense pro v2 iDrive throttle controller Xentec 35W HIDs Vair 88p air compressor Dome LEDs LED reverse lights + pods JBA Upper Control Arms Full size spare tire Driver seat riser
    When does your lift open up? I've got the pre-cut plates. I've never welded before and don't think my truck frame is the best place to start haha
  5. Jun 14, 2021 at 1:22 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    @Usethe2nd ever worked on a mid 80s Chevy dumptruck? The like Chevy C70 think they are called. Bit diesel engine with 10 speed transmission.
    Got one in my back yard that's stuck in reverse. Clutch in it'll start fine but in neutral on the shifter stiff goes in reverse. Put it in any gear and it won't move and dies like it's in two gears (reverse and a forward).
    Leaning towards it being a broken....man name escape me...part that engages each gear
  6. Jun 14, 2021 at 1:24 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    depends on when my brother gets his drive lines back from Nw drivline for his Allison conversion, they’ve already fucked him once
    bttrbsch[QUOTED] likes this.
  7. Jun 14, 2021 at 1:26 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    Yep, can you feel the gears engage properly?
  8. Jun 14, 2021 at 1:29 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    It feels like it for 3-4-5. First goes in ok but is a bit odd to get out. Like you can't just push straight forward and have to push the stick towards the passenger then push up.
    It's not mine but a contractors. Was just taking a look. They also said it was low on fluid and filled the damn thing to the brim. Like all the way to the top of the shifter. Otherwise I'd just pull the top off and look but I'm not draining oil and crap too
  9. Jun 14, 2021 at 1:33 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    Ya you’ll have to pull the shifter off, it’s going to probably be a shift rail or fork that’s busted. If you know what trans it it you could narrow the issue down to either a rail or fork by having a exploded view and know what gears you can and can’t engage
    either that or the gears on the main shaft or counter shaft are screwed up
  10. Jun 14, 2021 at 1:37 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    I pulled the shifter off just not the part right below it that has the forks. It's as far as I'm going since it'll have to get taken to a shop anyways. I looked for the trans tag but a few years of cakes on dort made me stop lol.
    Just wanted to make sure I wasn't missing something stupid. Figured shift rail or the slider between gears. But not my problem anymore :)
    Usethe2nd[QUOTED] likes this.
  11. Jun 14, 2021 at 1:38 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    Those are the best types of problems
  12. Jun 14, 2021 at 1:40 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Especially since it's still got a load of dirt it in!
  13. Jun 14, 2021 at 1:51 PM
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    True...but I ain't stacking dimes
    Edit - and time is money
    Dirk Diggler[QUOTED] likes this.
  14. Jun 14, 2021 at 1:51 PM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    Paint makes me the welder I ain't
  15. Jun 14, 2021 at 1:54 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    you forgot the grinder part...
    gravyboat likes this.
  16. Jun 14, 2021 at 2:10 PM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    I'd use alot of paint if you can't guess :anonymous:
  17. Jun 14, 2021 at 2:15 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    40grit flap disc is a magic eraser
  18. Jun 14, 2021 at 2:18 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    They’ll cover up a lot of globs
    i prefer stacking dimes though
  19. Jun 14, 2021 at 5:28 PM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Apparently "Bells palsy".
    "Also called: idiopathic facial paralysis.
    Sudden weakness in the muscles on one half of the face.
    Bell's palsy may be a reaction to a viral infection. It rarely occurs more than once.
    Rare:
    • Fewer than 200,000 US cases per year
    • Treatable by a medical professional
    • Requires a medical diagnosis
    • Lab tests or imaging often required
    • Short-term: resolves within days to weeks
    • Critical: needs emergency care"
    When I smile only one side smiles, or raise my eyebrows, only one side raises, and when I close my eyes, only one side fully closes. Doctors really have no clue what causes it specifically, but it's typically a reaction your body has after fighting viral infection, or can be exacerbated by hypertension/stress and a few other things.
    I thought I was having a stroke. But at the time I went to the doctor finally the next evenig, it was pretty clear I wasn't having a stroke. If it had been a stroke I'd be brain dead or keeled over before I went to work last Monday morning.
    Yetimetchkangmi and Dirk Diggler like this.
  20. Jun 14, 2021 at 5:33 PM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    Fuck bud if you think you're stroking out don't wait. Stroke centers have great results for recovery now.
    Though when you have a stroke the chances of self diagnoses is slim and denying one is a symptom of one too
