NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Feb 20, 2022 at 9:24 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    I got the spc on my gx. And icons on my Tacoma. Not sure which I like better. Both feel the same for me and I have had the bushings on either mess up.
  2. Feb 21, 2022 at 8:24 AM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    I haven't had issues with my icon uca bushings. Put 30k miles on the first set then swapped em for newer ones just as a preventative type thing. Bushings still has lots of life left in them. Only reap maintenance thing I did was actually loosen the long bolt before putting new grease in which was done every oil change.
    The ball joint was done after those 30k miles though. I went with the delta joint for a replacement and it's held up fine for the 15k miles or so I have on it now. Again just grease it every oil change
  3. Feb 22, 2022 at 7:02 PM
    JeffRoyJenkins
    JeffRoyJenkins Essentially Non-Essential
    Jeff
    Lake Stevens, WA
    2024 F-150 XLT PowerBoost
    I somehow managed to get like 50k out of the Icon uniballs on my Tacoma before they were completely blown out and then I did about 10k on the delta joints and they were great. I really liked the fact that they are greasable and seemed just to work as well as the uniballs.
    Sadly I sold the truck a couple weeks ago but I just picked up a 2000 4Runner today. With 250k miles though it is going to need some TLC, just from my first inspections it is going to need some new UCAs too and at least one of the CVs has a torn boot. Anyone know what the best place to pick one up would be? It came with 2 extra CVs with torn boots I can use as a core without any down time.
  4. Feb 22, 2022 at 9:17 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Are your cores OEM? If so, CVJ will accept them as cores.
    Iif they are OEM they are worth rebooting them yourself. A Toyota boot kit will cost about $50/axle.
  5. Feb 23, 2022 at 5:00 AM
    JeffRoyJenkins
    Jeff
    Lake Stevens, WA
    Nice, I believe they are OEM but I haven't looked very hard at them. I will have to look into the boot kit.
  6. Feb 25, 2022 at 12:16 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Anyone hitting some trails/dunes this weekend?
    WrecklessAbandon likes this.
  7. Feb 25, 2022 at 1:06 PM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    I wish...will be doing family stuff in longview :puke:might be down to do something the following weekend though
  8. Feb 25, 2022 at 2:14 PM
    stonylaroux
    stonylaroux Well-Known Member
    Seattle, WA
    2015 Toyota Tacoma TRD Offroad
    I would also be down next weekend. I am committed to a few things this weekend. But haven't been out in a while on the trails.
  9. Feb 25, 2022 at 7:45 PM
    bttrbsch
    bttrbsch Well-Known Member
    Michael
    Bellingham, WA
    2018 Inferno Tacoma TRD Off-Road
    Kicker speaker upgrade Rockford Sub TRD Grill Raptor Lights Oedro Running Boards Seat Covers Black Emblems MBRP Exhaust Sound dampened doors Blacked out turn signals Pro comp 7069 wheels BFG KO2 285/70/17 Ram mount Joying Head Unit Fogs Soft topper canopy Fox 2.5 RR DSC Fox 2.0 RR rear HS AAL 1.5" rear plus overload (2" total) Center console divider Axe/Shovel Mount Traction boards 32" light bar Shift sense pro v2 iDrive throttle controller Xentec 35W HIDs Vair 88p air compressor Dome LEDs LED reverse lights + pods JBA Upper Control Arms Full size spare tire Driver seat riser
    I'm getting the itch to get out and explore somewhere on the weekends - just don't know where to go! Don't want to get in over my head lol
    Buttskevin21[QUOTED] likes this.
  10. Feb 26, 2022 at 5:16 AM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Couple buddies and I are headed to Moses lake dunes march 18th for the weekend. Gonna be riding and my first time playing with the taco at the dunes. Camping of coarse.
    Buttskevin21 likes this.
  11. Feb 26, 2022 at 4:12 PM
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    Swinging by here tomorrow morning if anyone else is going!
  12. Feb 26, 2022 at 6:05 PM
    ninernation
    ninernation Well-Known Member
    WA
    TRDOR
    OME, ALUCAB, RCI
    Getting some bad mpg on my third gen. Distance to empty shows 256 miles after filling up.
    It’s a 2018. On an OME lift, 255 Cooper ST Maxx (I know these are heavy,) sliders and an Alicante canopy. Seeing guys with 285s and more armor getting significantly better mileage.
    Any thoughts on what I need to check?
  13. Feb 26, 2022 at 6:08 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Do the math don't trust the digital. Example my tires are 3% off due to going up in tire size. Therefore, my mileage to empty and overall distance traveled is off by, 3%.
  14. Feb 26, 2022 at 6:16 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    I'd be real happy with those numbers on mine.
    Shadowhunter likes this.
  15. Feb 26, 2022 at 6:17 PM
    ninernation
    WA
    TRDOR
    OME, ALUCAB, RCI
    it is what it is. Weird to see guys with bigger tires and more armor showing 300+ miles to empty.
  16. Feb 26, 2022 at 7:32 PM
    shotgunbilly420
    Just ordered some 315/75/16 ko2's maybe I'll get lucky and get em sometime . Already have my cab relocation mount just need to install it
    captrussia253 likes this.
  17. Feb 26, 2022 at 8:32 PM
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    I have 285s and that is pretty much spot on for what my computer shows after a fuel up. Uncorrected I'm about 12-13mpgs around town and 14-15mpgs on the highway.
  18. Feb 26, 2022 at 8:37 PM
    stonylaroux
    Seattle, WA
    Just a heads up for folks in the Redmond area.
  19. Feb 26, 2022 at 10:18 PM
    Stick to your guns
    Stick to your guns Well-Known Member
    Bronson
    Lake Stevens
    2005 Black DCSB TRD off road
    Bilstean 6112, progessive AAL, method NV 17X8.5, Falken wildpeak AT3 285/70R17, Hooke Road rack, Spyder headlights, mesh grille, BAMF hybrid bumper.
    I couldn’t believe I was getting 16 mpg the other day when I filled up I almost took a picture. 285/70/17 with steel bumper, skids, roof rack, dual batteries, and the tent on the back. A combo of Fresh plugs, MAF and throttle body cleaning, and pedal commander on eco mode added like 4 mpgs
    shotgunbilly420 likes this.
  20. Feb 28, 2022 at 3:16 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    what’s your average mileage? On 285s, armor and lift, no tune and stock gears I was getting 18-19 city and 20-21 hwy. remember you have to calculate a % gain for larger tires too.
    On 35s regeared I’m getting 15.5mpgs right now but it is winter gas that always lowers the mpg.
