NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Oct 6, 2022 at 11:13 AM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Oh I know, the Solid offroad brand ones will put off more vibes but will also have a little less movement. They are also 3x the price.
  2. Oct 6, 2022 at 11:16 AM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Anything for our trucks is a few hundred $$$ lol
    Buttskevin21[QUOTED] likes this.
  3. Oct 6, 2022 at 11:18 AM
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    Cant beat the ones I did, as they are only $160 which is cheaper than stock.
  4. Oct 6, 2022 at 11:20 AM
    shotgunbilly420
    Damn you got a link for purchase . I'd like to check it out.
  5. Oct 6, 2022 at 11:20 AM
    Buttskevin21
    Kevin
    Washington
    Stock-ish
  6. Oct 6, 2022 at 11:28 AM
    shotgunbilly420
  7. Oct 6, 2022 at 12:41 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    It’s not just rolling mass but the diameter still affects how to drives. Gearing also immensely helps in 4lo. 5.29s and my 35s almost felt like a crawl gear on super steep descents.
  8. Oct 6, 2022 at 12:57 PM
    Stick to your guns
    Stick to your guns Well-Known Member
    Bronson
    Lake Stevens
    2005 Black DCSB TRD off road
    Bilstean 6112, progessive AAL, method NV 17X8.5, Falken wildpeak AT3 285/70R17, Hooke Road rack, Spyder headlights, mesh grille, BAMF hybrid bumper.
    Yeah the truck is still my DD and my off-roading is a lot more snow wheeling than it is crawling. I’m planning on 4.88s but I’ve been too lazy to pull my diffs and ship them to ECGS this summer…
  9. Oct 6, 2022 at 1:05 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    I go snow wheeling a few times a year too and the gearing always helps going up the trails too. Definitely worth it IMO if you’re doing 35s.
  10. Oct 6, 2022 at 2:41 PM
    msgs350
    msgs350 Well-Known Member
    PNW
    2020 Tacoma OR Cement DCSB 4x4 AT
    Some Mods
    They send you the diffs first, then you send your cores back to them and get your deposit back pretty quick..maybe that's what you meant and you're too lazy to do it. It's not bad, but their packaging could be improved.
    tonered likes this.
  11. Oct 6, 2022 at 2:55 PM
    Stick to your guns
    Bronson
    Lake Stevens
    If you send your diffs first then you can avoid dealing with core charges and they get your stuff done quicker.
  12. Oct 6, 2022 at 3:03 PM
    msgs350
    PNW
    Some Mods
    gotcha, the core charge does suck but glad I got it out of the way. good luck!
  13. Oct 8, 2022 at 1:32 PM
    stonylaroux
    stonylaroux Well-Known Member
    Seattle, WA
    2015 Toyota Tacoma TRD Offroad
    The trail giveth and the trail taketh!
    I no longer have body mount creaking after going up to Gallagher Head last weekend!
    The trail works in mysterious ways!
  14. Oct 8, 2022 at 3:52 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Hahaha! Mother Nature's lube?
    Probably got some dust in there that polished them up a bit. Might even confirm the body mount guess?
  15. Oct 8, 2022 at 4:59 PM
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    Good chance it could have been the dust shield. I chased a little squeal down back in August and it was bent in behind the caliber. I thought it was sure as hell a wheel bearing because it only happened on aggressive cornering where I was loading it up. It was like the thickness of 3 playing cards off the rotor. I think next time I’m doing wheel bearings I’m going to yeet them into the weight reduction blackberry bush behind the shop.
    Eazy.E likes this.
  16. Oct 8, 2022 at 5:36 PM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Tell that guy he's an idiot, I was able to get replacement u joints at my local Napa. Although, they are the best of the best IMO. Lots of knowledge under one roof there. It's a Spicer part number, and I'm pretty sure it's even stamped or on a sticker on the front drive shaft somewhere.
  17. Oct 8, 2022 at 5:55 PM
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    I got them from O Riley’s and put them in.
    bobsuruncle[QUOTED] likes this.
  18. Oct 9, 2022 at 7:30 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I did that on one of our cars and sort of regretted it. It took a bit of extra time when the rotors were cold and wet to bite.
    IMO, I would flex them or cut away small areas before tossing them.
    Shadowhunter[QUOTED] likes this.
  19. Oct 9, 2022 at 7:30 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just wild. At least you didn't have to get an entire shaft. Hahaha!
  20. Oct 9, 2022 at 8:53 PM
    4ast4orward
    4ast4orward Well-Known Member
    WA
    2014 Tacoma DCSB 4x4
    Gonna be regearing through ECGS too 4.88's here soon with an Eaton locker in rear and noticed I can do a Torsen LSD in the front, I do very easy off-roading and not trying too build a rock crawler. Does anyone have any experience with this LSD in the front? What would be the benefits and the negatives to this? I would throw a locker in but its $650 vs $1500, thanks for the input!
