NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Feb 17, 2023 at 2:26 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Be wary of any shock relocation setup that puts both shocks on the same side of the axle. Shocks are on opposite sides to mitigate axle wrap, moving them to the same sides can have undesirable axle wrap effects.
  2. Feb 17, 2023 at 2:58 PM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    have you bought anything yet? I’ve got the whole sua setup for sale.
    and I would argue against that just due to valving being the only thing kind of helping but could also be argued it’s trying to twist the axle…but any thicker pack will also negate any axle wrap.
  3. Feb 17, 2023 at 3:17 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Axle wrap is from driveline acceleration, attempting to hold it with a single pivot point on one side of the axle isn’t nearly as stabilizing as holding it from opposing sides. We chased this issue on @White lightning boosted truck after he did a shock relocation. Ended up having to install a traction bar to control it, but ended snapping the welds. Some don’t have issues, but it is something often overlooked in consideration with doing the relocate.
  4. Feb 17, 2023 at 3:20 PM
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    yes. consider all his points as they were factors.
    crashnburn80[QUOTED] likes this.
  5. Feb 17, 2023 at 4:31 PM
    pnw_runnin
    pnw_runnin Well-Known Member
    Louis
    Covington, WA
    2022 Tacoma OR DCLB, 2016 4R Trail
    I'm not disagreeing that axle wrap could be an issue with shocks on one side of the axle. From my understanding, it does seem like @White lightning boosted makes gobs more power than my stock 3rd gen, which has to factor in under hard acceleration. I would think that thicker/stiffer leafs and stiffer shocks would help offset it a bit. I'm on Icons at Option 2. There seem to be a quite a few folks on similar setups without really bad axle wrap. Or at least without knowing about it.
    I saw your setup posted while lurking on one of the LT threads. Would have jumped on it but I already had Fox's and SOA springs in hand with the rest in the mail!
  6. Feb 17, 2023 at 5:11 PM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Traction bars need a virtual pivot point at the front to allow the arm to move forward and backwards while pivoting instead of a fixed location.
  7. Feb 17, 2023 at 5:14 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    .not a fan of trac bars as mine tore a hole in my rear 3rd. id sell mine. i just cant use it for my ride.
    pnw_runnin likes this.
  8. Feb 17, 2023 at 5:17 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    give example of gobs of power. i can hit way over 100mph in 4th. when roads are wet i can do 55+mph drifting.
  9. Feb 17, 2023 at 5:18 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yes, it was on a boosted truck making much more power than 3rd Gen.
    It had pivot points. Axle wrap was so bad it broke the welds at the pivot.
  10. Feb 17, 2023 at 5:35 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    and probably 2k in payload with boost. oops.
  11. Feb 17, 2023 at 11:12 PM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    hence bigger packs. my 539/540 hd pack had minimal if any axle wrap with the ls.
  12. Feb 18, 2023 at 7:55 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I noticed a lot less wrap with just RXT Option 1 packs.
  13. Feb 18, 2023 at 3:41 PM
    pnw_runnin
    Louis
    Covington, WA
    Sounds like a heavier duty aftermarket leaf pack should be enough not have to worry about it too much.
    What I’m really more concerned with is positioning the axle tab and setting the bump travel correctly for my setup. That’s why I was looking for recommended installers by anyone who’s had similar kits done locally.
  14. Feb 18, 2023 at 3:50 PM
    johnnyjunk
    johnnyjunk Lurk more, learn more.
    The Great PNW
    2016 Tacoma TRD Off-Road
  15. Feb 21, 2023 at 9:43 PM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    anyone else going to the dirt and donuts at nomad? figured might be fun to show those overlanders what a real truck looks like...lol
  16. Feb 21, 2023 at 10:12 PM
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    I guess I could load up the hounds or put my Tupperware and knickknacks back on.
  17. Feb 22, 2023 at 8:50 AM
    Tacodog
    Tacodog Well-Known Member
    Ron
    Renton, Wa.
    ‘19 TRD offroad DCSB Cement
    Icon stage 1, Icon upper control arms, 17” Fuel wheels,Ridge Grapplers, TRD exhaust, leather interior.
    I’ll be there. It’s close to where I live.
  18. Feb 23, 2023 at 9:35 AM
    D-knoww
    D-knoww D-Know
    Washington state
    2019 Tacoma TRD Sport Longbed
  19. Feb 25, 2023 at 10:56 AM
    Tacodog
    Ron
    Renton, Wa.
    98C64F40-81B8-4A36-9563-259DCAF029BE.jpg Nomad Overland. 53772C19-00F9-4FAB-AAB1-2D3801DE181C.jpg
  20. Feb 27, 2023 at 7:23 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Next to a Yota dealer? If so, they know their audience. :D
    TacoEspecial likes this.
