NW WA Meet / BS Thread
Discussion in 'North West' started by Benson X, Jun 13, 2012.
  1. Jun 3, 2016 at 2:39 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Not sure if it makes a difference but I always do it the opposite. Turn the driveshaft and count the tire revolutions.
  2. Jun 3, 2016 at 2:56 PM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    Probably easier to see how many revolutions that way but both work.
  3. Jun 3, 2016 at 3:28 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    And the confusion seed is planted...
    bobsuruncle likes this.
  4. Jun 3, 2016 at 6:13 PM
    twalchlii1
    twalchlii1 Tacotraitor
    Tom
    Wa
    2018 GC Trailhawk
    Are floor mats a mod?
    You are going to want to remove your step bars for this trip or there is a good chance they will get damaged.
    PNW/TRD Steve likes this.
  5. Jun 3, 2016 at 9:14 PM
    Nylaia
    Nylaia WA Ambassador for L.O.T.
    Tara
    Lynnwood
    2016 Blazing Blue Tacoma TRD OR DCLB 1997 4Runner Limited 4x4
    Topper EzLift Weekender Ironman 4x4 3" Lift 18" Black Rhino 'Sierra' wheels BF Goodrich KO2's Warn VR Evo 10s Winch SDHQ Hidden Winch Bumper Leer 100XR Yakima Lock N Load Roof Rack OVS Nomadik 270* Awning Ironman 4x4 50L Watertank Light Bar Predator steps
    So... I think we are bowing out of the day trip on the 18th... Husband is worried Tahuya will damage the suspension on our '97 T4R. As far as we know, it's never been updated/upgraded. We've got over 230K miles on it already also.
    Anyone know of a great place to update/upgrade suspensions for our rig? Hopefully not too expensive either?
  6. Jun 3, 2016 at 9:32 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If your curious, try it the way I suggested to see of the results you gat are different. :D
    NorthwestCruiser likes this.
  7. Jun 3, 2016 at 10:28 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    15772FC7-6A51-487E-B0F7-4CDB8EEDAF53_zps_cffd4cc8c26c03d6b92ece6bdc3e76cf1b85b571.jpg
    My bumper works, it pulls and I car ramrodded a stump
    @bobsuruncle 's bumper works too that fallen tree got pounded
  8. Jun 3, 2016 at 10:36 PM
    James Lee
    James Lee 1st gen for the win.
    Seattle,WA
    2001 Tacoma 4x4 Limited TRD
    -OME 882 coils -Jeep Jk 10mm trimpackers -Wheeler's extending rear brake line -OME Dakars+aal -4in Deckplate -nitro sport shocks all around -Star Hid projector headlights -Trail gear rock sliders -Trail Gear low profile front bumper -Pro Comp 51's 15x8 on BFG KO 32" -ARB snorkel -EBC pads and rotors -Rago Fabrication ditch lights+brackets -SpiderTraxx 1.25 wheel spacers -Snugtop Canopy
    What much did y'all pay for the regear? Is it cheaper to get a 3rd member from ecgs and have a shop install it or just have a shop do everything?
  9. Jun 3, 2016 at 10:40 PM
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Cheaper to go through ECGS. Saves a lot of time building the gears.
    I got:
    4.88 gears f/r (4.56 and 4.88 are $50 extra I believe)
    ARB lockers f/r (which jacked up the price)
    Solid spacers f/r
    Gear oil
    I think thats it.. Anyway before core return it was $3990, after core return it was around $3100. If you do it without ARB lockers its around $1300 just for gears after core return, one ARB locker and gears is about $2200 after core return.
    Honeybadger likes this.
  10. Jun 3, 2016 at 11:30 PM
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    BP-51s, Dakar leafs, ARB bumper, 4xinnovations rear HC, 3x trail camera, pure android, lightforce 170s, Dick Cepek 255 85s extreme terrain.
    I was doing my oil change and found this damn stick stuck behind the vsc sensor plug. It left a mark on the inside of my rim and it wore a little on the CV boot. Never had this happen before heh.
  11. Jun 4, 2016 at 12:00 AM
    Boba Fetty
    Boba Fetty Well-Known Member
    Gen3 Tacoma DCLB TRD OR
    Ya, that's one of the first mistakes I noticed after getting them. Feel pretty dumb actually, hoping I can find someone interested in buying them so I can just replace them with sliders!
    twalchlii1[QUOTED] likes this.
  12. Jun 4, 2016 at 12:21 AM
    Honeybadger
    Honeybadger Powaaaaaah!
    Alex
    Kirkland, Wa
    05 Tacoma TRD Sport 05 4Runner Lmt
    ARB: Front bumper, compressor, tire repair kit, deflate 4xinnovations: Full skids King Racing: extended travel coil overs. Bamf shock relocation buckets with 12" smoothies. EBC: Slotted/drilled brakes with Yellowstuf pads Pioneer: Deck, speakers Wheelers: Front and rear superbumps, extended brake lines Homemade: Rear HC bumper with swingout Toyo: 255/85R16 Open Country MT
    How quickly did they ship for you? I'm looking to go with them as well. I'm gonna run both arb front and rear with 4.56s
  13. Jun 4, 2016 at 2:02 AM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    Oh yes, only $3100 he says...
    Sure, it would be nice, and sure, I'm much more pokey on the highway, but it isn't getting so much in the way that I can't drive safe or wheel OK. I need that money for all of my other stupidly spendy hobbies, such as buying very spendy pants because I fell down and put a hole through my last pair of spendy pants, or sending money to people who try teaching my dumb ass how to play a single note six different ways without screwing up (a la the guitar).
    Soon enough you and I are going to be doing something like this
  14. Jun 4, 2016 at 5:12 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    Are you looking to stay stock or upgrade?
  15. Jun 4, 2016 at 6:39 AM
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Lead time was about a week and a half, there were a few orders in front of me though.
  16. Jun 4, 2016 at 8:22 AM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Define update/upgrade. 230k miles on original suspension is a lot to begin with so even going with new OEM stuff will probably be a nicer ride. But if you want to upgrade to a bit better shock that should be smoother and more comfortable of a ride than i believe Old Man Emu has shocks you can get and Bilstein makes shocks for the 4runners. Both are pretty inexpensive overall.
    @AWilson013 and @GSPRunner might be able to help you out a bit more as they have 4runners too.
    You could also call DownSouth Motorsports (based in San Diego) or Wheelers Offroad (in Oregon) and talk to those guys and they could get you a setup youd be happy with.
    Honeybadger and Yetimetchkangmi like this.
  17. Jun 4, 2016 at 9:47 AM
    Honeybadger
    Alex
    Kirkland, Wa
    My brother just got the toytec kit with bilstiens for his 98 4runner. Looks a lot better and rides fantastic. I'm running the ome shocks and springs with the bilstiens 5100s myself. I originally started with just the 5100s they are a great begginers upgrade. Highly recommended.
  18. Jun 4, 2016 at 10:26 AM
    Nylaia
    Tara
    Lynnwood
    Upgrade
  19. Jun 4, 2016 at 10:41 AM
    Chickenmunga
    Keizer, Oregon
    x2 to that. Rule of thumb is to expect a change out every 50k
  20. Jun 4, 2016 at 10:53 AM
    James Lee
    Seattle,WA
    Damn sounds like i need some saving up to do. Who did the installation for you? I might be going to Randys ring and pinion up in everett to have them install the parts after i order them from ecgs.
