NWOR Tri-Y with an Auto Trans
Discussion in '1st Gen. Tacomas (1995-2004)' started by medikirk, Aug 13, 2011.
  1. Aug 13, 2011 at 12:12 PM
    medikirk
    medikirk [OP] Active Member
    Caleb
    North Carolina
    02 SR5 2.7l 4x4
    3" lift Deck Plate Mod Dynomax Super Turbo Muffler
    Anyone on here rocking the NWOR Tri-Y header on a 2001-2004 2.7l with an auto trans?
  2. Aug 13, 2011 at 1:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    If your asking as to why NWOR says it wont work, its because the tranny dip stick tube gets in the way. The tube can be bent to accomodate the header.
  3. Aug 14, 2011 at 4:33 AM
    medikirk
    Caleb
    North Carolina
    02 SR5 2.7l 4x4
    Yes that's basically what i was wanting to know. will bending the tube affect the tranny in any way and which way do you bend it. i.e. down or up.
  4. Aug 14, 2011 at 7:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It wont affect anything. You'll see how to bend it when you install the header. If you get it, get a set of OEM Toyota Gaskets, and some copper RTV. Use a thin film of Copper RTV on both sides of the gasket.
  5. Aug 26, 2011 at 4:23 AM
    medikirk
    Caleb
    North Carolina
    02 SR5 2.7l 4x4
    cool thanks. got to redirect funds to correcting lift right now.
