NWXPDTN - 04 TRD 4x4 XCab
Discussion in '1st Gen. Builds (1995-2004)' started by davidpick, Feb 27, 2013.
  1. Jul 25, 2014 at 7:08 PM
    #121
    davidpick
    davidpick [OP] NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    Fair point! I replaced the inner and outer TREs in March of 2013 and had a quick toe-and-go alignment done at Les Schwab so it's possible they didn't get it back to 0. But the TREs themselves should be solid, as they only have 25k miles on them.
  2. Jul 25, 2014 at 7:31 PM
    #122
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Well then, I can see why you are a bit concerned. Hopefull the full inspection will reveal the root cause.
    No noises when the 'stuck' occurs?
  3. Jul 25, 2014 at 7:57 PM
    #123
    davidpick
    David
    Leavenworth, WA
    Nope, no noises. To be honest I can't really feel any sticking but I can feel the wandering on the freeway. The alignment tech could feel sticking on the alignment rack apparently. I think it's sticking just to the left and right of TDC
  4. Jul 25, 2014 at 8:16 PM
    #124
    Digiratus
    Roaming the PNW
    The RedHead
    Hmm, very odd. Will be curious to see what you find.
  5. Jul 31, 2014 at 1:31 PM
    #125
    davidpick
    David
    Leavenworth, WA
    Yup, bent piston in the rack and pinion assembly. :(
  6. Jul 31, 2014 at 8:13 PM
    #126
    Digiratus
    Roaming the PNW
    The RedHead
    Aw man, that sucks. Diagnosed as bent eh? Any idea how it happened?
    I have read about the guides inside wearing but have not heard of a stock unit bending.
  7. Jul 31, 2014 at 10:42 PM
    #127
    davidpick
    David
    Leavenworth, WA
    Yeah, bent somehow... not really sure, as I don't really do that much crazy off-roading and am pretty good about care and maintenance. I have done quite a few miles on some gnarly washboard dirt/gravel roads to get to hikes and trailheads though...
    Gonna go with a new OEM assembly for the replacement though. Too many horror stories with aftermarket.
  8. Aug 23, 2014 at 7:43 AM
    #128
    davidpick
    David
    Leavenworth, WA
    Well, new steering rack is installed and I re-did the "steering column tack weld mod" as my little tack weld had snapped due to some pretty rough forest service roads. Steering is nice and tight and drives like a dream. No more wandering and weird sticking while turning. But for $1100 it better be perfect haha...
  9. Sep 30, 2014 at 12:26 PM
    #129
    2002
    2002 Well-Known Member
    Andrew
    Louisiana
    2002 Prerunner sr5
    3 inch skyjacker lift 18x9 rockstars Plasti-dipped emblems 32" BFG all-terrains K&N cold air intake Retro fit projectors with 5k HID LED Light Bar mounted behind bottom grille
    Bro loving your build and loving my projectors had to do some work on the though one time both of the shrouds came off had to fix that then a ballast went out i had to order two new ones then a bulb went out had to get two new one of those and my wiring harness went out and had to replace that over all though it was worth it i now have a brand new hid system because of it lol and i still love them hahahahaahahahahahhaahha
  10. Oct 1, 2014 at 2:05 PM
    #130
    The_Trail_Yota
    The_Trail_Yota Well-Known Member
    Colorado
    2021 TRD Offroad
    Bells & Whistles
    David, great job on the bed rack. I'm getting ready to do the same here soon with my Father-In-Law, he's got the welding skills. Just curious what you based your measurements off for the platform of the bed rack?
  11. Oct 1, 2014 at 2:24 PM
    #131
    The_Trail_Yota
    Colorado
    2021 TRD Offroad
    Bells & Whistles
    I should have looked further back. Did you end up going with these specs? What angle cuts did you put on the 2x1s?
  12. Oct 3, 2014 at 7:07 AM
    #132
    davidpick
    David
    Leavenworth, WA
    Yep, I did end up going with those specs and it worked great! To get the angle on the legs, I built a jig to hold the upper "deck" part at the correct height and then just did a simple rise over run calculation to determine the angle and cut it with a chop saw.
  13. Oct 3, 2014 at 10:47 AM
    #133
    The_Trail_Yota
    Colorado
    2021 TRD Offroad
    Bells & Whistles
    Awesome! I figured that's how you got the angle! Thanks for sharing the specs! I just can't justify paying big bucks for a bed rack when my father-in-law has an awesome welder and a cheap source for metal. I'm thinking I might have him teach me how to weld that way I can get a welder and then the sky is the limit! :D:D:D:D:D:D:D:D:D:D:D:D
  14. Oct 3, 2014 at 11:27 AM
    #134
    The_Trail_Yota
    Colorado
    2021 TRD Offroad
    Bells & Whistles
    Get the CBI bumper. I got one and I love it!
  15. Oct 3, 2014 at 12:12 PM
    #135
    davidpick
    David
    Leavenworth, WA
    Do it! This was my first welding project ever. My roommate was a little 110v Lincoln Electric unit but it did fine. After a little grinding, my welds look great haha. Plus, the satisfaction of building something yourself from scratch is fantastic. Easily one of my proudest achievements with my truck.
    I'm so close! Need to save a bit more though... One day haha!
  16. Oct 3, 2014 at 1:01 PM
    #136
    Digiratus
    Roaming the PNW
    The RedHead
    Did you ever go pick up those scepter cans?
  17. Oct 3, 2014 at 4:10 PM
    #137
    davidpick
    David
    Leavenworth, WA
    i haven't yet. been pretty busy recently. hoping to get up that way in november/december.
  18. Oct 3, 2014 at 6:42 PM
    #138
    Digiratus
    Roaming the PNW
    The RedHead
    It would make for a nice little road trip. :D
  19. Jan 1, 2015 at 12:57 PM
    #139
    davidpick
    David
    Leavenworth, WA
    Hello and happy new year TW! I'm looking for someone or someplace to have my front wheel wells tubbed. My 285/75r16 tires are rubbing the pinch weld during articulation while turning and I've decided that 2015 is the year that I correct this issue. Looking for assistance or a recommendation as this sort of project is way above my skill level.
    mrbeggins has some pictures of the process I'd like to follow: http://www.tacomaworld.com/forum/1st...ml#post7366742
  20. Jan 1, 2015 at 4:58 PM
    #140
    Dj318
    Dj318 Well-Known Member
    Dylan
    Concord, NC
    02 Tacoma
    bilstein 5100, wheelers AAL, Trail gear bumper, SOS sliders, RAT skids, 35" Mtr/k
    You don't have to tub for 285/75s pretty sure you'll be ok if you just cut the punch weld a little, trim the plastic and take a bfh to the fender well
