NY/NJ/PA/LI/CT Mega Thread
Discussion in 'North East' started by crazychris4124, Feb 14, 2018.
  1. Oct 28, 2018 at 2:00 PM
    #221
    Sasquatchtaco
    Sasquatchtaco Sasquatch Taco
    Catskills NYS
    09 MGM DCSB 4X4 TRD
    ImMrYo Rear-View Mirror Lift Bracket, Android HU replacement, Climate Unit Knobs, USB outlet mod, DRL mod, frame restoration with etch & prep and Por-15, and Satoshi grille.
    Ha! That's the thing . I bought a cheap CB but an expensive antenna. I have a feeling the ciax cable was messed up.
    Bastek likes this.
  2. Oct 28, 2018 at 2:23 PM
    #222
    Bastek
    Bastek Member
    Seb
    SI NY
    '17 OR Taco
    Some stickers, plastidip and radio knobs
    Yeah, if pinched or forcibly twisted, it surely could have been messed up. Did you re-drill the hole in the bracket? Is the bracket properly grounded? (When in doubt: sand/remove some paint, add grounding screw with grounding strap, and if possible ground it to the frame.... Sorry, if I didn't stress ground enough :devil::devil: ). Once your bracket and antenna ground is figured out, rest should be cake.
    For good measure there is a diagram of antenna to bracket connection/ assembly.
    I'm rocking something a bit different, due to a fact that 3rd gens have tighter space between tailgate and bedside. Some people experienced issues with chipping paint on their tailgates when using mounts like yours (and similar), so I've decided to go with trunk/hood lip NMO mount (and NMO antenna).
    wmg and Sasquatchtaco like this.
  3. Oct 28, 2018 at 7:30 PM
    #223
    pmstoy10
    pmstoy10 Well-Known Member
    hudson valley, ny
    2010 Tacoma DCLB TRD Sport
    Weathertech Floor Liners, UWS Toolbox, Seatbelt Chime Mod, Coverking Covers, Window Guards, Wheeler's 1.5" Single Leaf AAL, Rear Spring TSB, Front Bilstein 5100's @ 2.5", Rear Extended Travel Bilstein 5100's, removed front mud flaps, Lifetime LED Headlights, Firestone RideRite Air Bags with Daystar Cradles, Light Racing UCA's, ECGS Front Diff Bushing
    hmmm...guess I better check my swr before I burn out the ham.....
    Sasquatchtaco likes this.
  4. Oct 29, 2018 at 5:56 PM
    #224
    Sasquatchtaco
    Catskills NYS
    09 MGM DCSB 4X4 TRD
    I made the hole slightly larger, isanded, I cleaned, i spit on it and shined it :D...oh and I grounded the antenna to the frame. Nice and clean. Didn't work for shit.
    Bastek likes this.
  5. Oct 29, 2018 at 6:07 PM
    #225
    Bastek
    Bastek Member
    Seb
    SI NY
    '17 OR Taco
    :pout:
  6. Nov 6, 2018 at 12:53 PM
    #226
    wmg
    wmg Well-Known Member
    bill
    2015 Tacoma ..Off Road
    BP-51 OEM LIFT..33;s...xd9000...ARB bumpers...cat back...rockers...bed tire rack....
  7. Nov 6, 2018 at 12:58 PM
    #227
    Bastek
    Bastek Member
    Seb
    SI NY
    '17 OR Taco
  8. Nov 6, 2018 at 1:03 PM
    #228
    Bastek
    Bastek Member
    Seb
    SI NY
    '17 OR Taco
  9. Nov 6, 2018 at 3:47 PM
    #229
    wmg
    bill
    ur most welcome...I must have 75 threads bookmarked ...just tons of info on the site..glad to share and good luck with the install..mine was very simpleIMG_0131.jpg
    Bastek likes this.
  10. Nov 7, 2018 at 5:54 AM
    #230
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Special grill insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot
    Bastek, pmstoy10 and wmg like this.
  11. Nov 7, 2018 at 6:51 AM
    #231
    Cativelense
    Nuno
    CT
    And by the way, it's no longer just a New England calendar. It's a Northeast calendar.
    pmstoy10, Sasquatchtaco and Bastek like this.
  12. Nov 7, 2018 at 7:04 AM
    #232
    Bastek
    Bastek Member
    Seb
    SI NY
    '17 OR Taco
    Well, that's nice:thumbsup:
    Cativelense likes this.
  13. Nov 7, 2018 at 5:12 PM
    #233
    Sasquatchtaco
    Catskills NYS
    09 MGM DCSB 4X4 TRD
    Thank you sir. I got a uniden 520 pro xl off ebay for cheap and it's working fine. I just haven't bothered in connecting the Wilson 2000 antenna to it. I should get some new coax cable before I do that I suppose.
    Bastek likes this.
  14. Nov 12, 2018 at 5:59 PM
    #234
    Taco_Coma
    Taco_Coma Well-Known Member
    South NJ
    2018 DCSB SR5
    Where's the best place to get a leer trilogy tonneau cover in south nj? This one place quoted me about $150 less than anyone else. But the place is never open
  15. Dec 29, 2018 at 9:05 AM
    #235
    urbanrails
    urbanrails Member
    Long Island, NY
    2018 TRD OFF ROAD
    Surprised to see this thread is so dead, I see a dozen tacomas a day on LI
  16. Dec 29, 2018 at 12:06 PM
    #236
    Bastek
    Bastek Member
    Seb
    SI NY
    '17 OR Taco
    Yupp, OP went missing... And dedicated LI thread doesn't get much action neither
  17. Jan 1, 2019 at 11:28 AM
    #237
    crazychris4124
    crazychris4124 [OP] Earn those pinstripes
    Westchester County, NY
    '17 Inferno DCSB TRD OR
    I'm here, just been busy last couple of months.
    Bastek likes this.
  18. Jan 1, 2019 at 1:56 PM
    #238
    Sand Dog
    Sand Dog Well-Known Member
    2018 SR, 4x4 CC, MGM
    Saw this today in northern Westchester...
    Bastek likes this.
  19. Jan 1, 2019 at 2:13 PM
    #239
    Bastek
    Bastek Member
    Seb
    SI NY
    '17 OR Taco
    My favorite color, like ever! Lol
    Sand Dog likes this.
  20. Jan 1, 2019 at 2:15 PM
    #240
    Bastek
    Bastek Member
    Seb
    SI NY
    '17 OR Taco
    Happy New Year !!
    Hmmm, busy looking for pics from AOAA? :boink: lol
    crazychris4124 [OP] likes this.
