NYCO's '06 Boosted Blue Betty
Discussion in '2nd Gen. Builds (2005-2015)' started by NYCO, May 18, 2011.
  1. Aug 19, 2013 at 4:24 PM
    #2001
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    Stronger than Yukon at least. That's what broke
  2. Aug 19, 2013 at 4:28 PM
    #2002
    Round II
    Round II Member #12005
    Wow 2nd set eh.:(
  3. Aug 19, 2013 at 4:56 PM
    #2003
    NYCO
    bOb
    Colorado
    dents & scratches
    Yup. I love upgrades. Hate repairs!
    She's fixed tho.
  4. Aug 19, 2013 at 4:58 PM
    #2004
    Round II
    I agree, I always try to upgrade before I have to make repairs.:crazy:
    I'm still working on dates for this fall and will keep you posted.;)
  5. Aug 19, 2013 at 5:36 PM
    #2005
    Manwithoutaplan
    ID
    So glad I have 8.4 rear.
  6. Aug 19, 2013 at 6:05 PM
    #2006
    NYCO
    bOb
    Colorado
    dents & scratches
    sounds good...i'll take off what i can and join in for as much of the trip as i can...hoping to have the rtt on by then and looking to spend some time in the mtns before the snow begins to pile up...
    figure some good fishing spots and some wheeling is what you're looking for?
    yea an 8.4 w/ an ARB i've heard is a good combo
  7. Aug 19, 2013 at 6:45 PM
    #2007
    Round II
    Mostly looking for scenery but fishing would be a plus, not to much worried bout the wheeling but hey if its calls for it then yep.
  8. Aug 19, 2013 at 6:47 PM
    #2008
    Round II
    You may get lucky like me and get 130k plus out of it....Still going strong...:burnrubber:
  9. Aug 19, 2013 at 7:02 PM
    #2009
    Round II
    Ah yes forgot that you had Nitro's in there you should be much safer with those. It's strange but mine has been used a ton and seems to be bullet proof so far Maybe its because mine was one of the 1st trucks out of NUMI, who knows?
  10. Aug 19, 2013 at 7:44 PM
    #2010
    NYCO
    bOb
    Colorado
    dents & scratches
    i'll bounce some ideas off ya when it comes time for planning
  11. Aug 20, 2013 at 11:16 AM
    #2011
    Round II
    Sounds good!:cool:
  12. Aug 20, 2013 at 5:03 PM
    #2012
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Rumor has it this truck is running again. I don't believe it! :D
  13. Aug 20, 2013 at 5:05 PM
    #2013
    NYCO
    bOb
    Colorado
    dents & scratches
    :yay:
  14. Aug 21, 2013 at 6:37 AM
    #2014
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    She survived open axle surgery?
  15. Aug 21, 2013 at 7:59 AM
    #2015
    NYCO
    bOb
    Colorado
    dents & scratches
    yup..found out that there is a reason why so many people have bad things to say about yukon gears...
    on to nitro gears front and rear now
    had some new rear brake pads thrown on while things were a part as well..
    nice to have her back...now the process of breaking in new gears...gotta take er' easy for a bit...
    but she'll get dirty this weekend...loooooooong overdue!
  16. Aug 21, 2013 at 8:01 AM
    #2016
    NYCO
    bOb
    Colorado
    dents & scratches
    Q: How Do I Break-In My New Gears
    New gear sets MUST be broken in correctly to prevent damage. Not following proper break-in procedures will lead to overloading and overheating the ring and pinion as well as breaking down and ruining the gear oil. Not following proper break-in procedures can be determined during inspection and will void the warranty.
    Please follow the below guidelines to ensure a proper break-in and long life of your gears.
    • Only use high quality gear oils. ECGS recommends Lucas non-synthetic 75-140 or 85-140
    • On initial run, drive lightly for 15 to 20 minutes then stop to allow differential to cool completely for 20 to 25 minutes.
    • Avoid towing and heavy acceleration, as well as vary speeds every 5 to 10 minutes while driving on highways.
    • Drive conservatively and do not drive more than 50 miles at a time without allowing a cool cycle during the first 500 miles following installation.
    • After completing initial break-in, change gear oil at 500 miles. Small metal particles are normal and gear oil will typically be black. Excessive metal in gear oil should be reviewed by a competent differential mechanic to ensure safety of internal parts.
    Post gear oil change and initial break-in: Towing.
    • First time towing should be limited to light load for no more than 15 miles, then allow differential to cool completely for 20 to 25 minutes.
    • Repeat this procedure for first 45 miles of towing for full break-in of gears for towing vehicles.
    PREMATURE OVERLOADING AND IMPROPER BREAK-IN WILL CAUSE GEAR OIL BREAKDOWN AND MAY RESULT IN RING AND PINION FAILURE VOIDING THE GEAR WARRANTY!
  17. Aug 21, 2013 at 8:02 AM
    #2017
    NYCO
    bOb
    Colorado
    dents & scratches
    ^for anyone wondering
  18. Aug 21, 2013 at 9:31 AM
    #2018
    JLink
    Josh
    Ocean, NJ
    Good to know :thumbsup:
    Btw what gears are you using? 4.56s?
  19. Aug 21, 2013 at 10:27 AM
    #2019
    NYCO
    bOb
    Colorado
    dents & scratches
    yup 4.56s
  20. Aug 21, 2013 at 5:55 PM
    #2020
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    "competent mechanic" lol
