NYCO's '06 Boosted Blue Betty
Discussion in '2nd Gen. Builds (2005-2015)' started by NYCO, May 18, 2011.
  1. Jan 20, 2014 at 5:03 PM
    #2641
    BradyT88
    BradyT88 Well-Known Member
    Nice!
    So are your pics of your cut flares in this thread somewhere? I want to check out how you did it. I think I need to take a couple inches out of my rear fenders to clear my tires both sides are stuffed...
  2. Jan 20, 2014 at 5:07 PM
    #2642
    BradyT88
    Found them! So you just cut the bottom of and left it open? I was trying to figure out how to take a couple inches out of the middle and reattach the top and bottom in a way that didn't look awful. haha
  3. Jan 20, 2014 at 5:14 PM
    #2643
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Interesting. If my thoughts are correct, longer springs will set that shackle back further and closer to the frame lowering your rear end. You are going to need extended shackles or start running "Brah" style. :D
  4. Jan 20, 2014 at 5:19 PM
    #2644
    Gramps
    Gramps
    07 TRD DC 4x4
    Paint it all black inside and you see nothing. Bob's was first set we cut up. Mine will be next. The process isn't bad but does take a good weekend. I am thinking of spraying bed liner in at the very end to seal it.
    Bob added some bolts and wing nuts on the ends to help secure the flare a bit better then the plastic mounts. This helped out a lot. I think I will add them on the ends and at a couple more points in the middle. They appear to be holding up well on his so far.
  5. Jan 20, 2014 at 5:23 PM
    #2645
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    already run a rake, so it'll actually level me out i'm guessing...but longer shackles will fix the lift if needed...a benefit of having the shackle flip now :D
    hoping my defined shackles will fit over the Toytec leafs so i can install those finally!
  6. Jan 20, 2014 at 5:25 PM
    #2646
    NYCO
    bOb
    Colorado
    dents & scratches
  7. Jan 20, 2014 at 5:28 PM
    #2647
    BradyT88
    I see. Did you just paint the backside of the flare black of the fender as well?
  8. Jan 20, 2014 at 5:31 PM
    #2648
    NYCO
    bOb
    Colorado
    dents & scratches
    i think we painted the fender a bit back there...i forget
    i need to take it apart again and repair some of the flare tabs that broke during removal..probably do more of those bolts to help keep the flare tight on the fender..
  9. Jan 20, 2014 at 5:55 PM
    #2649
    Gramps
    Gramps
    07 TRD DC 4x4
    I think we did a quick final spray inside after install but since your truck is already dark it really wasn't needed.
    Mine on the other hand being sand will need a dark coat inside. So I was going to spray bedliner in there after it is back on.
    More bolts will definitely be in order along with a few extra "tabs" left in the steel fender trimmed to allow for the splash gaurd to remain intact.
  10. Jan 20, 2014 at 6:17 PM
    #2650
    BradyT88
    Yeah... My silver isn't going to be any better I don't think. haha
    Good to know. So what is this super secret tool I saw a little about in the CO BS thread? Or did I quit reading too soon and it's in there? haha
  11. Jan 20, 2014 at 6:19 PM
    #2651
    NYCO
    bOb
    Colorado
    dents & scratches
    we could tell you, but then we'd have to kill you :spy:
  12. Jan 20, 2014 at 6:22 PM
    #2652
    Gramps
    Gramps
    07 TRD DC 4x4
    X2.
  13. Jan 20, 2014 at 6:34 PM
    #2653
    BradyT88
    Alrighty then. haha You just bring the tool with you to Moab and I'll bring my flares and we can do mine at night after the trail runs. We can do 1 one night and the other the next night. haha :D
  14. Jan 20, 2014 at 6:44 PM
    #2654
    Gramps
    Gramps
    07 TRD DC 4x4
    There is a $250 per flare mobile processing fee for work done after hours at the event. Oh and then there is the standard labor fees that will apply. :-D
  15. Jan 20, 2014 at 6:51 PM
    #2655
    NYCO
    bOb
    Colorado
    dents & scratches
  16. Jan 20, 2014 at 7:06 PM
    #2656
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    That's a lot of beer....
  17. Jan 20, 2014 at 7:20 PM
    #2657
    BradyT88
    Well in that case I'm not going to do it/help. I'm going to just kick back with a beer and watch and they better look damn good! :cool: haha
  18. Jan 20, 2014 at 8:57 PM
    #2658
    NYCO
    bOb
    Colorado
    dents & scratches
    :laugh:
    Mcgrimm I believe had photos of his tool. Same idea but slightly different.
  19. Jan 20, 2014 at 9:02 PM
    #2659
    BradyT88
    Was it like Monte's tool? haha A ruler with 2 holes drilled in it. 1 hole had a pencil in it as a guide and the other hole had a sharpie to make the cut line.
  20. Jan 21, 2014 at 9:57 AM
    #2660
    Gramps
    Gramps
    07 TRD DC 4x4
    Damn I went too cheap! :-D
