NYCO's '06 Boosted Blue Betty
Discussion in '2nd Gen. Builds (2005-2015)' started by NYCO, May 18, 2011.
  1. Mar 29, 2014 at 3:03 PM
    #3361
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    :ohsnap:
    Bob's are a 15. :D
  2. Mar 29, 2014 at 3:30 PM
    #3362
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    They are over achievers :D
  3. Mar 29, 2014 at 3:35 PM
    #3363
    NYCO
    bOb
    Colorado
    dents & scratches
    Stage 1 BFH complete. Almost there. I can turn almost full on compression. Just a little more to trim and beat then I'll be good.
    Not turning fits nice tho :D
    E87B2F34-6196-4A7B-9977-9119FF3A9EC8_zps_0193e010036b228fb425682a04459a0bae5eac11.jpg
    89E0E239-E69A-4DFF-B5CE-64B167B3FC5F_zps_84ca5a11224e86e6484128901b4ca516eb805151.jpg
  4. Mar 29, 2014 at 6:28 PM
    #3364
    Gramps
    Gramps
    07 TRD DC 4x4
    Need bigger hammer! :-D
  5. Mar 29, 2014 at 7:06 PM
    #3365
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Where is it rubbing when you turn? Pinch weld?
  6. Mar 29, 2014 at 7:10 PM
    #3366
    NYCO
    bOb
    Colorado
    dents & scratches
    There's a small section of the cab mount and the firewall just above the cab mount.
    So I'm going to grind it back a bit more, convince the firewall a bit more, then work on getting both sides equal.
  7. Mar 29, 2014 at 7:19 PM
    #3367
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I still rub firewall... Have not adjusted the caster tho. :eek:
    Looking good my friend. :thumbsup:
  8. Mar 29, 2014 at 7:37 PM
    #3368
    NYCO
    bOb
    Colorado
    dents & scratches
    Yea I was talking with jace about that for when he aligns the truck before we head out. See how much we can push it forward without throwing the camber out of whack.
    I'm hoping to get it a little better so when I run Moab rim at cruise I won't bind going up devils crack or the z turns. Those two can require turning and stuffing.
  9. Mar 29, 2014 at 7:40 PM
    #3369
    steezemcqueen
    steezemcqueen 4Runner Abuser
    Dylan
    Crawlarado
    1997 4Runner Turbo and 2006 Tacoma
    Unicorn fart injection system
    Those Five Stars are freaking sexy
  10. Mar 29, 2014 at 7:41 PM
    #3370
    NYCO
    bOb
    Colorado
    dents & scratches
    Yea they are :D
  11. Apr 4, 2014 at 12:24 PM
    #3371
    NYCO
    bOb
    Colorado
    dents & scratches
    brought the truck in for a quick alignment for the new tires...
    also had jace move my caster up a bit..give me a little extra space to play with for clearancing...
    spec caster is 2*...upper end of the spec range is 3*, so we stopped there
  12. Apr 6, 2014 at 11:53 AM
    #3372
    NYCO
    bOb
    Colorado
    dents & scratches
  13. Apr 6, 2014 at 12:30 PM
    #3373
    JLink
    Josh
    Ocean, NJ
    2 spare tires?
  14. Apr 6, 2014 at 12:31 PM
    #3374
    NYCO
    bOb
    Colorado
    dents & scratches
    Waiting for sale and no room in my place to put it :)
  15. Apr 6, 2014 at 12:32 PM
    #3375
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    3" ADS lift , Opened Exhaust, 33" Hankook, TRD Supercharger, URD Stealth 2.8" Pulley, URD CAI, UCON, DTLT, URD Y-Pipe, Demello Front Bumper, Total Chaos UCA, Satoshi Grill, Console Safe, Cobra 29 CB, Demello Sliders, DYI Rack, CVT Mt. Hood Tent, Rigid Industries LED in hood scoop, Bruteforce HC rear swingate bumper, Icom 5100A, Icom 7000, Alpine INE 920HD, Warn 8000m, 4x Inovations Skids, NItto 4.56 Gears, Diehard 31M Battery, Dual Battery Solar charge controller.
    Looks Awesome Bob! Thanks for the idea of where to mount the axe and shovel. :D
  16. Apr 6, 2014 at 5:11 PM
    #3376
    Gramps
    Gramps
    07 TRD DC 4x4
    That's his "sedan" donut. :D
  17. Apr 7, 2014 at 5:38 AM
    #3377
    NYCO
    bOb
    Colorado
    dents & scratches
    my truck feels whole again :D
    some new sawtooth kickouts installed late last night...finally punched the clock on the day at 9pm...but they're on :woot:
    i'll get some better pics later and yes i still need to paint them
    901397B9-7850-48D5-881F-EA4EF227A3EF_zps_e7dce52f079aad598ec2640a10c57f1d992eef23.jpg
    ABF99825-C473-458F-85FA-5664C1BAE61B_zps_dc43c3ca152ac50b57b3d230c5d773ac0de6775b.jpg
    69EF6F11-A242-40DB-9AA4-DBC07BC64D49_zps_3b849c2c349f246b9810654b9f6ae682b92c02be.jpg
    same length as the old ones, but we f'd up installing the first ones and had them too far forward...to get the larger tires in, the sliders had to go..
    so the mounting is much better this time around...basically from the start of the flare front and back is the coverage
    the angle is a bit more than the last ones, so they are tucked in there a bit more...we also added a bit to the kickout so we don't lose the coverage after the increased angle..
  18. Apr 7, 2014 at 5:47 AM
    #3378
    NYCO
    bOb
    Colorado
    dents & scratches
    thanks...this way they're up and out of the way but still accessible
    worked out good where they are at the level of my MaxTrax, so i didn't loose any ceiling height really..
    i added links to the mounts i used in the post above with the pics
  19. Apr 7, 2014 at 8:27 AM
    #3379
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    Cool thanks for the links!
  20. Apr 7, 2014 at 8:50 AM
    #3380
    la0d0g
    running for the hills
    For crawling not hauling
    So the inner diameter of that Tusk holder will accommodate 1 3/4" - 1 7/8" tubing?
