NYCO's '06 Boosted Blue Betty
Discussion in '2nd Gen. Builds (2005-2015)' started by NYCO, May 18, 2011.
  1. Jun 12, 2014 at 7:20 AM
    #3641
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    more from rock therapy...
    behind the rocks
    see the big rock in front of my passenger tire?
    well i broke it in half :D
    TC lowers did their job well as it was lodged in there as i drug it across the rocks
    had another go at upchuck
    but shut me down again...being a heavy beast with a stick led me to back down and save it for another day...my clutch hates me enough as it is :D
    at balcony arch
  2. Jun 12, 2014 at 7:26 AM
    #3642
    NYCO
    bOb
    Colorado
    dents & scratches
    dome plateau
  3. Jun 12, 2014 at 7:27 AM
    #3643
    NYCO
    bOb
    Colorado
    dents & scratches
    then we played on this thing
    where i broke a dude's collar bone :eek:
    then found water
  4. Jun 12, 2014 at 7:32 AM
    #3644
    NYCO
    bOb
    Colorado
    dents & scratches
    saturday before the raffle we went out to explore flat iron mesa area
    some fun obstacles throughout
    including the chute
    with the proper exit looking gnarly up close (much taller than it appears in this photo)
    there is a bypass to the whole chute area, then there is a bypass up the side of the chute which i took...some ledges along an area going up the side
    from there to the intersection of a co rd that cuts through the trail, there wasn't much...we skipped the second half so we could have some time to shoot stuff and still make it back in time to setup...
    definitely need to make it back there!
  5. Jun 12, 2014 at 7:34 AM
    #3645
    NYCO
    bOb
    Colorado
    dents & scratches
  6. Jun 12, 2014 at 8:16 AM
    #3646
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Nice build. Maybe I missed someone asking but how do you like your new Boss springs compared to the old Dakar's now that you've had them for a few months?
  7. Jun 12, 2014 at 8:33 AM
    #3647
    NYCO
    bOb
    Colorado
    dents & scratches
    it will depend on your setup...
    keep in mind these are a 2" lift leaf pack versus a 2.75"/3" lift pack from Dakar
    and these were not designed for a shackle flip
    that being said, these allowed me to keep my height down to a 2.5"ish lift which i like. with the bed rack and RTT up there, keeping it low helps..plus 2.5" & 35s looks bad ass IMO :D
    with the shackle flip, the leaf pack is flat at ride which is not ideal...but with a reverse shackle (factory) setup, this should not be the case...
    but they flex very well on the trail...with the shackle flip, i am able to utilize the full 11" of travel from these bilsteins...i did not get that with the dakar pack
    although they are for a 2" lift, the leaf pack is longer than the dakar pack which is why i think they are able to pull better numbers...
    driving around they give a great ride...
    my big downfall on my rear setup is my uptravel, but that's a problem i will face if i keep my lift low like it is...
    unfortunately, the best option for me going forward is a custom leaf pack to work better with the shackle flip if i stay that route...i keep getting pushed back into a reverse shackle setup though which would help with my leaf options
  8. Jun 12, 2014 at 8:49 AM
    #3648
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Who made your shackle flip? Isn't ATO's adjustable or did you get the early version?
  9. Jun 12, 2014 at 8:54 AM
    #3649
    steezemcqueen
    steezemcqueen 4Runner Abuser
    Dylan
    Crawlarado
    1997 4Runner Turbo and 2006 Tacoma
    Unicorn fart injection system
    Eff that. Just link it. :spy:
  10. Jun 12, 2014 at 9:02 AM
    #3650
    NYCO
    bOb
    Colorado
    dents & scratches
    adjustability isn't the issue, it's the difference between the two mounting positions and how the shackles work...as with any leaf pack you see with the 2nd gens, they are designed to work with the reverse shackle design
    load capacity and spring rates are different when flipping the shackle mounts...
    i do have the old ATO kit, but i had two kits...one was for the Dakar short pack and the other was for a longer leaf pack which works good with these leafs...shackle angles are good at ride height and i get full motion with drooping out without inverting..so there's not much i could change with the shackle flip to make it any better..
  11. Jun 12, 2014 at 9:03 AM
    #3651
    NYCO
    bOb
    Colorado
    dents & scratches
    find me a money tree to support this movement and i'm down :D
    till then... :(
  12. Jun 12, 2014 at 9:21 AM
    #3652
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    You still have your reverse mounts or did they get jacked up taking them off? Might check with Brady if you're looking for some, he might still have his. Not sure if you'd want to put the stock back on tho when you could use measurements and cut some nice mounts out of 1/4 or something... If you get me calipered measurements on the mounts i could possibly draw something up wit ACAD :D
    BTW, just spent a bunch of my morning off looking thru all the pictures you've been dumping! SO many great shots!
  13. Jun 12, 2014 at 9:29 AM
    #3653
    NYCO
    bOb
    Colorado
    dents & scratches
    i should show you the pre-rock therapy album in full, only the shots i included in my truck album are public..it'll get you inspired to head down there and explore some more :D
    it would be a great idea if someone could come up with a better design for the reverse shackle design....
    i know the SUA setups have beefier setups, but they hang lower than the factory mounts, so it helps but hurts...plus you have to get the rest of the SUA package which $$
    but a nice factory replacement mount would be nice
  14. Jun 12, 2014 at 9:44 AM
    #3654
    SconnieHailer
    Marc
    right!? i'd like one at some point. I know i'm staying reverse shackd. If I get a drawing done i'll see if I can get CBI to cut out the pieces for me on their table and i'll take a trip up there and have em slapped on. I'll let them know you might want a set too and it may help :D
  15. Jun 12, 2014 at 10:17 AM
    #3655
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Hey Bob isn't behind the rocks across the street from Bfe? We explored over there and found picture frame arch but nothing you posted looks familiar. I suppose we might not have gone far enough :notsure:
    Nvm answered my own question.
    http://www.everytrail.com/guide/behind-the-rocks-4x4-trail/map
    Looks like we'll have to explore there again next year
  16. Jun 12, 2014 at 10:22 AM
    #3656
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    ALCAN...
  17. Jun 12, 2014 at 10:27 AM
    #3657
    Gramps
    Gramps
    07 TRD DC 4x4
    Bob the photos are awesome. I am curious do you take all of your shots in HDR? Just wondering on that and also how are you "burning" in the sky on some of those shots? Is that a function of PS?
  18. Jun 12, 2014 at 10:35 AM
    #3658
    NYCO
    bOb
    Colorado
    dents & scratches
    you'll notice on the file names whether they are HDR or not...
    with things that are moving, HDR is not an option...so i did HDR anytime i could, but the action shots are all non-HDR.
    we also had two cameras out there...my 60D was primarily all shot in HDR with exception to the dunes session...kayla had the t1i and shot primarily non-HDR
  19. Jun 12, 2014 at 10:37 AM
    #3659
    NYCO
    bOb
    Colorado
    dents & scratches
    i still haven't found the "proper" entrance i think...there is a hill climb that is talked about in the descriptions but i never saw anything that seems to fit the descriptions...but it seems like i see "BTR" signs from the beginning, so idk...i know we hit most of the beginning (except the first hill climb) then head off at the "prostitute rock" or "lone rock" where balcony and picture frame arches are...
  20. Jun 12, 2014 at 10:40 AM
    #3660
    Gramps
    Gramps
    07 TRD DC 4x4
    Cool thanks. I have the HDR option on mine but I am still experimenting with it. Now from the sounds of it I have to buy a second camera too. :p
