NYCO's '06 Boosted Blue Betty
Discussion in '2nd Gen. Builds (2005-2015)' started by NYCO, May 18, 2011.
  1. Aug 1, 2014 at 9:11 AM
    #3761
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    Did you fallow the bedding process of EBC's website? It takes like 1000 miles. lol
  2. Aug 1, 2014 at 9:27 AM
    #3762
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I personally did not. I wore their coatings off as fast as i could then drove around for about 600miles using them normally then did their 10 stops in a row from 60-10mph in order to heat bake them.
  3. Aug 1, 2014 at 9:43 AM
    #3763
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea but...yours are bigger now :D
    Jealous of the trip. Makes me want to go back there
  4. Aug 1, 2014 at 11:30 AM
    #3764
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    i went the 500 mile route...first 100 or so very light, then normal driving through 500. then the 10 60-0mph stops.
    basically just took it easy for the first 500 then said, enough is enough
  5. Aug 1, 2014 at 11:31 AM
    #3765
    NYCO
    bOb
    Colorado
    dents & scratches
    i still have to finish the edits from the trip :eek:
  6. Aug 1, 2014 at 11:32 AM
    #3766
    Blackdawg
    Monte
    Wyoming/St. Louis
    Fun to let the photos trickle though :cool:
  7. Aug 1, 2014 at 11:34 AM
    #3767
    NYCO
    bOb
    Colorado
    dents & scratches
    slow day at work today too...i should have brought my HD to work and finish up..
    i finished all the stitching and HDR processing, i just need to finish the final edits in lightroom, then watermarks..
  8. Aug 1, 2014 at 11:35 AM
    #3768
    NYCO
    bOb
    Colorado
    dents & scratches
    then buzz through some video edits from a recent dirt bike trip in Hall Valley
  9. Aug 1, 2014 at 11:36 AM
    #3769
    Blackdawg
    Monte
    Wyoming/St. Louis
    You don't just watermark with LR? You can. Very easy to do including custom ones. Plus export directly to Flickr. No extra copies.
  10. Aug 1, 2014 at 11:38 AM
    #3770
    NYCO
    bOb
    Colorado
    dents & scratches
    i finish with LR at 100%, then reprocess those at 50-70% with watermark within LR
  11. Aug 1, 2014 at 12:04 PM
    #3771
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh. I just export directly to Flickr with water marks and it does resizing automatically.
  12. Aug 6, 2014 at 2:14 PM
    #3772
    NYCO
    bOb
    Colorado
    dents & scratches
    small update....swapped out my Camburg uniballs on the UCAs over the weekend..
    old
    they had quite a bit of play in them..they were loud as FUCK too
    turned out to be beneficial to remove the UCAs for the swap...too much of a pain to try and swap out while still on the truck..
    find some strong c-clip pliers..remove the c-clip...
    put the UCA on a 4x4, find a sock that'll fit inside the UCA hole to press out the old uniball..then give her hell til she pops out
    we used some brake clean and a rag to clean the inside of the hole along with a pick to clean out the grove the clip sets in...
    throw some bearing grease on the outside of the new uniball...set the new uniball in place..make sure it's set to go in straight before you start to press it in...
    eric had an old pipe laying around which lined up great around the outside of the uniball...set that on the uniball and hammered away...press the new one in until you get clear access to the c-clip groove..
    get those strong pliers again and set the new clip in...take a flat head screwdriver and hammer to tap the new clip in to make sure it's set
    then reinstall the UCA and torque :cheers:
  13. Aug 11, 2014 at 10:11 AM
    #3773
    Round II
    Round II Member #12005
    Damn Warbucks I would have thought you would just purchase new UCA's....:D
  14. Aug 11, 2014 at 6:19 PM
    #3774
    sander1036
    sander1036 Well-Known Member
    Snack Food Capital of the World
    02 SR5 TRD Double Cab 4x4
    THULE Roof Rack, Color matched grille w/ GrilleCraft, Toytec Ultimate, 33 x 12.5 Duratracs, Bushwacker Cut Out Flares, Cvt Mt Shasta, Cvt Awning, LEER Cap
    Hey Bob, I was just going through my Moab pics from last year... Found this if you want it
  15. Aug 11, 2014 at 7:22 PM
    #3775
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    thats a good picture!
  16. Aug 13, 2014 at 12:32 PM
    #3776
    NYCO
    bOb
    Colorado
    dents & scratches
    that is a great pic! thanks :cheers:
  17. Aug 14, 2014 at 1:26 AM
    #3777
    skygear
    skygear                    
    Details on the Airflow install, Donaldson, etc? I was talking to a local overlander and he told me NOT to get a prefilter due to improper air flow vs the forced air flow. Noticed any issues?
  18. Aug 14, 2014 at 7:41 AM
    #3778
    NYCO
    bOb
    Colorado
    dents & scratches
    prefilter vs open hat....definitely better airflow with open hat
    does it make a difference? slightly yes
    does the prefilter help eliminate 99% of dirt, dust and other debris before hitting the air filter? most definitely
    do i have to worry about heavy rain and/or snow getting down the tube and soaking through my filter and fucking with my MAF sensor with the prefilter? definitely not...with the open hat? yes
    does the prefilter still perform better than factory setup? yes
    i actually have my open hat behind my seat so i can swap them back and forth easily...unscrew the clamp, take out set screw and swap.. pretty easy to go between the two...
    airflow or safari, i would go with the 10" safari for airflow purposes...they offer two inlet diameter options that would work "good" with each one
  19. Aug 14, 2014 at 8:16 AM
    #3779
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Should I poke the bear and talk about how I don't have those water issues with my Safari open hood?:D
  20. Aug 14, 2014 at 8:21 AM
    #3780
    NYCO
    bOb
    Colorado
    dents & scratches
    well you never drive...especially in heavy snow storms :eek:
