NYCO's '06 Boosted Blue Betty
Discussion in '2nd Gen. Builds (2005-2015)' started by NYCO, May 18, 2011.
  1. Oct 15, 2014 at 5:59 PM
    #3961
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Sweet I will have to take a listen soon!
  2. Oct 15, 2014 at 6:02 PM
    #3962
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Never heard of or experienced any issues like that with the dclb but I guess if it ever happens maybe I won't freak out as much.
  3. Oct 17, 2014 at 11:46 PM
    #3963
    PPansini10
    PPansini10 Well-Known Member
    Paul
    NJ
    09' DCSB 4x4 TRD Sport
    Hey man, do you have any close ups of the LED bar on the ARB. Im interested in putting a 30in on mine
  4. Oct 18, 2014 at 6:31 PM
    #3964
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    like this?
    990340A8-AE21-4A4F-AFB8-C058C182770B_zps_9a02ee0485590f235178b1c97889c0a62a569da7.jpg
  5. Oct 18, 2014 at 6:34 PM
    #3965
    NYCO
    bOb
    Colorado
    dents & scratches
    the mounts are on the outside of the triangle openings. the bar itself has to slide through the openings then fits just inside the vertical flat sections. you'll have to cut out the rubber for the mounts and drill through top. the nut and bolt
  6. Oct 18, 2014 at 6:34 PM
    #3966
    NYCO
    bOb
    Colorado
    dents & scratches
    I can get another pic if needed
  7. Oct 18, 2014 at 9:24 PM
    #3967
    PPansini10
    Paul
    NJ
    Yeah thats what i was thinking.. i wonder if a cradle mount would work, if i still trimmed the rubber too. I don't mind drilling through the bumper, i would just rather not if i can find another way. Is the led bar a 30" or a 32"?
  8. Oct 18, 2014 at 9:26 PM
    #3968
    NYCO
    bOb
    Colorado
    dents & scratches
    total width is >30. I'll measure tomo if I can remember
  9. Oct 18, 2014 at 9:28 PM
    #3969
    PPansini10
    Paul
    NJ
  10. Oct 19, 2014 at 4:35 PM
    #3970
    NYCO
    bOb
    Colorado
    dents & scratches
  11. Oct 20, 2014 at 9:18 AM
    #3971
    PPansini10
    Paul
    NJ
    Thats perfect man, thanks
  12. Oct 20, 2014 at 2:53 PM
    #3972
    Round II
    Round II Member #12005
  13. Oct 20, 2014 at 2:58 PM
    #3973
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    :eek:
    Me either. I know my sliders and skids stiffen up my frame a lot though.
  14. Oct 21, 2014 at 1:11 PM
    #3974
    NYCO
    bOb
    Colorado
    dents & scratches
    finally getting around to modifying and installing my bushwackers...
    got the rears on, still need some fine tuning for the cut lines and cap off the cut edge with some trim...
    front holes don't all line up as easily as the rear, but nothing a little drilling can't fix...going to see if i can get those in tonight and start trimming both F&R to match bumper lines a bit better...
    idea was to leave as much on as i could and cut back from there as needed..
    i'm hoping that the tires will tuck up in there so i don't have to make them as small as my last flares..
  15. Oct 21, 2014 at 1:14 PM
    #3975
    NYCO
    bOb
    Colorado
    dents & scratches
    for the hardware
    36 button head bolts, 72 nuts, 36 nylon washers, 36 flat washer and 36 lock washers :bananadead:
    nut and nylon washer is used as a spacer then washer, lock and nut on the inside of the fender...
  16. Oct 21, 2014 at 4:43 PM
    #3976
    JLink
    Josh
    Ocean, NJ
    Looks like they may stick out further than the stock ones?
  17. Oct 21, 2014 at 6:02 PM
    #3977
    NYCO
    bOb
    Colorado
    dents & scratches
    fronts are on and got some additional trimming done to match the bumper lines better. both F&R have the bottom lips cut off and use all factory holes except for one drilled hole each side up front.
    17FAF132-6506-4508-9C66-D16FF136C37D_zps_5389a3311d3705d7294ae812ca4769076413ae97.jpg
  18. Oct 21, 2014 at 6:04 PM
    #3978
    NYCO
    bOb
    Colorado
    dents & scratches
    yea another inch or so wider. tires still stick out slightly. will have to wait till morning for that photo. about even now with the edge of the tread.
  19. Oct 21, 2014 at 7:11 PM
    #3979
    PS78
    PS78 I like beer, I brew beer!
    Rancher
    2011 DCSB TRD OR
    to many to list, check the build thread
    NICE!!! looks great
  20. Oct 21, 2014 at 7:14 PM
    #3980
    JLink
    Josh
    Ocean, NJ
    Yea looks real good. Might need to do that, I've had a warning from a cop about the tires sticking out further than the fender flares.
