NYCO's '06 Boosted Blue Betty
Discussion in '2nd Gen. Builds (2005-2015)' started by NYCO, May 18, 2011.
  1. Feb 13, 2012 at 5:54 AM
    #381
    Namyo
    Namyo -
    25-186314 - 11" 5150 Crossflow - 11.50" - 16.50" - 27.99" - 175/60
    so that's the one? I need to get mines straight at sum point too...
  2. Feb 13, 2012 at 7:54 AM
    #382
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    yea, or the 5165 with the same lengths..talking with toytec and DSM on what they would recommend with my setup...
    DSM mentioned that bilstein is slowly getting out of production of the 5150s....
    but DSM recommended the Fox 2.0s and Toytec deals mainly with Bilstein, so i'm curious to see what they recommend with my length specs i gave them...
  3. Feb 15, 2012 at 7:08 AM
    #383
    NYCO
    bOb
    Colorado
    dents & scratches
    as if my days weren't busy enough...
    updated moab list
    . -U-bolt flip - DONE
    . -measure for rears - DONE
    . -Camburg UCAs - waiting on install
    . -OME 90000 nitrocharger front replacement with 10mm enhancer - need to order shocks and enhancer waiting on install
    . -Wheeler front bumps - waiting on install
    . -Fox 2.0 resi rears - working with dsm on a setup
    . -Wheeler rear bumps - backorder
    . -timing chain cover gasket replace
    . -rear brakes
    . -black out rear bumper
    . -rock light upgrade
    . -finish reverse light setup
    . -grease up short throw kit
    . -grease driveline
    . -clean air filter
    . -maf cleaning
    . -clean out truck, inside and out
    . -storage bins
    . -respool winch cable
    . -clean up wiring
    . -finish sirius wiring
    . -transmission skid?
  4. Feb 15, 2012 at 8:06 AM
    #384
    NYCO
    bOb
    Colorado
    dents & scratches
    piece of mind and also want to see how it is holding up..
    taking things apart and lube the piss out of it...with the 4.56 gears, i been shifting a whole lot more so it's been on my mind recently
  5. Feb 15, 2012 at 10:30 AM
    #385
    NYCO
    bOb
    Colorado
    dents & scratches
    so been working with marco at DSM on figuring out a good setup for my shocks...the bilsteins just didn't have many options that can compare to what the foxes offer...
    going with fox 2.0 resis with 10" travel..going to be approx 16"x26"...thinking of adding a couple washers at the top mount to push it down another 1/4-1/2" to give my extension a little more room
  6. Feb 15, 2012 at 10:34 AM
    #386
    NYCO
    bOb
    Colorado
    dents & scratches
    man tell me about it! got my eyes glued to your build to see how the upcoming projects turn out...i got another year left in my tires so i'll probably look into going to 34s or 35s when the time comes
  7. Feb 15, 2012 at 10:59 AM
    #387
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    One thing to look for when checking the shifter, is if the plastic white bushing, at the bottom of the shifter itself, is worn out or cracked. It will then cause poor shifting. Plus, if the rubber isolation in the middle of the shifter has a lot of years of use on it, it will make the upper half of the shifter wobble around, with to much play. Another member on here named Coupe, has a fix for that. He repairs them by replacing the rubber with a stronger flexible epoxy. Just something to keep in mind.
    I feel for you on the timing cover gasket fix. I will be doing that to mine this weekend. Not hard, but definitely not fun... :(
  8. Feb 15, 2012 at 11:46 AM
    #388
    mreimann
    mreimann Well-Known Member
    Denver, CO
    '15 double cab Limited
    Icon C/O, Fox 2.0, All Pro Expo 2.0 leafs, Total Chaos UCA's, Airflow snorkel, Custom Built Bed Rack, Pelfrey aluminum front bumper and IFS skid, All Pro aluminum rear bumper, SmittyBuilt winch. RTT
    One thing to watch out for when adding the washers on top the sock. I've got the all pro expo leaf pack and when the bump stop hits the frame, the shock is almost bottomed out. If your leaf pack is thinner than mine, the shock will bottom out before the leaf pack. And if you add washers on top the shock after that, it'll bottom out even sooner.
    just something to watch out for when you're installing everything
  9. Feb 15, 2012 at 12:29 PM
    #389
    NYCO
    bOb
    Colorado
    dents & scratches
    yea that has been a concern...when we measured, the collapsed length was at 18" from top mount to lower eye mount, so i should have 2" to play with, and with the wheeler bumps, the bumps should hit before the shock comes close to bottoming out. the washers will help keep the shock from fully extending. we measured 26" droop from top mount to eye, so the washer will help push the extended shock length past that 26" mark.
  10. Feb 15, 2012 at 4:32 PM
    #390
    Relik
    Relik Well-Known Member
    Eddy
    Thousand Oaks, CA
    '11 TRD Sport PreRunner-Auto-Magnetic Gray
    Bilstein 5100s (Front & ext. Rear), Eibach coils @ 0, MaxTrac 4" Spindles, Light Racing UCAs, 1/4" lean spacer, All-Pro 3" Standard leafs, u-bolt flip kit, SpiderTrax 1.25" wheel spacers, 33" (285/70/17) TreadWright Warden A/T tires, extended lines
    Remember that you will have a eyelet to stem converter for those shocks... I believe because the fox shocks are eyelets on both sides. That should add more length to the shock and maybe a lil more to check on colapsed. Don't know how much exactly, I've seen 1" tossed around on here but no sure numbers..I'm debating between the same shocks or 5150s too, its pretty much $100 more atleast...make sure to check the length with converter with DSM...
    Edit: If you figure out which shocks, 'The Parts Whore' (TPW) says that he's still doing his deal on shocks (king/fox/bilstein) for tax season, heres the link. I PM'ed him tho with no response yet. Seems to be good prices if they're the same as the GB.
    http://www.tacomaworld.com/forum/de...ate-suspenison-deals-no-group-buy-needed.html
  11. Feb 15, 2012 at 5:15 PM
    #391
    NYCO
    bOb
    Colorado
    dents & scratches
    Dsm sells stem mount Fox 2.0
  12. Feb 16, 2012 at 11:18 AM
    #392
    rossivey
    rossivey Well-Known Member
    North Texas
    06 Black DCLB 4x4
    Where did you get the switches or did they just come with the lights? I'm looking at adding some lights to mine and I want to use the same style switches in the blank ports. They look awesome by the way!
  13. Feb 16, 2012 at 11:40 AM
    #393
    NYCO
    bOb
    Colorado
    dents & scratches
    thanks...
    company called OTRATTW (Over The River and Through The Woods)
    http://otrattw.com/
    great company, helpful customer service and great products
    i now have 3 of their switches in that location...took out the factory fog switch that was unused
  14. Feb 16, 2012 at 3:53 PM
    #394
    NYCO
    bOb
    Colorado
    dents & scratches
    :playball:
    i'm sick of working so much and having parts laying around!
    throwing in the front bumps saturday so i can test them out wheelin sunday...
    anxiously awaiting word on my foxes and when they'll be in my hands..then those will go on next...
    going to try and knock out a couple items on my moab to-do list until the front goes in...
    so until then.... :playball:
  15. Feb 16, 2012 at 4:20 PM
    #395
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    I no man im tryin to get everything done. We'll be good come may
  16. Feb 16, 2012 at 4:52 PM
    #396
    NYCO
    bOb
    Colorado
    dents & scratches
    i know...just excited for new suspension parts
    i have a lot of small things to keep me busy until then...not like we'll be wheelin much, except for this weekend, until spring
  17. Feb 17, 2012 at 11:36 AM
    #397
    rossivey
    North Texas
    06 Black DCLB 4x4
    so do they just fit snug in place after the filing? & did you just use the wiring kit that came with your lights? I plan on doing a off-road lights/fog lights combo on an Iron Bull Bumper so I'm definitely going to be getting some of these switches. Thanks for the info!
  18. Feb 17, 2012 at 12:30 PM
    #398
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Otrattw x2.
    Great customer service!!
  19. Feb 17, 2012 at 1:15 PM
    #399
    NYCO
    bOb
    Colorado
    dents & scratches
    yup...keep testing it out while you're filing so you don't go too far, but if you do it right they stay in there nice and snug
    wire up like you would any other switch with a light...battery, light and ground
    the on-off-on switches get more complicated but if you go that route, ask for a diagram and they will provide you with a very helpful diagram
  20. Feb 21, 2012 at 1:19 PM
    #400
    NYCO
    bOb
    Colorado
    dents & scratches
    Foxes are on the way :goingcrazy:
