NYCO's '06 Boosted Blue Betty
Discussion in '2nd Gen. Builds (2005-2015)' started by NYCO, May 18, 2011.
  1. Dec 10, 2015 at 7:54 AM
    #5361
    jztacoma
    jztacoma Trust me I’m an Engineer
    Upstate NY
    2024 Tacoma TRD Offroad
    Semi Stockish
    Mine aren't that bad. Pushing 40k on my Camburgs and now going into the 2nd winter on them. Some surface rust I clean off when I see it. But I spray them almost every day in the winter and every time I fill it up in the summer with some liquid wrench (has the same teflon type material that the balls have). Seems to keep it noise free. But might have to check this weekend for any movement since I'm getting a popping sound somewhere
  2. Dec 10, 2015 at 9:59 AM
    #5362
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    2 rebuild kits @ 180$ a piece plus the press tool @ 50$
    It's not cheap to rebuild these at all. TC confirmed that 40-50k is the avg replacement time.
  3. Dec 10, 2015 at 10:02 AM
    #5363
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    yup...maintenance is the worse part about uniballs
  4. Dec 10, 2015 at 10:04 AM
    #5364
    2ndGenJonny
    Jon
    Gilbert, AZ
    My bushings are still in great shape so I don't think that will be needed. The only shit part is removing them to rebuild them.
    I should've done this before I installed them on the new rig. :pout:
  5. Dec 10, 2015 at 10:07 AM
    #5365
    NYCO
    bOb
    Colorado
    dents & scratches
    it's doable to replace the uniballs with the arms still on the rig...uppers are so easy to take off, it really doesn't save much time, but lowers can be left on so you don't have to worry about jacking with your alignment
  6. Dec 10, 2015 at 10:09 AM
    #5366
    2ndGenJonny
    Jon
    Gilbert, AZ
    How did you press the balls? Just use a C clamp or something? Or rent a puller from Vatozone?
  7. Dec 10, 2015 at 10:09 AM
    #5367
    jztacoma
    Upstate NY
    Semi Stockish
    Kind of a relief to know you can do the re-build while the arms are still on the truck, had a bitch of a time getting the stock uppers off and the new ones on
  8. Dec 10, 2015 at 10:54 AM
    #5368
    NYCO
    bOb
    Colorado
    dents & scratches
    got a kit from harbor freight as well as the TC uniball cups
    combination of impact gun and ratchet...gun to get them out and ratchet to get them in (hard to get them in straight, so sometimes you gotta go slow)
    not a perfect way, but it did the job...
    when i first did the UCAs, we took them off and used a block of wood along with a socket to knock the old ones out and press the new ones in
    so if you take the arms off, you don't really need anything special...the TC cups help as they're the right size, but if you have a large enough socket, that'll work
  9. Dec 10, 2015 at 10:56 AM
    #5369
    2ndGenJonny
    Jon
    Gilbert, AZ
    Thanks! After I finish the rear setup I'll save up for the rebuilds
  10. Dec 13, 2015 at 5:33 PM
    #5370
    NYCO
    bOb
    Colorado
    dents & scratches
    i'll have some 1:1 pics coming at some point, but just finished up this edit of the 1:10 Blue Betty
    got the body finished up and some new suspension components so i took her to the beach to stretch out her legs...
    https://youtu.be/SO1gHhOYZUs
  11. Dec 13, 2015 at 7:10 PM
    #5371
    NYCO
    bOb
    Colorado
    dents & scratches
    well flickr is not cooperating so i'll be stealing from my FB...
    from last weekend's trip around Moretown/Waitsfield area...
    the day started off fairly clean
    saw some frosty sections as we climbed
    then the sun started to burst through
    climbing through Bald Eage
    reasoning behind our naming the trail Bald Eagle
    didn't get too many action shots, but it was actually a fun trail with some fun obstacles and a really off-cambered section near the end (maxed out around 35*)..after the steep sections, jordan slipping around getting back to flat ground
    just2wd and SconnieHailer like this.
  12. Dec 13, 2015 at 7:18 PM
    #5372
    NYCO
    bOb
    Colorado
    dents & scratches
    then we popped over to Waitsfield gap to see if we could get all the way through...
    found a spur that brought us up to a great view point over the Mad River valley
    overlooking Sugarbush and Mad River Glen resorts
    down was the easy part...
    it was getting back up that was the shitty part...the trail was gated off at the bottom, so we had to climb back up the slick trail...this section was the worst muddy section..locked F&R i just sank digging some deep ruts
    locked F&R i was able to line all 4 maxtrax on the downhill track and work my way up..
    jordan on the other hand did not have the luxury of locking up...
    luckily he had 4 treds to add to my 4 maxtrax
    so slowly but surely we worked him up the deep section then again a little ways up...
    first hand review on the maxtrax vs treds.....spend the money and get maxtrax!
    the treds did the job, but everytime he went over them, i heard them cracking more and more...plus the maxtrax seem to lay down better on uneven terrain...
  13. Dec 13, 2015 at 7:19 PM
    #5373
    NYCO
    bOb
    Colorado
    dents & scratches
    then of course, what's a trip through Vermont without some covered bridges...
    went through 3 on the way down the mountain into Northfield Falls
  14. Dec 14, 2015 at 4:36 AM
    #5374
    jztacoma
    Upstate NY
    Semi Stockish
    Went to college in Northfield, seeing the bridges makes me miss Vermont a lot :thumbsup:
  15. Dec 14, 2015 at 8:53 AM
    #5375
    NYCO
    bOb
    Colorado
    dents & scratches
    i know what you mean...any time i see pics from areas in the west i used to frequent i get that feeling
  16. Dec 14, 2015 at 9:48 AM
    #5376
    2ndGenJonny
    Jon
    Gilbert, AZ
    This pic should really make you miss the grand views up in the Rockies
  17. Dec 14, 2015 at 10:04 AM
    #5377
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    I miss it and I've never even been there
    2ndGenJonny[QUOTED] likes this.
  18. Dec 14, 2015 at 10:21 AM
    #5378
    NYCO
    bOb
    Colorado
    dents & scratches
    wait there's mountains in this pic?
  19. Dec 14, 2015 at 10:27 AM
    #5379
    steezemcqueen
    steezemcqueen 4Runner Abuser
    Dylan
    Crawlarado
    1997 4Runner Turbo and 2006 Tacoma
    Unicorn fart injection system
    Sure are. Not rocky though
  20. Dec 14, 2015 at 10:43 PM
    #5380
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I like where this thread is going :cool:
    yea shitting thing about uniballs is the short life. Ball joints win there. Kinda glad my lowers still are ball joints.
