NYCO's '06 Boosted Blue Betty
Discussion in '2nd Gen. Builds (2005-2015)' started by NYCO, May 18, 2011.
  1. Sep 10, 2012 at 10:50 AM
    #821
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    got my maf calibrator re-mapped...had issues connecting to the ecu..
    talked with gadget and he pointed me in the right direction..
    issue was with my usb>serial...on a quick search in google, brought me to a tech writeup done by split second and they mentioned that these usb>serial connections have drivers that need to be installed...well i looked in the box and sure enough, a driver cd, a mini cd, but it had what i needed..
    just plugged in and connected just fine once i found my Com port (mine went to Com 8)..opened my fuel map and wrote to the ECU...hopefully that did it
    started it up and the startup ran smooth (start up cycle runs on an open loop)..so that's a start...guess i'll run WOP on the way home and see how she runs..
  2. Sep 10, 2012 at 10:56 AM
    #822
    NYCO
    bOb
    Colorado
    dents & scratches
    so glad i got that figured out...
  3. Sep 10, 2012 at 10:58 AM
    #823
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I had the same issue, first time I used a USB to serial cable. Felt like such a dummy. All good after that though.
    Had a chance to drive it around and see how it does yet?
  4. Sep 10, 2012 at 11:04 AM
    #824
    NYCO
    bOb
    Colorado
    dents & scratches
    not yet...just started it up to make sure shit didn't blow up
    can't wait to really see how the short tubes feel when i hit it harder this time...i was reluctant in the morning due to the fuel maps being tuned for my prior setup..
    i'll have to keep an eye out for more maps to see if anyone has one more tuned to my full setup..right now i'm back to the stock setup from gadget..
    not sure if having thorley's short tubes and a magna flow cat back would change things at all..or the fact that i live at 6000ft and frequent the mountains weekly between 8000-10000ft and occasionally the truck will see 11-12k
  5. Sep 10, 2012 at 12:34 PM
    #825
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    So call me a stalker but did you ever order those replacement CV's from CVJ?
  6. Sep 10, 2012 at 12:36 PM
    #826
    NYCO
    bOb
    Colorado
    dents & scratches
    i have one installed right now when i had a boot go, and i have one as a spare that i got off the GB a while back..
  7. Sep 10, 2012 at 12:41 PM
    #827
    NYCO
    bOb
    Colorado
    dents & scratches
    WHERE THE FUCK IS THE UPS GUY!!!
  8. Sep 10, 2012 at 12:44 PM
    #828
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    Nice. Were you able compare the articulation from your stock CV to the CVJ one? Have you wheeled with it sense? How is it holding up? Is it "maintenance free"?
    Just getting info because I am currently trying to piece together a spare parts stash and I like this option compared to Autozone shiz.
  9. Sep 10, 2012 at 1:01 PM
    #829
    NYCO
    bOb
    Colorado
    dents & scratches
    yea, i've wheeled with it..
    it's a toyota axle that is just rebuilt. so there is no difference really between the OEM and the CVJ..the CVJ has their own boots which is the main difference, but i have not noticed a difference at all...
    i would definitely go CVJ over autozone or napa anyday! rebuilt OEM vs aftermarket crap? not even close..
  10. Sep 10, 2012 at 1:28 PM
    #830
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    second that^ less fins on the boots mean fins arent touching each other as much= less likely hood of torn boots
  11. Sep 10, 2012 at 1:28 PM
    #831
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    Ok that's kind of what I am thinking too. Thanks for the info.
  12. Sep 10, 2012 at 2:40 PM
    #832
    NYCO
    bOb
    Colorado
    dents & scratches
    UPS finally showed up :spy: :D
  13. Sep 10, 2012 at 3:00 PM
    #833
    Round II
    Round II Member #12005
    I have been saying the same thing all day!:confused:
  14. Sep 10, 2012 at 3:32 PM
    #834
    NYCO
    bOb
    Colorado
    dents & scratches
    oh yea? what is the brown man bringing you this time?
  15. Sep 10, 2012 at 3:42 PM
    #835
    Round II
    8 tires or two sets of four. I'm pretty sure he hates me as its not just an easy drop off. When he dropped of my Demello sliders he asked what the hell I was building in there.:D
  16. Sep 10, 2012 at 3:46 PM
    #836
    NYCO
    bOb
    Colorado
    dents & scratches
    hahaha...maybe you should give them a gift card for the holidays for putting up with your shit..my UPS guy knows me by name in the office building..most all packages that come to the office are for one of my projects
    you moving up in size?
  17. Sep 10, 2012 at 3:49 PM
    #837
    Round II
    Nah keeping with 33's just one set for the trails and some AT's for the street. I need to get another set of wheels just not sure what I'm going with yet. Most likely just another set of enduro's?
  18. Sep 10, 2012 at 3:54 PM
    #838
    NYCO
    bOb
    Colorado
    dents & scratches
    they look nice for sure... i was thinking at one point of going down to 16" mickey classic beadlocks
    but i may stay with 17s when the time comes for new tires...
  19. Sep 10, 2012 at 3:58 PM
    #839
    Round II
    I must have killed my alignment in Moab this year cause it destroyed a set of brand new Mickey Thompson MTZ's on the drive back. They got louder with each 1000 miles we drove.
  20. Sep 10, 2012 at 4:01 PM
    #840
    NYCO
    bOb
    Colorado
    dents & scratches
    should have hit cliffhanger with us...would have straighten it right out :laugh:
