NYCO's '06 Boosted Blue Betty
Discussion in '2nd Gen. Builds (2005-2015)' started by NYCO, May 18, 2011.
  1. Oct 14, 2012 at 8:35 PM
    #921
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    Just be careful with the power-washer once and edge lifts it's all over for the vinyl.
  2. Oct 14, 2012 at 8:38 PM
    #922
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    good point.... guess the best solution is to not wash it again :D
  3. Oct 14, 2012 at 8:41 PM
    #923
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Perfect who needs paint anyway!
  4. Oct 15, 2012 at 7:18 AM
    #924
    NYCO
    bOb
    Colorado
    dents & scratches
  5. Oct 28, 2012 at 9:40 AM
    #925
    NYCO
    bOb
    Colorado
    dents & scratches
    busy day yesterday....
    finished off the CMC and took care of my pinch weld...cut and beat the weld then covered with some black silicone...also cut some more metal back to bring things back to the same depth...while i was in there, i also trimmed some more of my flare back...covered the seams on the CMC with some JB weld to smooth the corners off and fill the gaps from the welding
    after that project was under my belt...took on some mods to kayla's murano
    project HID fogs: factory fog housings from rockauto & DDM tuning HID kit
    goal was to use the HID kit to get around having to work with the factory fog wiring which would require buying a new lever that has the fog switch in it...so idea was to tie the low beam wire into a relay to trigger the lights..
    all was fine, lights worked as planned, until we went to go pick up chinese...truck didn't want to start (attributed this to the bad connection that the terminal "savers" caused, so i removed those) and the RH low beam didn't work (also meant the fogs didn't either because i tapped into that light)
    trouble shooting here...http://www.tacomaworld.com/forum/li...-dead-fog-light-tapping-trouble-shooting.html
    found out the light went out because of a blown fuse...battery also ended up crapping the bed finally this morning which gave us a dead truck this morning....
    so new battery, replaced fuse and used the running lights as my new trigger for the relay..truck is up and running!
    also trimmed the factory plastic fog covers that came with the truck into black rigs to accent the fogs..
    fogs in with accents
    light output
    was up til 130am last night trouble shooting and figuring out the fuse issue, and finally wrapped things up this morning after i got the new battery and fuse in...
    time for a beer :cheers:
    yes it's only 1040am, but i need a damn beer after that shit
  6. Oct 28, 2012 at 10:47 AM
    #926
    Kappes03
    Kappes03 Legend of the UG
    Colorado
    2014 Tundra CM
    Hey it's afternoon here, I'll drink one with you haha
  7. Oct 28, 2012 at 11:20 AM
    #927
    NYCO
    bOb
    Colorado
    dents & scratches
    cheers bud...this one's for you and your new adventure coming up
  8. Oct 28, 2012 at 11:34 AM
    #928
    Kappes03
    Colorado
    2014 Tundra CM
    Hell yea man I appreciate it!
  9. Oct 28, 2012 at 1:29 PM
    #929
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Wait battery died in Murano or Taco? Didn't you get a yellow top in the taco?
  10. Oct 28, 2012 at 1:31 PM
    #930
    Gramps
    Gramps
    07 TRD DC 4x4
    Cutting looks good in the fender well. Fogs look great!
  11. Oct 28, 2012 at 1:44 PM
    #931
    NYCO
    bOb
    Colorado
    dents & scratches
    in the morono
  12. Oct 28, 2012 at 1:45 PM
    #932
    NYCO
    bOb
    Colorado
    dents & scratches
    :thumbsup:
    hopefully won't be rubbing anymore no matter what the tire position :D
  13. Oct 28, 2012 at 1:49 PM
    #933
    Gramps
    Gramps
    07 TRD DC 4x4
    Yeah mine need to be cut just like you say here. Mine are like Bob's now and I am rubbing now that the LR UCA's are on and properly aligned. Just not going to get to it today. Plan on cutting all the way up to the next mount and about an inch in.
  14. Oct 28, 2012 at 1:51 PM
    #934
    NYCO
    bOb
    Colorado
    dents & scratches
    that's where the cut starts...wanted to see if i can keep that lower mount in there for "support"
    we'll see how long it stays there
  15. Oct 28, 2012 at 1:59 PM
    #935
    Gramps
    Gramps
    07 TRD DC 4x4
    I bet until just after you get 35's. :D
  16. Oct 28, 2012 at 2:14 PM
    #936
    NYCO
    bOb
    Colorado
    dents & scratches
    last trip out i managed to rub up near the second mount up which brought about cutting up higher too...idea was to cut down the amount the plastic sticks out near those points...
    can't wait to see the homer flares mounted up!
    his bushwacker hybrid turned out damn good
  17. Nov 5, 2012 at 9:14 AM
    #937
    NYCO
    bOb
    Colorado
    dents & scratches
    shot of the truck while checking out the rocky mountain arsenal wildlife refuge
    put more pics from the day up on my FB
  18. Nov 5, 2012 at 10:00 AM
    #938
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    :laugh:
  19. Nov 5, 2012 at 2:49 PM
    #939
    Round II
    Round II Member #12005
    Sorry about having them rolling around in the bed of my truck. hope he cuts out all the gouges...:eek:
  20. Nov 5, 2012 at 3:00 PM
    #940
    NYCO
    bOb
    Colorado
    dents & scratches
