NYCO's '06 Boosted Blue Betty
Discussion in '2nd Gen. Builds (2005-2015)' started by NYCO, May 18, 2011.
  1. Nov 16, 2012 at 7:26 AM
    #941
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    truck's going under the knife today :sick:
    having dr. nadeau cure my leaking gasket illness...
  2. Nov 16, 2012 at 7:47 AM
    #942
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Which gaskets are leaking?
  3. Nov 16, 2012 at 8:17 AM
    #943
    NYCO
    bOb
    Colorado
    dents & scratches
    timing cover gasket....
    i don't have a garage to work in over a weekend, so i'm having my buddy do the work at his shop...he's a toyota tech, so i know he'll take good care of it
    replacing the belt and water pump while it's apart too along with every gasket that he can see :D
  4. Nov 16, 2012 at 8:20 AM
    #944
    NYCO
    bOb
    Colorado
    dents & scratches
    for later....
  5. Nov 16, 2012 at 8:32 AM
    #945
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Have him trim the power steering pump where it fits between the head and the timing cover. As is, it puts a lot of separating pressure in the spot behind the power steering pump. That is the root cause of the timing cover TSB.
    Trimming that portion of the power steering pump where it through bolts between the timing cover and head, will alleviate the future potential of a leak.
  6. Nov 16, 2012 at 9:12 AM
    #946
    NYCO
    bOb
    Colorado
    dents & scratches
    interesting...
  7. Nov 16, 2012 at 10:22 AM
    #947
    NYCO
    bOb
    Colorado
    dents & scratches
    progress report...
    gettin' low
    where the magic happens
    also getting some shit cleaned up
  8. Nov 16, 2012 at 12:33 PM
    #948
    NYCO
    bOb
    Colorado
    dents & scratches
    i haz new steel ordered for mah belly!
  9. Nov 16, 2012 at 3:16 PM
    #949
    NYCO
    bOb
    Colorado
    dents & scratches
    somewhat recent pic at a meet & greet...it's actually clean :D
  10. Nov 16, 2012 at 5:39 PM
    #950
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    i disagree.... there is a nut on the top mount of the p/s pump that slides. when the pump is out, i put the bolt back in and tap it with a hammer pushing the nut back. then the pump slides right in when the covers back on. main cause: lack of fipg at head gasket area on right bank from factory.
  11. Nov 17, 2012 at 6:17 AM
    #951
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    :spy:
  12. Nov 17, 2012 at 8:16 AM
    #952
    NYCO
    bOb
    Colorado
    dents & scratches
    should be in next week :goingcrazy:
    i'll have 1/4" going from front the tcase now :D
    caught a deal with relentless that i couldn't pass up...already have someone willing to buy my all pro off me too that will help pay for the recent repairs on the truck.. :(
    went over budget on the repairs, but a lot of good things done to it to ease any concerns for a while :D
    jace once again has proven to be the man :cheers:
  13. Nov 17, 2012 at 10:39 AM
    #953
    Gramps
    Gramps
    07 TRD DC 4x4
    I agree with that. :beer:
  14. Nov 17, 2012 at 10:50 AM
    #954
    NYCO
    bOb
    Colorado
    dents & scratches
    truck is back and in great shape....thanks again to jace for taking care of her
    whole bunch of gaskets, seals and o-rings, new belt, water pump, t-stat and a vent hose...not to mention my tpms on all 5 tires are back in sync...had one throwing my computer off flashing my tire light at me which jace swapped out with a spare that i had..plus some new oil & filter
    next project....saving for some rubber....just stopped by discount and they have some 305s available, which i thought was odd seems how everyone talks about mt/r's being on backorder...
    planning on tinting the taillights tomorrow and putting a sockmonkey design over my 3rd that i have had hanging around for a while now...
    then some painting later this week! and i have some phillips HIDs coming in monday to swap in....4300K
  15. Nov 17, 2012 at 4:37 PM
    #955
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Different method of reaching the same end result. :thumbsup:
    I agree as well with the lack of FIPG on the timing cover in that particular spot. But to compound that, there is also a small portion of the timing cover, in that same area, which is recessed beneath the machined mating surface of the timing cover. Not sure why it was made like that from the factory, but it certainly doesn't help in keeping things sealed properly.
  16. Nov 18, 2012 at 9:11 AM
    #956
    lotsoftoys
    Jace
    Denver
    bunch of crap
    i know it? its almost like the machine made a mistake but i really doubt it.... iwanna know if that recessed section is on 07 and newer as well? how come only 05 06 leak?
    and not a problem Bob, glad shes clean. no more diapers needed for ur engine lol
  17. Nov 18, 2012 at 10:20 AM
    #957
    NYCO
    bOb
    Colorado
    dents & scratches
    taillight project..
    waiting for sealant to clear on the repair, then onto prepping the other side... hope I don't get to drunk before that :laugh:
  18. Nov 18, 2012 at 11:41 AM
    #958
    NYCO
    bOb
    Colorado
    dents & scratches
    update... on beer 3.. hopefully quality hangs in there :laugh:
  19. Nov 18, 2012 at 11:53 AM
    #959
    NYCO
    bOb
    Colorado
    dents & scratches
  20. Nov 18, 2012 at 12:56 PM
    #960
    NYCO
    bOb
    Colorado
    dents & scratches
    almost there
