NYCO's '06 Boosted Blue Betty
Discussion in '2nd Gen. Builds (2005-2015)' started by NYCO, May 18, 2011.
  1. Nov 19, 2012 at 11:58 AM
    #981
    nimrod712
    nimrod712 Well-Known Member
    Jonathan
    Hot Springs, AR
    '08 Taco TRD
    I don't know man. The 305 MTRs actually measure just under 34 by right around 12.3 or so on the truck. I imagine that is pretty close to actual measurements of some 315s...
    On mine it looks like I will definitely have to trim an inch or so out of the fender. On level ground they tear into the fender on the back of the wheel well. I haven't stuffed them yet, and I haven't tested on the back yet.
  2. Nov 19, 2012 at 12:01 PM
    #982
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    what size wheels are you running?
    i have 17x8 wheels
    edit...saw you'll be on 17x8.5, so you'll be slightly wider than me, but very close
  3. Nov 19, 2012 at 12:05 PM
    #983
    NYCO
    bOb
    Colorado
    dents & scratches
    MT/R
    305/70/17
    measuring rim 17x9
    measured dimensions 34.1x12.2
    adjusted for 17x8 should be 34.1x11.8
    315/70/17
    measuring rim 17x9.5
    measured dimensions 34.7x12.7
    adjusted for 17x8 should be 34.7x12.1
    duratrac
    285/70/17 (current tire)
    measuring rim 17x8.5
    measured dimensions 32.8x11.5
    adjusted for 17x8 should be 32.8x11.3
  4. Nov 19, 2012 at 12:06 PM
    #984
    NYCO
    bOb
    Colorado
    dents & scratches
    taken from Tirerack
    A tire's section width (also called "cross section width") is the measurement of the tire's width from its inner sidewall to its outer sidewall (excluding any protective ribs, decorations or raised letters) at the widest point. This measurement is made without any load placed upon the tire and after the tire has been properly mounted on its industry assigned measuring rim and has been inflated and reset to its test pressure after 24 hours.
    Because a tire's section width is influenced by the width of the rim upon which the tire is mounted, the correct industry assigned measuring rim width for the tire size being measured must be used.
    The width of a tire mounted on a narrow rim would be "narrower" than if the same tire was mounted on a wide rim. NOTE: because the overall diameter of a steel belted radial is determined by the steel belts, there is little, if any, change to the overall diameter of the tire due to differences in rim width.
    The industry rule of thumb is that for every 1/2" change in rim width, the tire's section width will correspondingly change by approximately 2/10".
    For example: a tire in the P205/60R15 size is measured on a 6.0" wide wheel and this size tire has an approved rim width range from 5.5" to 7.5" wide. The tire has a section width of 8.23" (209mm) when mounted on a 6.0" wide wheel. If that tire were mounted on all of the rims within its approved range, the tire's approximate section width would change as follows:
    Difference from Measuring Rim.............. Rim Width ..............Approximate Tire Section Width
    0.5" narrower..................................... 5.5" ..................................8.03"
    Measuring Rim ....................................6.0" ...................................8.23"
    0.5" wider ..........................................6.5".................................. 8.43"
    1.0" wider........................................... 7.0"................................. 8.63"
    1.5" wider.......................................... 7.5" ...................................8.93"
  5. Nov 19, 2012 at 12:18 PM
    #985
    NYCO
    bOb
    Colorado
    dents & scratches
    but that's basing everything off theory
  6. Nov 19, 2012 at 12:24 PM
    #986
    Kappes03
    Kappes03 Legend of the UG
    Colorado
    2014 Tundra CM
    That makes more sense. I went off your specs on your sig and a 9.8" wheel confused me
  7. Nov 19, 2012 at 1:14 PM
    #987
    n0rth
    n0rth Well-Known Member
    J.W.
    New Mexico
    2019 Tundra Platinum
    2009 Tacoma Access Cab SR5, 4wd, 2.7L URD S/C, 4:88's ARB lockers, 36x9.8r16 Radial TSL
    The guy I bought my swampers from had them mounted on a 10" rim and said they were too skinny for his liking. Interco has some strangeness to their sizes compared to all other tire companies. On a side note I'll be in Lakewood the dec. 3-7 if anybody wants to meet up for beers.
  8. Nov 19, 2012 at 1:41 PM
    #988
    NYCO
    bOb
    Colorado
    dents & scratches
    no shit!
    what's got you coming down here?
    i assume you're flying in?
    i'll be around that week, usually work until 5ish down in Denver but live out by 285 & kipling so i head west after work.
  9. Nov 19, 2012 at 2:24 PM
    #989
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    ^^ I PMed him my number as well so he could text when he is in town.
  10. Nov 19, 2012 at 2:34 PM
    #990
    NYCO
    bOb
    Colorado
    dents & scratches
    pretty much
  11. Nov 19, 2012 at 2:41 PM
    #991
    NYCO
    bOb
    Colorado
    dents & scratches
    thanks man...yea used this as a guideline
    after repairing the driver side with some marine sealant...sand with 600 (didn't have 800), wipe down, sand with 1000, wipe down, sand with 2000, wipe down, clean surface (used a liquid paint prep degreaser), mask off reverse lights, clean again, 1 light coat of tint, 1 heavy coat of tint, 12 criss-crossing clear coats, sand with 1000, wipe down, sand with 2000, wipe down, rubbing compound, polishing compound and then enjoy the finished product..
    took 6+ hours and a 6 pack of dale's pale ale (including 2 hours of waiting for the repair to harden enough to sand down)...so could be done in 4-5 hours allowing proper drying time between coats and allowing the cleaning solution to dry completely
  12. Nov 19, 2012 at 2:48 PM
    #992
    NYCO
    bOb
    Colorado
    dents & scratches
    yea after seeing the OP's lights i linked to, i knew 3 was too dark..
    doing the light coat first, i was figuring that it would be less likely to run
  13. Nov 19, 2012 at 5:04 PM
    #993
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    What kind of sealant did you use and how good is it holding up? Is it noticeable through the tint? I have maybe 3 cracked tail lights I want to repair. :eek:
  14. Nov 19, 2012 at 5:32 PM
    #994
    nimrod712
    Jonathan
    Hot Springs, AR
    '08 Taco TRD
    Actual measurements on the truck under weight on the 305 MTR are about 33.8 by about 12.3 on my 8.5" wheel. I said that about the 315s, because I've seen 315s that measured like 33.5" while on the truck, when they claimed to be 34.7"... I think I may have some time this weekend to put the 305 back on and do some more testing. I'll let ya know.
    Anyway, the tail lights look good. I may have to do that myself.
  15. Nov 19, 2012 at 6:01 PM
    #995
    NYCO
    bOb
    Colorado
    dents & scratches
    used DAP marine silicone sealant..
    seems like it'll hold up fine...it doesn't completely dry to a solid so getting it to dry as a layer of protection over the crack was impossible...but i was able to get some in the crack and bond the cracks together...
    you can see the cracks here..
    so no it's not the perfect fix, but it'll hold...after the tint and clear coats, the crack has smoothed out quite a bit, but you can still notice it if you run your hand over the area..
  16. Nov 19, 2012 at 6:03 PM
    #996
    NYCO
    bOb
    Colorado
    dents & scratches
    yea that's why i say in theory...i have yet to test it out in person like you have...we'll see how it goes...i may have to look into a small spacer for my wheels if it is too wide for my wheels..
  17. Nov 19, 2012 at 6:05 PM
    #997
    Gramps
    Gramps
    07 TRD DC 4x4
    When did you do that? Sorry no factory driver's side tail that I can sell you. That's the side I keep destroying. Something is wrong with my driving. :D
  18. Nov 20, 2012 at 6:43 AM
    #998
    NYCO
    bOb
    Colorado
    dents & scratches
    that would be the gatekeeper squeeze at OCG...almost got through until it slipped and hit the massive rock
    right here..
  19. Nov 20, 2012 at 6:45 AM
    #999
    Namyo
    Namyo -
    Dam that's some pretty scenery :jellydance:
  20. Nov 20, 2012 at 6:49 AM
    #1000
    NYCO
    bOb
    Colorado
    dents & scratches
    that would be mt princeton (14,197') in the back...photo taken from the first hill on the trail
    there is a trail that leads up to the left peak
    this pic was taken at the end of the trail just below the left peak..."tigger peak"
