NYCO's '06 Boosted Blue Betty
Discussion in '2nd Gen. Builds (2005-2015)' started by NYCO, May 18, 2011.
  1. Feb 1, 2013 at 11:45 AM
    #1101
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    tacoma with Trxus
    being put to use
  2. Feb 1, 2013 at 7:09 PM
    #1102
    nimrod712
    nimrod712 Well-Known Member
    Jonathan
    Hot Springs, AR
    '08 Taco TRD
    Good looking tires. They do well around here and are pretty tough. You never can tell about Interco and their tire sizes though... I would try to find someone that has that size and get actual measurements.
  3. Feb 1, 2013 at 8:27 PM
    #1103
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Have you looked at the geolanders? Or dynaMtS?
  4. Feb 2, 2013 at 5:23 AM
    #1104
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Awesome
    I have run Geolanders on another rig. Awesome tire but the drawbacks are no cross pattern rotating (directional tire) and super soft compound so there mileage is short. I have heard good things about the dyna's. Bob I still say look at the Hercules or SST's. That's a ton of money on those Interco's.
  5. Feb 2, 2013 at 8:51 AM
    #1105
    NYCO
    bOb
    Colorado
    dents & scratches
    STTs are nice too, got a buddy who runs them on his 1500 and he likes them...standard sizes though...would be nice to gain .5-1" off your ass haha
    on another note, i am going with a one piece shaft...will be picking it up next weekend (out of town all week on business for this guy)
    this will be nice because i'll have a spare shaft now incase anything does happen..
    i'm thinking about having my old one repaired and a new carrier bearing put on it at some point and maybe have that be my wheeling shaft (swap it out for moab trips and other harder trails)...i have a spare carrier bearing already (questionable whether it fits the truck though), so i'll throw that on the repaired shaft when that project moves forward..
    but i'll be sure to take some clearance measurements so we can have an idea of what the loss is when going to a one piece...
    going through rocky mountain driveline...some good people over there and heard good things from guys in ttora and colorado 4x4 already...walls will be thicker than factory as well, so that'll be a plus...also means when i repair my factory shaft it'll then have a thicker wall as well..
    :popcorn:
  6. Feb 2, 2013 at 8:59 AM
    #1106
    NYCO
    bOb
    Colorado
    dents & scratches
    geolander MT are some crazy looking tires :eek: not a fan of the shoulder and sidewall design and grip though...plus they have limited sizes in 17s..no i won't go all the way to 35s for reasons i said before
    dynapro MT looks like a nice tire...i've seen some west coast guys running them...haven't seen many reviews with them..
    my big things are...snow/ice performance, off-road performance with 30-40k life
  7. Feb 2, 2013 at 11:27 AM
    #1107
    Blackdawg
    Monte
    Wyoming/St. Louis
    The dynas are supposed to get 50-60k. And that's on full sized trucks.
    Think ill get them next. Almost 50 bucks cheaper a tire in 37s.
  8. Feb 2, 2013 at 11:49 AM
    #1108
    NYCO
    bOb
    Colorado
    dents & scratches
    they are muuch cheaper...
    hmmm...
    got some time till i am making a purchase, but i'll have to keep them in mind
  9. Feb 2, 2013 at 11:52 AM
    #1109
    NYCO
    bOb
    Colorado
    dents & scratches
    fact that it's hard to find someone willing to make a 2 piece driveshaft haha
  10. Feb 2, 2013 at 12:03 PM
    #1110
    NYCO
    bOb
    Colorado
    dents & scratches
    i'm thinking once i get the 2 piece rebuilt i'll see if i can find a way to tuck the spare one piece under the frame out of the way...
    new shaft will be complete with both flanges so the u-joints will be intact and all i'd have to do is unbolt the old and put on the new
  11. Feb 9, 2013 at 12:31 PM
    #1111
    NYCO
    bOb
    Colorado
    dents & scratches
    got the new drive shaft in...$500 for a custom one piece with a double cardan i make my joints happier...
    install was straight forward..torque specs @65ftlbs (i went more)
    to get a comparison of the two shafts, i started at the front flange (t-case) and worked my way back in 1 foot increments to the carrier bearing then 1 foot increments to the flange at the 3rd.
    measurements before/after:
    gas tank height 15 3/8"
    old shaft: 21", 20 3/4", (CB) 18 1/8", 16 1/4", 14 1/4", 12 1/2"
    new shaft: 21", 20 1/2", (CB mounting) 18 1/8", 16 1/4", 14 3/4", 12 1/2"
    so really the only loss was between the carrier bearing and tcase...the remaining measurements showed no significant changes
    height at the carrier bearing was similar, but the old shaft measurements was to the bottom of the CB, while the new shaft measurement was measured to the shaft.
    there was a slight gain toward the rear but i think that is mainly from the difference in shaft diameters maybe...plus there is a slight gain in the rear because the slip yoke is now by the 3rd where the factory shaft was full diameter all the way to the 3rd's flange.
    new shaft
    clearance
  12. Feb 9, 2013 at 12:38 PM
    #1112
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    ^ hmmmm....
    :rolleyes:
  13. Feb 9, 2013 at 12:39 PM
    #1113
    NYCO
    bOb
    Colorado
    dents & scratches
    you like my shaft? :cool:
  14. Feb 9, 2013 at 12:40 PM
    #1114
    NYCO
    bOb
    Colorado
    dents & scratches
    might be a different story with the trail limos..but the swap doesn't seem to be much clearance issue with the AC
  15. Feb 9, 2013 at 12:50 PM
    #1115
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Did you have that made locally at a drive-line shop or is that a Tom Woods?
  16. Feb 9, 2013 at 12:55 PM
    #1116
    NYCO
    bOb
    Colorado
    dents & scratches
    kept it local...
    great people..heard lot of good reviews from others on other forums around here about the shop
  17. Feb 9, 2013 at 1:24 PM
    #1117
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    very niiiiiiiiiice! i doubt youl have any clearance issues... i agree tho a lb might be different story
  18. Feb 9, 2013 at 2:11 PM
    #1118
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Very nice!
  19. Feb 9, 2013 at 2:19 PM
    #1119
    NYCO
    bOb
    Colorado
    dents & scratches
    thanks man...
    glad to finally get this taken care of and looking forward to seeing its limitations and benefits
  20. Feb 9, 2013 at 3:30 PM
    #1120
    Gramps
    Gramps
    07 TRD DC 4x4
    Nice! Glad they hooked you up.
