NYCO's '06 Boosted Blue Betty
Discussion in '2nd Gen. Builds (2005-2015)' started by NYCO, May 18, 2011.
  1. May 15, 2013 at 9:55 AM
    #1621
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    This to me sounds like the cleaner solution rather then modifying the mount itself. I would drill a new set of holes in the frame though rather then elongating. Last thing you want is that mount to slip along the frame rail while on the road.
    It is looking more and more that fixed Shackle flips need to be mated to a particular aftermarket spring specifically for it to work correctly.
  2. May 15, 2013 at 10:01 AM
    #1622
    NYCO
    NYCO [OP] go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    may not need it :D
    solution will be coming
  3. May 15, 2013 at 10:01 AM
    #1623
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    problem with drillin new holes, is that it can move the mount left or right/screw up the alignment of the mount while moving front to rear since our frames are tapered in this spot.
    also, these are suppose to be built for the OME Dakar springs.
  4. May 15, 2013 at 10:02 AM
    #1624
    wrmathis
    Bonaire, GA
    parts and stuff
    let me know too. might have to do something whenever i get mine installed
  5. May 15, 2013 at 10:04 AM
    #1625
    NYCO
    bOb
    Colorado
    dents & scratches
    and my OME Dakar, maybe because they're aged, aren't producing like they were planned.
    adam at ATO has looked at everything and is taking care of it.
  6. May 15, 2013 at 10:06 AM
    #1626
    Gramps
    Gramps
    07 TRD DC 4x4
    True, but how far do you think it moves the mount if a new hole is drilled within 3/4" of an inch forward. Would it be within acceptable limits I wonder.
    Yeah I know they are for the Dakars and I have seen other trucks with this set up working just fine. So I wonder if something else is at play here on Bob's truck?
  7. May 15, 2013 at 10:06 AM
    #1627
    Gramps
    Gramps
    07 TRD DC 4x4
    Hmmm... care to elaborate? :D
  8. May 15, 2013 at 10:11 AM
    #1628
    NYCO
    bOb
    Colorado
    dents & scratches
    more info will come when things are worked out
  9. May 15, 2013 at 11:18 AM
    #1629
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    x zwei
    Bought these because they were made for specific leaf packs... I have "aged" Dakars as well
  10. May 15, 2013 at 1:00 PM
    #1630
    NYCO
    bOb
    Colorado
    dents & scratches
    i will post up with updates for sure.
    performance you can see from the flex shots, that it works fine. but the angles just aren't "ideal"
    hope to get it adjusted before moab, we'll see
  11. May 16, 2013 at 8:30 AM
    #1631
    NYCO
    bOb
    Colorado
    dents & scratches
    so as much as i tried to have the truck ready well before the event...
    once again will be doing work up to my departure for moab..
    sunday:
    rock lights
    remove hook under bumper
    get defined shackles to fit!
    monday evening/night:
    new shackle flip setup
    wednesday night:
    test out new shackle flip setup
    thursday (may now take off work):
    plan B if i don't have time monday and wednesday for the shackles
    otherwise gather supplies and pack
    leave by 5pm latest
    plan C: bring all my shit to moab and swap shit out at BFE :D
    at least all the hard stuff is done on the flip
    would be nice to find a way to fit my spare driveshaft in my bed without taking up needed space too.
  12. May 16, 2013 at 8:33 AM
    #1632
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    Pull it apart and stick it in the cab.... :D
  13. May 16, 2013 at 8:36 AM
    #1633
    NYCO
    bOb
    Colorado
    dents & scratches
    no room haha
    i'm thinking of stuffing the short end angled down into the front passenger corner of my bed. then the long end will sit on the top of my spare tire that is mounted vertical in the back passenger side of my bed. then ratchet the shaft to the tire. my toolbox will keep the short end from moving around too much. idk
    now that i have a spare, i would hate to not bring it with me on a long trip like this and need it for some reason.
  14. May 16, 2013 at 8:37 AM
    #1634
    NYCO
    bOb
    Colorado
    dents & scratches
    but i have spare u joints incase those go.
    so really it would be if i twist a shaft or bend it over a rock
  15. May 16, 2013 at 8:41 AM
    #1635
    Round II
    Round II Member #12005
    I feel ur pain. I always do this before I go away on a long trip. Hell Im getting ready to hit Canada and I just changed out a CV, needle bearing, front, and rear shocks, and I still have some shit to do.
  16. May 16, 2013 at 8:50 AM
    #1636
    NYCO
    bOb
    Colorado
    dents & scratches
    when are you heading out?
    have they started thawing out up there yet?
  17. May 16, 2013 at 8:58 AM
    #1637
    Round II
    Leaving Tuesday @ noon man I cant wait to get on the road!!!!! It looks like they have started to thaw out a bit I just got an update from North Bay that the laks levels are as high as they have seen in 25 yrs, I can see this being a real mud fest...:(
  18. May 16, 2013 at 9:02 AM
    #1638
    Round II
    Been sittin on the shelf for two years now....:eek:
  19. May 16, 2013 at 9:03 AM
    #1639
    NYCO
    bOb
    Colorado
    dents & scratches
    looks like a nice area up there!
    you hitting some trails up while you're there or mainly fishing?
  20. May 16, 2013 at 9:06 AM
    #1640
    Round II
    1st week is wheeling with some Toronto 4x4 club, the 2nd week will be all fishing.
