o2 DTCs
Discussion in 'Technical Chat' started by Doorslammers, Feb 14, 2009.
  1. Feb 14, 2009 at 4:50 PM
    Doorslammers
    Doorslammers [OP] New Member
    Hey guys
    Ive got a 96, 3.4, 4x4 here with some troubles.
    I seem to be getting three codes
    PO125- Isufficiant temp for closed loop
    PO133- Signal slow B1-S1
    PO135- Heater circuit B1-S1
    Now, the voltage to the sensor is within the perameters in all driving conditions, the fuel trim seems to be reacting ok, and it seems to have no trouble getting into Closed loop, but the sensor does not cycle between rich and lean. In most driving conditions it will be at 0/s but the odd time it will hover around 0.5/s and sometimes (usually while coming to a stop) it will spike to 16.xx/s.
    Both sensors have been replaced with Bosch units with no change, i still get the same three codes, have there been any issues with these in the past? Has anyone run into this problem before that can shed some light on it?
    Thanks
  2. Feb 14, 2009 at 5:56 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    Does the truck have an 02 sensor heater relay? Some car companies use them
  3. Feb 14, 2009 at 6:02 PM
    Doorslammers
    hmm, i dont know. i dont have any information telling me about any heater relays, i have been using Alldata and none of the tests have mentioned them.
  4. Feb 14, 2009 at 6:04 PM
    TRD4x4858
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    Hmm then maybe it doesnt, is the signal that the pcm is recieving the one your seeing? All wiring ok, good fuses?
  5. Feb 14, 2009 at 6:18 PM
    Doorslammers
    yes, i am reading the values right off the scanner, so they would be coming from the PCM. all the wires seem to be good as well.
  6. Feb 15, 2009 at 1:45 AM
    Doorslammers
