o2 sensor - '06 Tacoma 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by louie57h, Feb 6, 2021.
  1. Feb 6, 2021 at 7:20 PM
    louie57h
    louie57h [OP] New Member
    Louie
    2006 Tacoma v6 2 wheel drive
    Put diagnostic on truck because getting CEL. Reading is Bank 2 sensor 2 (downstream). Double checked code at Auto Zone with their diagnostic. Same code. Searched part needed using VIN#. Part number identified. From what I can tell Bank 2 is driver side because cylinder 2 is driver side. So, I need the post cat sensor for Bank 2. Part # is Denso 234-4260 or 234-4261.
    Here is the problem. When you go to buy one it says Downstream Right or Downstream Left. I have looked everywhere to see whether "Downstream Right" means as you are sitting in vehicle or looking at vehicle from front.
  2. Feb 6, 2021 at 10:04 PM
    RecklessTLS
    RecklessTLS Well-Known Member
    Rowdy
    Ft Collins, Colorado / Texas Native
    2009 Tacoma DCSB TRD Offroad 4.0
    TRD CAI and Exhaust,ECGS bushing, Blistien 6112 Fronts at 2.5, SPC upper arms, Bilstien 5160 Rear with 2in AAL, Interior light mod, Back up camera anytime Mod, Overhead Console Temp/Compass Fix. Leather Interior with heated seats, Weathertech floor liners, Ultraguage, Oil catch can, Smart Tap, More to come
    Rockauto is where I got my o2 sensors. Go back with denso brand. Down stream is away from engine. The upstream sensors are AFR sensors while the downstream is o2. I'd replace both if it was me if you have the extra cash. The left is driver side.
    SUMOTNK and winkel like this.
  3. Feb 6, 2021 at 10:26 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Upstream and Downstream are commonly used to indicate what side of the converter the sensor is located. These trucks use A/F Sensor (upstream) and O2 Sensors (Downstream).
    It would be easier if they would be listed like this on retail sites.
    A lot of folks don’t know the difference, or just call then O2 sensors anyways.
    which they “kind of are” but the A/F monitors a wider range of data.
    winkel likes this.
  4. Feb 7, 2021 at 8:38 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Standing in front of truck with hood open, Bank 2 sensor 2 is the driver's side sensor after the cat. (bank 2 refers to the bank that includes cylinder # 2, which is the cylinder closest to you on driver's side. Bank 1 is closest to you passenger side)
  5. Feb 7, 2021 at 8:45 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    I would plan on replacing both sensors. If one has failed, the other may not be much longer.
    Also, your under the truck doing the work. It only takes a little more time.
  6. Feb 7, 2021 at 1:04 PM
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    The O2 sensors are cheap. The A\F one are much more expensive. I changed both of mine out many years ago when replacing my headers with DT Long tube ones.
  7. Feb 7, 2021 at 1:08 PM
    louie57h
    Louie
    Thank you all. When I ran the VIN # to get the Denso part # it comes back as 234-4260 and 234-4261 for each different side downstream. So, I checked for these part #'s on Amazon and it says they are not a compatible fit. I'm more inclined to trust Denso than Amazon. I might as well do both downstream. The only difference is length of cable on each side.
    Debating whether to do upstream AFR sensors. These suckers are expensive.
    I'm going to change out the MAF while I'm at it. That's about a 2 minute job.
    Hoping downstream will come off easily if I soak with PB blaster overnight. Kid at Auto Zone was clueless as to which special slotted socket I should use. I think its 3/8 drive with 7/8 socket size but not sure.
    Thx for all the help.
  8. Feb 7, 2021 at 2:47 PM
    RecklessTLS
    Rowdy
    When I did all my sensors about 2-3 years ago, it was around 350 for all 4.
  9. Nov 13, 2024 at 10:41 PM
    bkrdave36
    bkrdave36 Well-Known Member
    Dave
    Wittmann,AZ
    06 Prerunner Double Cab Black
    Front OME Springs, Upper Control Arms, Icon Stage 3 Rear Leaf Springs, Durobump bump stops,Bilstein 5125 shocks, BFG All Terrain KO2 Tires, Avid Light bar and step rails, Victory 4x4 bed rack with Tepui Ayer Rooftop Tent, Anytime Fog light mod, Outside Air Temp Gauge mod, ImMrYo Rearview Mirror mod, Chinese Knockoff LED lights, Body Armor 4x4 Offroad Swingout rear tire carrier and bumper, Victory 4x4 Bed Stiffeners, Rattle can Custom Camo paint stripe, Truxedo Lo Pro tonneau cover, various Blue Ridge Overland Gear storage solutions in cab, thats it so far .... to be continued!
    Any update on this repair? Did it work? Any problems since?
