O2 sensor came loose and popped out of exhaust? wtf?!
Discussion in '1st Gen. Tacomas (1995-2004)' started by defleppardsg, Oct 26, 2011.
  1. Oct 26, 2011 at 8:24 AM
    defleppardsg
    defleppardsg [OP] Well-Known Member
    chris
    texas
    2.7L SR5 4x4
    OME 880's, Wheeler's Offroad 5-Leaf pack. Bilstein 5100's, 1" Daystar shackles, Deck Plate Mod.
    I thought i had a hole forming in my muffler or something, got real loud. Got under there to look, and find my post-cat O2 sensor hanging by it's harness. The bolts (rusted???) off and the freakin sensor just popped out. How the hell could this have happened??? I'm glad it didn't fall off.
  2. Oct 26, 2011 at 8:27 AM
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Just a guess, but since you live in NY you probably got salt or something on it year after year and it corroded...also, not sure if you're the original owner, maybe it's an aftermarket sensor?
  3. Oct 26, 2011 at 10:45 AM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    Happened to mine too - just rusted bad and there it went.
    Not an issue anymore though - put on new cats/muffler.
  4. Oct 26, 2011 at 10:52 AM
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    2018 Tacoma TRD Sport access cab, magnetic grey metallic.
    same thing on my "95". just the nuts rusted off, and not the studs. 2 new nuts and all was well.
  5. Oct 26, 2011 at 11:07 AM
    KingToaster
    KingToaster Member
    Alan
    NH
    2002 Tacoma DC 3.4L SR5
    Deck Plate w/ K&N. Grey Wire Mod.
    also happened to me about two years ago, put on some new nuts and it has been fine since.
  6. Oct 26, 2011 at 11:17 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    damn I'm glad I live in FL...:D
  7. Oct 26, 2011 at 11:23 AM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    damn i'm glad I live in California!!!!!
  8. Oct 26, 2011 at 12:20 PM
    defleppardsg
    chris
    texas
    2.7L SR5 4x4
    wow, yea, almost hard to believe that the nuts could completely dissinigrate, and the whole senor could just vibrate right off of the studs. lol. I feel those things are hard to get off when you're trying to, who knew it could just come free. Glad I'm not the only one.
  9. Oct 27, 2011 at 5:44 AM
    KingToaster
    KingToaster Member
    Alan
    NH
    Kept hearing some clanging around down there and keep having the CEL come on and go off repeatedly so i decided to take a look and it didn't take long to figure out what was going on.
  10. Sep 11, 2012 at 6:25 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    shit I think I'v just discovered that my nuts have rusted away too!! sensor is still in there solid as can be though, but the gasket is rotting away!! is there a trick to removing the sensor so that I can replace the gasket and the nuts?
  11. Sep 11, 2012 at 6:17 PM
    Ecnerwal
    Ecnerwal Well-Known Member
    NW Mass
    '02 4x4 2.7 A/T Ext Cab
    gradually replacing the bumper with hairy bondo ;-)
    Penetrant and vise grips. Use the penetrant for several days in advance, applying to hot exhaust and letting it work its way in while it's cooling down. If you still have the "sheild" some people have in their pictures on the rear one, you may have to cut it loose to get to the nuts with the vise-grips. You may also (or instead) want a nut-splitter or a dremel with a cutoff wheel to soften up what's left of the nuts.
    Spend the $50 on a new sensor as well, IMHO. And the $100 up front (A/F) if that's not been done in your memory or 100K miles.
    Stainless steel nuts, lockwashers (I couldn't find decent stainless ones, so I used non-stainless for those) and anti-sieze on the threads after you put the sensor on but before you put the nuts on.
