O2 sensor codes (P0032 and P0052)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jnprn2003, Oct 13, 2023.
  1. Oct 13, 2023 at 8:53 PM
    jnprn2003
    jnprn2003 [OP] Well-Known Member
    Joe
    MA
    2021 Tacoma Off-Road Premium 4x4
    21 Tacoma 3.5 V6.
    Did some work on it (installed new steering rack and some other unrelated work).
    Put the battery back in, started and now have a CEL and reading as P0032 and P0052.
    No wires were touched, truck only has 17500 on it.
    Any thoughts on what may have occurred?
  2. Oct 13, 2023 at 9:21 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Both are codes relating the the heated oxygen sensors. You may need to use Techstream to clear them. Other guys smarter than me may have a better answer.
  3. Oct 13, 2023 at 9:28 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Those codes are for high current.
    Are you sure you didn’t pinch any wires?
    joba27n likes this.
  4. Oct 16, 2023 at 10:28 AM
    jnprn2003
    Joe
    MA
    Very sure. I have been
    Figured it out.
    There is a ground wire on the power steering pump (which I did not reattach when upgrading the pump). I attached it to ground and light went away.
    Chew likes this.
