O2 sensor, front or rear?
Discussion in '1st Gen. Tacomas (1995-2004)' started by JerzYota, Feb 29, 2016.
  1. Mar 17, 2016 at 8:38 AM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Yes. It would be best to replace them both. Usually when one goes.......the other is not far behind. Toyota suggests the O2 sensors to be replace every 100k miles. So if you don't know when the 1st sensor was replaced, replacing it would give you a piece of mind knowing when they were all changed.
  2. Mar 17, 2016 at 8:48 AM
    JerzYota
    JerzYota [OP] Member
    Gotcha. Thanks.
  3. Mar 17, 2016 at 8:57 AM
    JerzYota
    Looking up the parts on Autozone website and it looks like Denso front and rear will cost 143.99 for upstream and 89.99 aft.
    Why is the NGK upstream 448.99? 300 bucks difference in price is insane.
    I can't afford to do this job right now and as far as I can tell I won't harm my truck by delaying the repair. So I have time to shop around and would welcome any advice.
    Thanks
  4. Mar 17, 2016 at 9:22 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    front sensor is air fuel sensor
    think of o2 sensor as a on-off switch, dumb sensor you are either in the
    middle somewhere, or on one, or the other end of the range (checks for emissions compliance)
    think of air fuel as a dimmer switch, more sophisticated you need to know exactly where you are (controls fuel)
    I suggest denso only for replacements as denso is OEM and toyota ECU is damn fussy about every ohm and volt from these things..non-denso have a real bad rep
    if you are not worried about loot then OEM only with toyota part number for these!
    a/f is typically 100 bucks more than o2 sensor
    your OBDII code could be exhaust leak, or bad sensor
