o2 sensor help. bank 1 sensor 1
Discussion in '1st Gen. Tacomas (1995-2004)' started by vtwinjunkie, Sep 16, 2017.
  1. Sep 18, 2017 at 9:50 AM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    I had the same code in my kid's 2000 2.7. Air fuel ratio sensor was stuck on a specific output (80 I think). Replacing the sensor fixed the problem. However, getting the sensor out was no easy task. Broke one of the studs and had to remove the CAT and have it drilled out. Be ready for this possibility and have alternate transpo lined up 'cause it might take a few days from start to finish.
  2. Sep 18, 2017 at 12:01 PM
    vtwinjunkie
    vtwinjunkie [OP] Well-Known Member
    2005 TRD Sport
    Bilstein 5100's, 885 coils, Dakar Leafs, SPC LR UCA's, 275-70-17
    is that the upstream sensor or the downstream sensor? I removed the upstream sensor yesterday with map gas and channel locks. (it was stripped when I bought the truck).
  3. Sep 18, 2017 at 12:03 PM
    rzgkane
    A/F ratio sensor is the upstream (closest to the engine and furthest from the muffler) sensor. Failed at about 160K miles.
  4. Sep 18, 2017 at 12:07 PM
    vtwinjunkie
    2005 TRD Sport
    Ok thanks.
    so if this sensor fails it wont throw an o2 code, but rather the p0420 code?
    I assumed it would throw an o2 code but I am curious what yours did.
  5. Sep 18, 2017 at 12:07 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    true. they all have a finite life and 120~150~ thousand miles, these things are dying or dead
    my 4runner 5vzfe a/f died at 130,000 (heater circuit) or so and the rear o2 at 142,000 (p0420) the p0420 code happened
    ON april 20th no lies.
    Tacojoe68 and scocar[QUOTED] like this.
  6. Sep 18, 2017 at 12:13 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    it will throws codes related to it's heater circuit (it has to get hot to work)
    it will throws codes related to lean or rich
    a/f (the front ones) typically throw a p11XX code
    most common are these
    https://parts.olathetoyota.com/p1135-code
    https://parts.olathetoyota.com/p1155-code
    but if the sensor is working, just 'off' you may get p0171 lean or p0172 (system too rich)
    and the fun part is you get these a LOT when you use aftermarket sensors. Stick to toyota OEM
    it's worth the bucks because it will always work. aftermarket is a crap shoot a lot of times.
    scocar likes this.
  7. Sep 18, 2017 at 12:14 PM
    rzgkane
    Mine threw just the P0420 code. I initially thought it was the MAF sensor and so I replaced it shotgun style. Only when it didn't solve the issue did I get ahold of a data logger (I think it was called CRecorder) that revealed the sensor to be stuck and not producing vacillating voltage as it's supposed to.
  8. Sep 19, 2017 at 8:13 AM
    vtwinjunkie
    2005 TRD Sport
    Cool,
    I am still unclear on how to diagnose the o2 sensors without the toyota factory part. I will need to re-read the manual as I think there is a test that uses volts off of the sensors while the truck is running.
  9. Sep 19, 2017 at 8:32 AM
    rzgkane
    Honestly, if everything else is tight and there are no exhaust leaks prior to the cat I would just spend the $100 and replace the a/f ratio sensor. Since your code references a lean condition and your truck has a lot of miles on it I would also replace the fuel filter. Have fun with that.
  10. Sep 19, 2017 at 1:22 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    I went through similar codes last year and replaced my a/f sensor twice, so I have a spare Denso for a 2.7l. Problem turned out to be a bad connection, and I believe the spare is ok.
    Got them from rock auto for around $110.
  11. Sep 19, 2017 at 1:25 PM
    vtwinjunkie
    2005 TRD Sport
    Thanks for that advice. I actually ordered the same one based on a few other similar experiences I read about.
