O2 sensor help needed
Discussion in '1st Gen. Tacomas (1995-2004)' started by donlogan, Oct 5, 2017.
  1. Oct 5, 2017 at 2:05 PM
    donlogan
    donlogan [OP] Well-Known Member
    I'm trying to replace what I believe is the 'downstream' Oxygen sensor in my 1995 Tacoma, 2.4L.
    Before I opened up the packaging I wanted to just make sure I am doing the right one.
    Upstream O2 sensor is the one closer to the cab right? And the downstream O2 sensor is the one further down...as in from the direction that the exhaust fumes flows.
  2. Oct 5, 2017 at 2:09 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
  3. Oct 5, 2017 at 2:11 PM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    upstream = before cat, downstream = after cat
  4. Oct 5, 2017 at 2:12 PM
    tomtraubertsblues
    tomtraubertsblues Well-Known Member
    Northern Arizona
    Downstream is after the catalytic converter.
  5. Oct 6, 2017 at 5:48 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    Wasn't there only a downstream O2 sensor on the '95? IIRC, they didn't add the upstream A/F sensor until later. I've only had 2.7Ls though, and my '97 only had a downstream.
