o2 sensor help
Discussion in '1st Gen. Tacomas (1995-2004)' started by gbollom, Nov 30, 2016.
  1. Nov 30, 2016 at 5:06 PM
    gbollom
    gbollom [OP] Well-Known Member
    Weatherford Tx
    01 xcab TRD 4x4 5spd
    yes I tried searching, but not having much luck
    I have the stupid p0420 code and want to change both of my o2 sensors. I found the denso downstream on rock auto, but the only denso upstream says its for an auto trans only. Can anyone help me with a part number or another location to find the proper up stream sensor please
  2. Nov 30, 2016 at 5:26 PM
    wesb1023
    wesb1023 Well-Known Member
    Westley
    Eastern NC
    04 Double Cab
    Scratch everything. Find someone with a scan tool that can look at your upstream and downstream o2 sensor wave patters. Upstream should be switching from rich to lean up and down in a fairly smooth waveform. The downstream should be a straight line... if it looks like the upstream waveform...you've got a bad converter.
  3. Nov 30, 2016 at 5:30 PM
    gbollom
    Weatherford Tx
    I don't know of anyone local that has that nice of a scan tool. The truck has 255,xxx miles and the light was on for the sensor when I purchased it. Ran a tank of premium through on recommendation from a local mechanic and the light went off temporarily, put reg unleaded back in it and now the sensor wont go back off even with premium.
