O2 sensor issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by vanakin70, Apr 25, 2020.
  1. Apr 25, 2020 at 4:11 PM
    vanakin70
    vanakin70 [OP] New Member
    Kevin
    Sioux Falls, SD
    2003 Tacoma prerunner 3.4 L
    Darth Vader edition remake...
    Does anybody know where to get inexpensive o2 sensors upstream and downstream that won't empty my bank account or can old ones be repaired bought 2 on ebay that were bad 2003 tacoma prerunner 3.4L extended cab 2wd
  2. Apr 25, 2020 at 4:23 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard Kevin
    Don't waste your money on cheap counterfeit knock offs.
    Denso identical to original replacement or you're asking for more problems.
  3. Apr 25, 2020 at 7:36 PM
    vanakin70
    Kevin
    Sioux Falls, SD
    The only problem is i just cant simply afford 250 dollar sensors but if i dont get that check engine to stay off i have no way of knowing if something else goes wrong down the road while that idiot light is always on
  4. Apr 25, 2020 at 7:41 PM
    Black DOG Lila
    Virginia
    An OBDII scan tool solves the not knowing something else issue for le$$
  5. Apr 25, 2020 at 7:45 PM
    vanakin70
    Kevin
    Sioux Falls, SD
    Got one of those already but that would be a pain in the ass checking that every single day just to see if another code popped up
  6. Apr 25, 2020 at 11:04 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    What code(s) do you have?
  7. Apr 25, 2020 at 11:13 PM
    vanakin70
    Kevin
    Sioux Falls, SD
    Started with 0031 then when i changed the first sensor it changed to 2238
  8. Apr 25, 2020 at 11:30 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  9. Apr 26, 2020 at 5:04 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I guess you have physical problem making it hard to plug the code reader in it is a pain having to remove the seat.
    Since Napa started selling Denso I buy O2 sensors there the delivery women is very friendly .
    For what ever reason Toyota`s don`t like Aftermarket sensors
  10. Apr 26, 2020 at 6:49 AM
    TacomaEli
    TacomaEli Well-Known Member
    Eli
    Roanoke, Virginia
    2000 Tacoma XtraCab SR5 TRD 3.4L Auto
    Buy Denso on Amazon. Just figure out the part number you need. Ideally an obd2 scanner with live data so you can check the voltage of O2 sensors and what not to see if they are functioning correctly. Not too savy on that, just what I’ve heard while researching how to solve my P0420 code.
  11. Apr 26, 2020 at 7:11 AM
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    2003 Std Cab 2.7L 4x4 & 2024 Off Road
    Bilstein 5100s, Deaver Leaf Springs, JBA UCAs on 2003 King 2.5 shocks front and rear on Off Road
    RockAuto has DENSO O2 sensors for much less than you quote.
    I changed out mine and it solved the problem.
    Good luck getting the bolt nuts off.
  12. Apr 26, 2020 at 7:27 AM
    Timmah!
    Timmah! Well-Known Member
    TIM
    Wyoming09 likes this.
  13. Apr 26, 2020 at 10:48 AM
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    I believe those codes are related to the heating element in the O2 sensor. It's possible that a non-Denso part has a different resistance in the heating element so the computer is seeing an out of spec current draw. Or if you use the wrong Denso O2 sensor.
    It could also be a wiring problem, so you want to check that too.
    cruiserguy and Wyoming09 like this.
  14. Apr 26, 2020 at 10:51 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Only use Denso sensors on these trucks, anything else might be cheaper but you'll pay more in the long run when they constantly crap out.
  15. Apr 26, 2020 at 11:25 AM
    Bend_corners
    Bend_corners Well-Known Member
    Jim
    USA
    1995.5 5vzfe medium quartz Xtracab
    I still got a stock oem downstream sensor that worked great for me if you want it and will pay for the shipping. Replaced it with a new denso sensor a few months ago just doing upgrades. 200K on it but hey it's cheaper than new. From a 1995.5 5vzfe
  16. Apr 27, 2020 at 6:13 PM
    austinsdad99
    austinsdad99 Well-Known Member
    1999 prerunner 3.4
