o2 Sensor P0051 (Sim not working?)
Discussion in 'Performance and Tuning' started by GSK9 B1T3, Apr 29, 2011.
  1. Apr 29, 2011 at 10:35 PM
    GSK9 B1T3
    GSK9 B1T3 [OP] Well-Known Member
    Another One
    Washington
    TRD Rugged Trail ED
    Toyotec Ultimate 3" TC UAC 305/70 R16 Breather Mod Front fender Mod Steel Brake Lines All around
    So I went in really deep water, truck died. I was able to start it up shortly after (while in the puddle) to get it out of the puddle and then I shut the truck off. Took the sopping wet air filter out then made sure no water was in any of the cylinders by cycling the engine with the spark plugs out (one at a time of course.) Luckily no mechanical damage to the engine that I can tell ------- yet.
    Yes rookie mistake I know...........Now to the problem.
    The truck was throwing a CEL for P0257 (something like that) and I changed the MAF. This solved the first CEL. Now the CEL is coming on "P0051" I looked into this on the forums already and have tried changing out fuses and I also just installed the URD o2 Sim.
    None of my attempts to solve this have worked. Anybody have any advice?
    Thanks.
  2. Apr 30, 2011 at 7:58 AM
    GSK9 B1T3
    Another One
    Washington
    TRD Rugged Trail ED
    Bump for help...
  3. Apr 30, 2011 at 9:44 AM
    GSK9 B1T3
    Another One
    Washington
    TRD Rugged Trail ED
    Bump for help....again.
  4. Apr 30, 2011 at 9:48 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    The O2 sim isn't going to help because the code is for the front sensor on bank two. I would suggest changing it out with a Denso (OEM) direct replacement
  5. Apr 30, 2011 at 9:49 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  6. Apr 30, 2011 at 5:29 PM
    GSK9 B1T3
    Another One
    Washington
    TRD Rugged Trail ED
    And this is the sensor that is located on the exhaust manifold itself? I see one on each manifold and one on each side of the "Y-Pipe." Just to clarify we are not talking about the MAF?
  7. Apr 30, 2011 at 5:51 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    No we are not talking MAF. You have a sensor(s) before and after the catalytic converters. The ones before (upstream) are #1's. The ones after the cats are #2's. Bank one is the side of the motor with the number 1 cylinder. Bank two is the side of the motor with the number 2 cylinder
  8. Apr 30, 2011 at 10:30 PM
    GSK9 B1T3
    Another One
    Washington
    TRD Rugged Trail ED
    Thanks for the clarification of what set of sensors I should be working on.
  9. Mar 26, 2012 at 9:28 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Subd even though it's an old thread this happened to my truck the other day and now my o2 sensors don't work both bank 1 and 2
