o2 Sensor Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by WVFC1101, Mar 7, 2012.
  1. Mar 7, 2012 at 9:09 AM
    WVFC1101
    WVFC1101 [OP] Member
    Cliff
    Northern VA
    02 Tacoma SR5
    Add a leaf rear, 2'' coil spring spacer in front, xd hoss wheels.
    My truck is throwing a code (PO420) I was told it was the Upper sensor. I was wondering if someone could help me find where it is so I can replace it or if there is a more simple solution. I was also wondering if this is a common problem with the 02's. Thanks.
  2. Mar 7, 2012 at 9:38 AM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    this
    http://www.4x4wire.com/toyota/4Runner/tech/O2_Sensor/
    http://www.tacomaworld.com/forum/1st-gen-tacomas/142451-rear-o2-sensor-done.html
    just do it by the steps
    order them from rocauto in the offical vendor list AND GET THE DENSCO nothing fancy or $$ for these trucks or they will let you know.
    i would get both so i would not have to get back under there if and when the other one goes out and it will
    get some good bold blaster lube and practice getting under the truck for a few day to looses up the bolts while the parts are coming when its cold give them a blast, drive it and then repeat for several days will save you from a lot of swearing. they can get very rusty!
  3. Mar 7, 2012 at 10:08 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    That code is actually for the catalytic converter but it can be triggered by numerous things.
    http://www.ncttora.com/fsm/2003/Repair_Manual/03tacoma/di/eg5vzfe/cip0420.pdf
    I would suggest replacing both sensors also.
    And yes, it is common with first gens for the sensor(s) to be replaced but only because they have been i service for a long time now.
  4. Mar 7, 2012 at 7:14 PM
    Jenkinstall
    Jenkinstall Active Member
    Jennings
    Colimbia, sc
    00 SC 4Runner Sport Edition 4wd
    Suspension/Drivetrain: 4wd swapped, E locker in rear with 4.30 gears, tundra 5100 adj. bilstein shocks, Trd coils, ome 891 springs with tundra shocks in back. Addicted offroad front tube bumper with BashFab hoops and stingaaaa, BashFab rear tube bumper, 285/75/16 BFG K02, tacoma wheels, savage offroad trans and t case skids and homemade gas tank skid. Engine: 2nd gen TRD SC, URD 7th, 2.2, TRD T-stat, IK-22 Plugs, TRD boost gauge, AEM wideband, ISR mod, and more to come. Interior: Kenwood marine stereo with Bluetooth
    sensors dont just go bad. something cause it had to go bad either from too much contamination from fuel or coolant or from a weekend warrior with seafoam or lucas. pull it out and check to see how dirty the sensing part is. dont just throw parts at it cause it may not be long before the new one goes out without determining the cause of the failure
  5. Mar 7, 2012 at 7:58 PM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    well I am sorry but sometimes they do. they wear out just like anything else on a car over time. I had a 92 Nissan SER put 300,000 on her but at 120,000 miles I bought a socket, had to back then, cleaned it with carb cleaner, friend at Nappa told me this trick, if you car has a funny idle, and it had some carbon on it, well 3 months later at Myrtle Beach on the week of the 4th, it just died..... and i was really stupid i used the car jack to get under the car to fix it myself...and drunk..
    i read this awhile back, its long..
    http://www.ttora.com/wiki/index.php/Oxygen_Sensor_Test
  6. Mar 8, 2012 at 5:32 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    X2.
    And just looking at it isn't going to tell you squat. Inside the sensor is a small heating coil. 99% of the time that is what fails in the sensor. And cleaning them doesn't help.
  7. Mar 8, 2012 at 9:20 AM
    WVFC1101
    Cliff
    Northern VA
    02 Tacoma SR5
    Alright, Thanks for all your feedback guys today I am going to get under there and start loosening them with some lube and Im also going to replace both I do believe. I may have another question along the way but thanks again.
  8. Mar 8, 2012 at 7:13 PM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    well just ask.
    are you near Winchester VA? or more near the dreaded washington dc
  9. Mar 11, 2012 at 8:23 PM
    WVFC1101
    Cliff
    Northern VA
    02 Tacoma SR5
    Im far enough away from D.C. thank god and I am kinda close to Winchester. I am in Fauquier, well Warrenton. I am in Winchester pretty often I got a lot of buddies up in Berryville.
  10. Mar 11, 2012 at 10:05 PM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    when my uncle was in business, we used to sell to sunbelt rentals, and man i can't count the trips I made that way up 29 and interstate 81 but I always enjoyed countryside! Esp. in the fall.
  11. Mar 17, 2012 at 2:52 PM
    ebayollis
    ebayollis MY DIXIE WRECKED
    josh
    spruce pine nc
    2017 tacoma trd sport ddbl cab 4wd auto
  12. Mar 18, 2012 at 8:17 AM
    watacomaguy
    watacomaguy Active Member
    Washington
    2012 4x4
    Oxygen sensors are considered 100K replacement items. So no defects there. I'd do both. Probably go with OEM(Probably Denso) instead of Bosch or NGK. Check Rock Auto once you have the exact part number.
