O2 sensor question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ZackM, May 8, 2012.
  1. May 8, 2012 at 7:03 PM
    ZackM
    ZackM [OP] Member
    Zack
    AZ
    07 Tacoma Sport silver
    I replaced the stock headers with doug thorley long tubes and of course the engine light came on. The stock o2 sensor seized on the driver side. My question is i am wondering if it is the upstream or downstream? i have looked around but didn't come across anything. also where is a good cheap place for an o2 sensor? i read that denso is oem so i wanted to go with them.
    Thanks for any help!
  2. May 9, 2012 at 7:44 AM
    ZackM
    ZackM [OP] Member
    Zack
    AZ
    bump
  3. May 9, 2012 at 8:01 AM
    Bryan139
    Bryan139 I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
    Go to an autoparts store and have them read the code for you. That will tell you which sensor it is.
  4. May 9, 2012 at 8:09 AM
    the.sight.picture
    the.sight.picture Well-Known Member
    Nick
    Warren County VA
    2018DCSB TRD Quicksand
    Emu 887x Nitrochargers Dakar Heavys, 255 85 16 ST-MAXX
    i bought both of my down stream denso 02s for 50 bucks a peice on Amazon. plug and play. but upstream cost $$ like 150 last time i looked
  5. May 9, 2012 at 8:19 AM
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    Why do you think the sensor seized? A code after header install is most likely the downstream sensor, since the AFR on the upstream should still read properly - or be able to adjust for the slight change with the headers. It's the downstream that will throw the code now that the cat is gone. It's sole purpose is to make sure the cat is doing its job - which it now knows it's not.
  6. May 9, 2012 at 8:26 AM
    ZackM
    ZackM [OP] Member
    Zack
    AZ
    i'm not sure why the sensor seized up. when i reinstalled the o2 i used anti seize and it was the first time they had been removed so maybe they didn't use anti seize or not enough from the factory. i will check out the engine code today thanks for the help!
  7. May 9, 2012 at 8:29 AM
    the.sight.picture
    Nick
    Warren County VA
    Have you thought about an URD 02 SIM?
  8. May 9, 2012 at 8:35 AM
    MadToy
    Nick
    Huntersville, NC
    Ah - I thought you meant the sensor itself stopped working. Just be extra careful not to get anti seize on the sensor part of it.
    I haven't followed too much of this subject on the Toyota forums, but a trick we would use to also fool the downstream sensor was to use spark plug fouler extenders, with steel wool stuffed between them. This worked well for me. It basically pulls the sensor out of the direct stream, and muffles the gas content to make the sensor read as if there was still a Cat there.
  9. May 9, 2012 at 3:00 PM
    the.sight.picture
    Nick
    Warren County VA
    DO you have a pic?:confused: im interested
  10. May 9, 2012 at 4:11 PM
    MadToy
    Nick
    Huntersville, NC
    Basically, you need the size foulers that are the same thread as the O2 sensor. 2 per side. You drill one out so the O2 fits in it, and you screw that one into another with steel wool between 'em. Not sure how the ECM on the Toyota will read it, but it worked with the Dodge, which has a very sensitive ECM system.
