O2 sensor question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bernard, Jun 30, 2013.
  1. Jun 30, 2013 at 11:05 AM
    Bernard
    Bernard [OP] Member
    Bernard
    SoCal
    2003 Tacoma
    Hiya! My 2003 Tacoma (2.4L, automatic) has recently begun having intermittent PO135 OBD2 alarms...the upstream O2 sensor. What I'm curious about is are these things different for California based vehicles? I'd like to just order a Denso sensor online, pop it in, and not have any future issues. Anyone know if they're the same nationwide? Thanks in advance! :)
  2. Jun 30, 2013 at 11:26 AM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Not sure about your question but if you do order, rockauto.com has the best prices I've found for OEM 02 sensors. Just an FYI
  3. Jun 30, 2013 at 1:32 PM
    tacomataco2
    tacomataco2 Well-Known Member
    Eastham Mass
    02 Dbl cab Silver
    Bilstein 5100's, eibach coils, u bolt flip, Dakars/d6xl, Ome shackles, Poly sway bar bush, Poly rack bush, voltmeter, led guage lights, magnaflow stainless catback, stainless cats, deckplate mod, afe filter, tundra brakes,PIAA fogs behind grillecraft, color matched grille, soft topper, Projector retrofit, Allpro bumper , Blitzpro light bars, Alpine/ rock fosgate sound system, 35% tint, Some derped stuff
    ^x2 on rockauto! And in 01' all tacomas became California emmissions, so all the sensors are the same
  4. Jun 30, 2013 at 4:49 PM
    Mainmoe02
    Moe
    Austin, Texas
    Front and rear are the same?
  5. Jun 30, 2013 at 5:55 PM
    tacomataco2
    Eastham Mass
    02 Dbl cab Silver
    No, I'm saying there is no federal emmissions or California emmissions sensor, they're all just California. Idk if there is a difference between the two in the first place though..
  6. Jul 1, 2013 at 7:26 AM
    Bernard
    Bernard [OP] Member
    Bernard
    SoCal
    2003 Tacoma
    Thanks, guys! I'll go ahead and order an O2 sensor today. :)
  7. Jul 1, 2013 at 7:30 AM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    Rock Auto is great.. so is Camel Back Toyota, just ordered an OEM Toyota one from Camel Back.
  8. Jul 1, 2013 at 11:37 AM
    Sittingbull2
    Sittingbull2 Old N.R.A. Hippy
    Mitch
    Southeast texas
    2000 Xtra Cab SR5 White
    3" Body lift, ARB Front Bumper w/9000 lb. Warn Winch, Chevy Alum. Rims w/ Kelly 285's M/S
    There is a difference. My 2000 is a California build but it is a Federal Emission for as 02 sensors. I bought mine on RockAuto my self but the wire connectors are made different for Federal versus California. The support from RockAuto is excellent it took about 15min. to get it figured out over the phone and then it was sent on its way in the mail. Plus Federal emissions 02 sensors or about half the price of California 02 sensors.
    Sittingbull2
  9. Jul 1, 2013 at 12:03 PM
    tacomataco2
    Eastham Mass
    02 Dbl cab Silver
    I said for 01-04's not 96-00
    Op has an 03
  10. Jul 1, 2013 at 12:17 PM
    Sittingbull2
    Mitch
    Southeast texas
    I know what he said and you said I can read but you said you didn't know if there is a difference between the 2 and I just went through this. I received California emission 02 sensors when I tried hooking it up it wouldn't work because the connectors are different. I personally don't know when they changed from federal to all California type. But there is a difference.
  11. Jul 1, 2013 at 12:31 PM
    tacomataco2
    Eastham Mass
    02 Dbl cab Silver
    The change 'twas in 01, all Toyotas became California rated. I said that before, I just didn't want the op to become confused when you said there is a difference, but for his truck there is not.
  12. Jul 1, 2013 at 3:27 PM
    Bernard
    Bernard [OP] Member
    Bernard
    SoCal
    2003 Tacoma
    Nah, at age 67 the CRS & confusion just make daily life more interesting! :)
    I ordered a Denso 234-9002 O2 sensor from Rock Auto.
  13. Jul 5, 2013 at 11:04 AM
    Bernard
    Bernard [OP] Member
    Bernard
    SoCal
    2003 Tacoma
    Update:
    Rock Auto delivery was very quick, the next day in fact. I decided to try changing the O2 sensor today, but I'm having problems getting my oversize mitts in there to disconnect the wiring connector. I'm guessing a small screwdriver will work, but the area is so crammed with steel tubing that I can't reach the connector with one. It looks like I need to remove the steel mount which holds the connector, or else pop loose the plastic connector bottom from the mount with some needle nose pliers.
    Any handy hints to get at that lil bugger? :)
  14. Jul 5, 2013 at 12:31 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are you underneath?
    I had a manual when I changed mine - and had to remove the shifter boot/cover to access the wiring from inside the truck. I don't know if that'll help you on an Auto or not.
  15. Jul 5, 2013 at 4:06 PM
    Seventh
    Seventh Insert witty title here
    Boston, MA
    2001 Reg Cab 4x4
    I just did mine (5Spd) and went through the shift boot as well.
