o2 sensor readings
Discussion in 'Technical Chat' started by hatrabbit, Dec 4, 2009.
  1. Dec 4, 2009 at 3:10 PM
    hatrabbit
    hatrabbit [OP] New Member
    A friend has an OBDII scanner, just for shits I plugged it into my 03 Tacoma 2.4L, all stock tacoma. I don't know anything about these readings, but to me the values don't look right:
    O2S B1 S2(V) .805
    O2S B1 S1(V) 3.297
    Anyone here know how to interpret these?
    Thanks.
  2. Dec 4, 2009 at 3:13 PM
    hatrabbit
    By the way, that was with a warmed up engine at idle.
  3. Dec 8, 2009 at 12:49 PM
    revhappyleon
    revhappyleon Well-Known Member
    Manny
    Tampa near macdill
    07 Prerunner V6 6-speed(custom dual exhaust)
    dual exhaust, foglight anytime, satoshi, chlm, aux backup lights and electric fan conversion
    the b1s1 is the one in the header and it should be bouncing up and down due to the engine constantly switching from lean to rich at idle and the b1s2 should be staying within a pretty small range since the catalytic converter consumes any rich spots
  4. Dec 8, 2009 at 12:57 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  5. Dec 8, 2009 at 1:15 PM
    FuTang909Inamo
    FuTang909Inamo Well-Known Member
    Socal IE
    03 TRD PreRunner
    Deckplate mod, Trueflow drop in filter, clear corners, 31 BFG A/T on 15x8 Mb Razors.
    Looking at the graph(s) wouldn't hurt either. Like the other poster said, 02b1s1 is upstream and should be active, going from rich, lean, rich, lean, rich...02b1s2 downstream after the cat, should be almost flatline.
