O2 sensor removal. Wtf...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Larzzzz, Oct 8, 2016.
  1. Oct 8, 2016 at 8:18 AM
    Larzzzz
    Larzzzz [OP] Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Got the rasta cel and wanna swap O2 sensors. 2 different styles of tools, socket and crowsfoot, and they both slip in the sensor nut. Soaked for a couple days with pb blaster, tried hot and cold. Torch on the cold bung..it ain't moving.
    Will the connector fit through a box wrench?
    22 mm I believe. And of course, I dont have one. Yet. Lol
  2. Oct 8, 2016 at 10:37 AM
    muisejt
    muisejt Well-Known Member
    YMM
    08 TRD Sport DC LB
    Katzkin, Bi-xenon Morimoto Mini Stage III Kit (D2S), 4Runner Mirrors, Complete Stereo Upgrade with Backup Camera, Pop&Lock PL5400, Extang Solid Fold Tonneau, TRD OR Tow Hook, rcbs204 4x4 Illuminated Switch, Grillcraft, 10" Rigid light bar behind grill, relocated horns, Redline Tuning hood struts, 5100's with 883 and Wheeler 5 leaf, OME carrier barring drop kit, ECGS Bushing, MarionB2B front hubs
    heat the bung and take a 4lbs sledge to the wrench
  3. Oct 8, 2016 at 10:41 AM
    smd3
    smd3 Well-Known Member
    Run over to your local parts store and get an 02 sensor wrench. It'll go on a 3/8 ratchet handle.
    Heating it up wouldn't hurt, either.
  4. Oct 8, 2016 at 12:19 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  5. Oct 8, 2016 at 1:38 PM
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
    O2 sensor wrench is your friend. The shorter style works better in tight spaces.
  6. Oct 8, 2016 at 1:41 PM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Hankook DynaPro AT2 (Summer), Blizzak DM-V2 (Winter)
    Yup, O2 sensor wrench makes it much easier. I have one like this:
    Based on where that image came from, it appears Harbor Freight has them.
    shakerhood likes this.
  7. Oct 8, 2016 at 4:06 PM
    Larzzzz
    Larry
    MA
    Both styles slipped on the sensor. I ended up using a 22 mm box wrench and a Chevy tool,(hammer). Lol
    Unfortunately, torque still showed bank one all over the place. Check the wiring next...
  8. Oct 8, 2016 at 4:15 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    if you are replacing the sensor than just cut the connector off and use a regular wrench. The new sensor will have a new connector on it.
    Aussiek2000, 3coma and smd3 like this.
  9. Oct 8, 2016 at 5:16 PM
    smd3
    What year is the truck? Any coolant loss?
  10. Oct 8, 2016 at 6:15 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    To be clear, which side did you go to as "bank 1"?
  11. Oct 8, 2016 at 6:16 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Knipex parallel pliers work amazing for this scenario.
    koditten likes this.
  12. Oct 9, 2016 at 3:51 AM
    Larzzzz
    Larry
    MA
    I swapped the sensors before I spent the money. Didn't have to cut the connector to slip the box wrench on.
    It's an 06 and I was losing coolant before i had the motor swapped out.
    Passenger side, the side with the most forward cylinder.
    I don't think the knipex pliers would work as well as the box wrench and hammer.
    smd3[QUOTED] likes this.
  13. Oct 9, 2016 at 6:33 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Use mine regularly. However, my exhaust components get swapped around more than anyone here, so fornthat reason mine aren't seized in, like yours seems to be.
  14. Oct 9, 2016 at 6:36 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Nothing worse than a cold bung.
    Larzzzz[OP] likes this.
  15. Oct 9, 2016 at 6:41 AM
    Larzzzz
    Larry
    MA
    Got them out and swapped them over. Box wrench and a hammer.
    Why are the leads on the 2 sensors different lengths? That's pretty deep gouge Toyota's giving us here with 2 different parts IMO.
  16. Oct 9, 2016 at 8:39 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Not exactly sure what you mean. The sensor infront of the cats are factory WRAF sensors. After the cats, those are O2 sensors. That would be two different parts, but not sure if that fits what your talking about?
  17. Oct 9, 2016 at 11:26 AM
    Larzzzz
    Larry
    MA
    I'm referring to the O2 sensors behind the cats. Drivers side sensor has longer leads than the passenger side
  18. Oct 9, 2016 at 1:38 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Oh ok. Just the way the bungs are clocked, and harness is situated.
  19. Oct 10, 2016 at 3:15 AM
    Larzzzz
    Larry
    MA
    That could be. I actually didn't put them side by side. Laying on broken acorn shells is not the most comfy and I just wanted them swapped.
  20. Oct 10, 2016 at 9:01 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Nature's bed of nails. Lol
