O2 sensor replaced, Check engine light came back
Discussion in '1st Gen. Tacomas (1995-2004)' started by Flash333, Feb 21, 2012.
  1. Feb 21, 2012 at 2:14 PM
    Flash333
    Flash333 [OP] Member
    03 TRD SR5 Silver
    Hi all
    So i replaced my O2 sensor yesterday. The Bank 1 sensor 2. Everything when fine. I cleared the alarm with my OBD2. Now today on my way home from work, the check engine light came back one and yes, it is the same alarm. Sensor O2 Bank 1 Sensor 2.
    ??????? Should i just burn the truck and buy a new one?????:D
    Joke aside, i dont know where to go now for troubleshooting...
    Any takers ?:cool:
  2. Feb 21, 2012 at 2:18 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Check the wiring isn't pinched or burned especially around hot areas of the engine. Also exhaust leaks or restrictions. EVAP emissions system or fuel pressure.
  3. Feb 21, 2012 at 2:38 PM
    Flash333
    03 TRD SR5 Silver
    all right !! ill check that out. could fuel pressure really do that ??
    Also, for more info, my OBD2 says i'm in the yellow for emission control. (if that means anything) and i have four lights flashing on it.. one is the O2S, Cat, and two others that i have no idea...
    cheers
  4. Feb 21, 2012 at 3:29 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    on any car i have had i always unhook the battery for 30mins to reset it.
    its the old fashion way, but that is the way i am. don't know if this helps.
  5. Feb 21, 2012 at 3:43 PM
    Flash333
    03 TRD SR5 Silver
    Nice !! the good ol redneck way... But yeah, i can reset it with my OBD2 but it keeps coming back... thanks anyways ;)
  6. Feb 21, 2012 at 4:20 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I replace oxygen sensors in pairs. If one is bad, chances are the other one is failing too.
  7. Feb 21, 2012 at 5:36 PM
    bicklebok
    bicklebok Well-Known Member
    Ronnie
    Montgomery, AL
    2000 Xtra Cab 4x4 SR5
    What brand O2 sensor did you buy? Denso is the only way to go on these trucks.
    I replaced mine about 6 months ago, and the light came on about 3 more times over a few hundred miles. I reset it each time, and it has now quit coming on.
  8. Feb 21, 2012 at 5:46 PM
    dud122
    dud122 rabble rabble rabble
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Warn winch, Tactical rear bumper with tire swing/jerry cans/hi lift, Revenge Fab. sliders, Tundra brakes, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Lights, CB, Switches, skids, LED's... OH MY!
    i went back and forth trying to fix the same problem... replaced both sensors twice over a couple years... now the only way i can keep the CEL off is if i run premium gas. if i fill up with regular the light will be back on by the end of the tank and it will take about 1-2 tanks of premium before it stays off. i've tested it several times and it happens like this every time.... i just figure the truck is getting picky in its old age.
  9. Feb 21, 2012 at 6:13 PM
    JSFoster75
    JSFoster75 Well-Known Member
    Scott
    Bluff City, TN
    2018 Wrangler JLU Sahara
    Too many to list.
    Advance Auto, Autozone, or O'Reilly Auto Parts will do a code reset for free... Could just be a fluke with the sensor tripping... Try having it reset once or twice and see if it comes back on, if so, replace the sensor with a OEM.
  10. Feb 21, 2012 at 6:39 PM
    Flash333
    03 TRD SR5 Silver
    thanks everyone, will try your tricks for a lil while and see. I bought that sensor off ebay and i dont even know what kind it is. Ill buy a denso if that doesnt work.
  11. Feb 22, 2012 at 5:18 AM
    dud122
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    try rockauto.com
    they have very good prices. i get all my OEM replacement parts from them.
